Results 1 to 33 of 33
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    E85 and stg 3 Magnuson
    I'm convinced this is the ticket. It came to me last night as I was taking a dump.
    The magnuson unit seems to be trapping 124 consistently with race fuel, but who drives around with race gas as a commuter. E85 runs cooler too doesnt it?
    Does anyone know anyone that has done this?
    AXA
    Turbo Villains
    Veteran Member Four Rings 4RCFED's Avatar
    Aug 27 2014
    12' Audi S4 (sold), 18' Discovery HSE (V)
    Sandy Springs, GA
    Haven't seen any numbers/logs on it. There's only a handful of people running the bigger blower I think.
    2012 S4 (sold)
    Jan 14 2009
    2014 S4 2014 GLK Diesel. 06 Jetta TDI
    pasadena md
    Their is no try. Their is do or do not.
    But only a 2mph bump from full out Stage 2+ to a Stage 3 seems lame to me.
    Its not that it runs cooler per say. Just E85 has a higher octane rating so its more resistant to knock or detonation.
    Forum Moderator Four Rings Loe's Avatar
    Aug 09 2015
    Audi RS E-tron GT, BMW i4 xDrive40
    Sarasota, FL
    Only one Magnuson car trapped 124mph, I wouldn't call that consistently, and I don't believe it was even reported that it did it consistently as they only posted their best time.
    Loe P - Forum Moderator, Audizine
    Sold: ('14 Audi S5 S-tronic: [email protected] (127.36mph highest trap)| +424 ft. D/A | 3.371 PR | full-weight/street tires).
    Current: BMW F82 M4cs, Audi TT RS APR E85 Stage 1 "+" ecu/tcu: [email protected] (Panel filter | 4" turbo inlet | intercooler | stock exhaust, suspension, 18" Neuspeed wheel/tires, | full weight).
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by chaos2984 View Post
    Agreed,
    I'm 1.81mph below in overall 1/4mile traps, and I'm on stock cooling, full weight, and ran in D/A's that were approx 1,148ft higher.
    Primtime is trapping 1.12mph below in overall 1/4mile traps in D/A's that were approx. 556ft higher.
    But then again, it's hard to compare numbers from different tracks on different days and different testing environments. I hope there is continued development on the stage III blowers, I would like to see solid and consistent 10's from the platform.
    Veteran Member Four Rings hodrosS42001's Avatar
    Mar 18 2012
    New Jersey
    E85... has ALWAYS been the answer... whether Stage 1/2/3... but there's little to no support for it and it will require additional hardware.
    There have been companies that have posted "teasers" of E85 support with flex fuel sensors attached at the fuel rail. This would absolutely solve most issues with heat.
    I wouldn't be surprised if you see within the year multiple companies that come out with a dual pulley tune/full e85 support with a fuel pump and flex fuel sensor. Based on EPL's posts we could all expect big gains off both at Stage 2+ levels and who knows with the tvs1740.
    Also APR has still teased that they are working on "other" solutions for the 3.0T which could be anything.. possible a turbocharger conversion.. which would probably produce more power for less than the Magnuson Blower.
    Oct 20 2008
    Denver
    Quote Originally Posted by hodrosS42001 View Post
    i mentioned thinking about E85 to a buddy of mine who works at a local tuner shop here. he did me a favor and called APR and asked them if they have anything in the works with E85 which they did answer "yes, and they're working on it" but didn't give any time frame or details.
    Stage 2 Banner Advertiser Four Rings
    Sep 06 2007
    After accessing the hardware on pump fuel, we've decide not to support the 1740 blower with a software/upgraded hardware solution.
    Jun 12 2015
    CA
    Quote Originally Posted by AudiTFSI3o3 View Post
    A few weeks ago I called APR and they said they weren't working on a dual pulley, or E85 solution. An APR solution is a hope, EPL's solution is real, and a phone call away.
    Veteran Member Three Rings shoe3k's Avatar
    May 18 2015
    weedwhacker
    No where
    Quote Originally Posted by Tony@EPL View Post
    Good choice because the 1740 is a complete waste on this platform.
    Previous: |'18 Golf R | '17 S6 | '15 S4 | '15 STI | '12 GLI Autobahn | '08 Passat | '04 R32 | '05 GTI 1.8t |
    May 22 2015
    DFW
    I'm pretty sure I'm maxing the injectors on E85 dual pulley. So there's that to consider..and with Direct injection it won't help IAT at all.
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    I drive around with race fuel for much of the summer. I work from home so a tank lasts me 3 weeks.
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    Work from FTW. but the race fuel is costly none the less. E85 will be the winner for sure but is this platform able to handle it. everything is electronic so we depend on the tuners for the right adjustments and some cars are not the same... i.e.. some cars burn oil so this and other issues can change the performance and at the top end of this platform anything makes the difference even the spark plugs lol.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
    Dec 19 2014
    Virginia
    Let's just put a cobra blower on the car an m112 would do the trick lol
    16 s3 eurodyne stage 2 ecu/tcu
    Jb4 Methanol Intake exhaust
    2010 s4
    Epl stage 2 ,test pipes non res downpipes custom exhaust , intake , dual pulley setup torque monster .
    Gone:
    07 a3 , unitronics stage 2 , water meth .
    Aug 09 2015
    Sarasota, FL
    I do wonder about the S/C intercooler health long-term with a dual-pulley set-up though. I know an upgraded cooling will help, but I would love to know the delta between a stage III versus a stage II DP in outlet S/C intercooler temps.
    something to think about in terms of reliability because I have searched and found some cases of them leaking even on stock level boost. However, our stock S/C intercoolers are cheap and as easy as removing the S/C itself to replace, which others have stated is like an hour job.
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    I walked one pump for pump.... Posted the video a few weeks back. APR stage 3 with all the supporting hardware. Same tune that supposedly made 477whp
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Aug 21 2014
    Boston
    someone make an adapter for a whipple!
    2015 Ibis White S4 DSG
    Veteran Member Four Rings audistealth's Avatar
    Mar 04 2012
    2012 Audi S4, 2017 Explorer Sport
    Quote Originally Posted by CELison View Post
    Are you blending E85 and 93, or running straight E85 on that GIAC stage 2?
    /// 2012 S4
    RocEuro Intake | AWE/GIAC Stage 2 | 19" Titanium Rotor Wheels 10mm H&R spacers | RS5 BBK & ECS 2pc front/rear wave rotors | Renn RS-51 19x8.5 20.5lbs | JHM LW/HD Pulley | MMI 3G+ rev. G and controls retrofit | vagcom stuff | Jokerz ported coated supercharger | KW V1
    Mid-Atlantic Forum (MD/DC/VA)
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by audistealth View Post
    E38
    B9 S4- EPL/AWE
    Aug 09 2015
    Sarasota, FL
    E38
    Loving that you are continually testing this mix as well, its such a perfect mixture!
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by Loe View Post
    For sure.
    B9 S4- EPL/AWE
    Mar 04 2012
    E38
    Does that assume shell 93 is 10% ethanol, and is that on the normal stage 2 tune? Just curious.
    /// 2012 S4
    Feb 23 2010
    Emmaus Pa
    Yes. And it's on the race gas file.
    B9 S4- EPL/AWE
    Mar 04 2012
    No knock or timing retard on the 100 file? VERY interesting. I should pay more attention here again.
    /// 2012 S4
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Indeed. Loe ran 11.2 @ 122 on a similar 93/e85 mix on GIACs race file stacked with the CW pro box. From the logs I've seen, his car makes excellent timing and pretty much no knock corrections in good conditions.
    Jul 10 2015
    SATX
    What is the ratio of 93 to E85 to acheive the E38?
    This is handled ok by stock FP?
    I mixed my first tank last fill and went conservative with 2 gallons E85 rest93 on empty tank.
    TIA!
    2014 S4 - Ice Silver Metallic - DSG - Sports Diff - Black Nappa - Xpel Ultimate
    2005 Allroad 2.7T - Daily Commuter - Silver - FBP - 19X9", 255/40/19" ET14.
    Prior:
    2006 A3 2.0T Revo tune
    2002 VW GTI 1.8T Revo tune
    1996 Eagle Talon TSI 2.0T
    1992 Eagle Talon
    1990 Chevy Corsica
    1988 Ford Tempo Coupe, 5-spd
    Dec 20 2005
    District 7
    it's true, this thread is my shameless attempt to reinvigorate the discussion regarding higher power for us via e85. I just still can't believe the stg3 is such a monumental flop. All that time and then nothing.
    How are you and the other guy trapping 122 when everyone else seems to hover around 117-116 with similar altitudes?! I want 122. Id be happy with my car consistently above 120 mph- mind you this is not a track toy for me, but just using the 120 mph trap to gauge overall power.
    AXA
    Turbo Villains
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by Boris View Post
    dual-pulley set-ups with either specific or a combination of non-specific hardware/software to support it. I'm on GIAC stage II + Chipwerke Pro, primetime is on a dual-pulley specific APR file. Mind you that me and him could also improve our times and 1/4 mile traps as well, so our current results may go up by years end.
    There are two others also trap over 120mph, one is dual-pulley without running supporting software for it (Jones2012S4 GIAC stage II, 121.26mph), while the other one is a single pulley car (Auditude 2.0t GIAC stage II, 120.03mph).
    I have a feeling two or three more APR cars, and possibly two more GIAC cars will join the 120+mph group in the near future as well, just a prediction
    Aug 09 2015
    Sarasota, FL
    Quote Originally Posted by mrmomo313 View Post
    Sure does
    Here is a log from my slower 11.2x times --> https://drive.google.com/file/d/0OTN...ew?usp=sharing
    Also shows the behavior of the engine during the LC sequence
    Veteran Member Three Rings ALAN12186's Avatar
    Mar 30 2016
    Brick, NJ
    I should be running my setup in the coming weeks hopefully I can join the club
    13 S4/6mt/SDiff/MMI/B&O/Black Ops/APR Stg2+ Ultra,SC & 187MM Crank Pulley,TB & CPS V2/APR Intake/Milltek Res GT100/TA HF Cats/FF103 19x9.5/ Vorsteiner Front Lip/E Codes/ECS Diffuser/P3-Vidi Track Pack/Bilstein B12 & H&R OE Springs/EBC Red Pads & Slotted Rotors & SS Lines F&R/Brembo Calipers/CR15/APR 7MM F&R/034 Sway/Moog Links/ECS Drivetrain Mounts/Eurocode Krez/ECS Clutch Line/034 Trans, Motor & Sub Mount/SB STG 3 Clutch/USP Slave/Enlaes Spoiler/ECS SS/Autotech HPFP/Jokerz Blower/Killer Chill
    Nov 30 2015
    Newark New Jersey
    seems to be a lot of dual pulley cars on the streets now. Anyone ever pop one of these motors ? i don't care about the blower as it seems they are a dime a dozen.
    Veteran Member Three Rings Silverbullet S4's Avatar
    Mar 10 2015
    CO - 6,200' +
    ...called APR and asked them if they have anything in the works with E85 which they did answer "yes, and they're working on it" but didn't give any time frame or details.
    That's been the answer for "TWO WEEKS". My shop in the Springs is supposedly in tight with the tuners at APR (allegedly helped them with the last stage II update and some skunk works A4 stuff that will beat our S4s) and they said they have nothing currently in the works "and probably won't" for the current gen S4s. Who knows....
    2013 S4 - APR Stage 2+, DP, CPS v3, BLQ 20s, Solo Werks coilovers, CR-15, EBC Rotors F&R, Deval diffuser, AWE exhaust & USP Intake - TD1 inevitable
    Aug 21 2014
    Boston
    Dual pulley + e85 + nitrous + upgraded dsg clutches = Low 10s?. I dont know what the bottom end can handle
    Slicks would be nice too
