Results 1 to 13 of 13
    Sep 27 2015
    iglo
    Cam installation on aeb engine
    Looking to find out how to reinstall the cams on my aeb head thanks
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Compress chain tensioner
    Run chain between cams with 16 rollers in between marks on cams
    Slip tensioner in
    Drop assembly into head
    Start replacing caps starting with center and working out
    Torque caps
    Remove tensioner
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Dec 05 2007
    Quote Originally Posted by redline380 View Post
    Remove tensioner tool
    ftfy
    Confirm tdc marks line up
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    ftfy
    lol good catch!
    2000 S4- Working?
    Sep 27 2015
    iglo
    Thanks now how do I time the block to the head it's a strain to time it the engine is there an easy way to do this
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by b52400 View Post
    Put pistons all the way up, put head on. Install lower timing belt cover and valve cover, ensure mark on crank pulley meets mark on tbelt cover, then make sure mark on cam gear meets up with valve cover mark.
    2000 S4- Working?
    Sep 27 2015
    iglo
    Could I also use the arrows on the cam journal caps or what ever there called and line them up with the boxes on the cam sprockets on the side were the cam chain is?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    OMG totes ma goats! That is, like, totally what it is for!
    2000 S4- Working?
    Sep 27 2015
    iglo
    Lol is that sarcasm or is that a yes just asking cause I have timid my engine like that before and I guess It was successful
    Senior Member Two Rings Spectre1130's Avatar
    Jan 08 2012
    2015 VW GTI
    Colorado Springs, CO
    Like very much truth brah!
    97 A4 1.8t: Reflect 650cc, T3 6063 turbo, turbo back exhaust & FMIC, top mount manifold, Apex lowering springs, 81.5mm bore, Supertech pistons, Eagle H beams
    Sep 27 2015
    iglo
    How can I compress the can chain tensioner without the tool ?
    Sep 18 2013
    Cleveland
    You don't. The tool is designed to thread in, compress the tensioner, and keep it compressed while the tensioner is moved.
    99.5 a4 1.8tqms Brilliant Black
    APR Stg 1, 710n, A8 brakes, OEM Xenon Kit, 034 PCV, 034 street density mounts, fog light mod.
    Mods on the table: too many to list.
    Sep 12 2008
    South Central PA
    I've done it will zip ties. It's a pain in the ass without the tool.
    Squeeze it together and run a ziptie around it. Only thing is that it makes it a bitch to keep the chain on. But once everything is in place you just cut the ziptie and pull it out.
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
