Results 1 to 16 of 16
    Oct 14 2013
    Bay Area
    New RS5 Owner! A Few Questions
    Hi guys,
    Been lurking for a while and just purchased a Panther Black RS5 this weekend! I have a few questions hope you guys can provide some clarity on:
    -Do downpipes with Stock Sport Exhaust add any horsepower?
    -My car doesn't seem to have the same "farting noise" during upshifts - is there a more aggressive shift mode or does Dynamic mode set you in the most aggressive setting?
    -Are you able to skip tracks via the steering wheel? I've only been able to do it with the audio "Joystick"
    Veteran Member Four Rings HazeMyth's Avatar
    Jul 17 2015
    Colorado
    Only some media sources allow you to skip tracks using the steering wheel. Bluetooth does not allow that functionality, for instance.
    The farting noise is from the "dynamic exhaust" being enabled. The car won't start up in Dynamic mode. Hit your drive select button a few times after you start the car to ensure it's in dynamic mode, it it should fart for you.
    As far as the transmission goes, Dynamic is as aggressive as it will get.
    2013 Audi S5 - EPL Stg 2 E40 ECU/TCU, AWE Track 102mm, RocEuro intake, etc.
    2014 Audi Q5 S Line
    2011 Toyota Tacoma TRD Sport - Lifted, reinforced, and slow
    2003 Evolution VIII - HKS280, FBO
    2004 Subaru STI - Stg. 2 (Sold)
    IG: @MrHazeMyth
    Established Member Two Rings mikron2's Avatar
    Feb 27 2016
    Nevada
    Congrats on the purchase! I just got mine back in March and had been lurking here quite a bit too so welcome. My answers are based on having the car for a month and a half now, and what I've read here/elsewhere so anybody please correct me if I'm wrong on anything.
    Quote Originally Posted by The Punisher View Post
    Not from what I've read. If it does it will be fairly negligible. It does add volume. Even the full exhaust systems from what I've read are fairly limited on hp gains. There's been a lot of discussion but the answer I've seen is either they don't add any, or they add up to 15hp but that's it.
    If you want the upshift/downshift sounds you'll need to be in dynamic mode and ideally manual as well. You still get them in dynamic but you'll need to pull the shift lever back toward you so the display on the dash shows an "s" instead of "d" that will get you the sounds. If you switch to dynamic and it's already showing "s" no need to bother with the shift lever. Otherwise it's pretty quiet with the valves closed on the exhaust. You'll hear more of it on downshifts than upshifts but you do get them on upshifts it's just faster because you're usually accelerating hard and revving high when you do get them.
    Not as far as I can tell
    2013 RS5 - Vorsteiner VFF - 104 Graphite 20x10, E-Codes, ECS Aggressive Spacer Kit
    Veteran Member Four Rings JamesRS5's Avatar
    Feb 27 2014
    Dubai
    Hi Punisher and welcome, great looking car.
    Firstly, no, down pipes won't do much except for removing a pair of small silencers, the largest restriction is from the cats but they are part of the headers and an engine out job if you wish to replace them. A full exhaust system (down pipe back) will gain you around 8 to 10hp from a good system.
    As said above, select Dynamic in MMI once the cars up and running.
    Oct 14 2013
    Bay Area
    Thanks guys! Bummer to hear that you can't skip tracks with the steering wheel if you are using BT Audio. I'm still getting use to the audio controls being near the shifter vs the radio! I find myself reaching for the Climate button everytime haha
    I don't mind spending a few hundred dollars on used downpipes. The sound is what I'm primarily after but it'd be a much easier decision if they did indeed add some horsepower :/
    Jul 17 2015
    Colorado
    If you use an AMI USB cable to plug an external hard drive into the car for music (NTFS file system, each folder is it's own playlist) the steering audio controls work. They also work if you import items onto the car's jukebox. As far as I recall, it also works for skipping tracks on CD, too.
    The center console audio controls are strange to get used to, but once you've had them for a while you realize just how convenient they are. It's especially convenient if you have a passenger changing tracks, because they don't get their hands in your way.
    2014 Audi Q5 S Line
    IG: @MrHazeMyth
    Jul 25 2011
    I have the sports exhaust with AWE Non res DP's, but all i wanted was sound and it did accomplish that. Sounds great. Definitely worth the $$.
    Oct 14 2013
    Bay Area
    Quote Originally Posted by Beast View Post
    Hi Beast. That's great that it accomplished what you wanted on the sound front. Did you notice any performance gain? Anything from the butt dyno? Also, any sound clips available??
    Veteran Member Four Rings Gonzoe11's Avatar
    Feb 21 2012
    Q5 3.0T
    Bedford, NY
    Welcome Punisher. Congrats. More pics please. Any other mods planned?
    2015 Q5 3.0 TDI Ibis White | Premium Plus | Black Optics | S-Line + | Ray's Volk G25 | Continental CrossContact |
    2014 Q5 3.0T Glacier | Premium Plus | Eurocode F&R Sway Bars | BBS CX-R | Continental DWS -06 | StopTech |
    Veteran Member Four Rings LimaSierra's Avatar
    Apr 26 2013
    2025 Infiniti QX 80 Autograph, 2024 Chevy Tahoe RST
    KIAH
    Nice and congrats! Looks forward to seeing more!
    --Nate
    LimaSierraPhotography.com
    2014 Panther Black RS 5: Pics | Build
    Oct 14 2013
    Bay Area
    Thanks for the warm welcome guys!
    A few mods that I'm looking at are:
    H&R Sport Springs
    Axis Verde 20" wheels (cheap but I love the way they look)
    Intake
    Downpipes
    Anyone have any suggestions on intakes that give the same type of gains as the Eventuri but slightly more cost friendly.
    Feb 04 2010
    Ottawa, Canada
    H&R Sport Springs
    Intake
    Downpipes
    check out 034. they have some goodies for the RS5 that make a difference
    http://www.audizine.com/forum/showth...ts-amp-X-Brace!
    2014 Ibis RS5 w/ Ti. Package AWE Track Edition, ECS 15/10, 034 Transmission Mount, 034 Solid Sway Bar, 034 End Links
    2021 Nardo Grey RS7 w/Black Optics/RS Design
    2023 Daytona Grey RS6 w/BlackOptics/RS Design w/CTS Res Delete, CETE Lowering Mod, 034 Sways
    2025 Daytona Grey RS6 Performance w/AWE SwitchPath, CETE Lowering Mod, 034 Sways, etc
    Veteran Member Four Rings paul.karroum's Avatar
    Apr 06 2015
    2023 Lexus RX
    New York City
    Congrats on the Panther RS! Looks great.
    Sent from my iPhone 6s using Tapatalk
    Paul J. Karroum
    Brilliant Red B8 S5 6spd
    ST Coilovers, LED Interior lights, Extreme Spoiler lip spoiler, Stoptech BBK
    MSY3 | Mech Engineer | Chemist
    Instagram
    Previous:
    2004 Infiniti FX35 Silver
    2007 Audi A5 6spd Brilliant Red
    Aug 28 2015
    Illinois
    Hi guys,
    Since the catalytic converters are just after the headers, the downpipes only add volume/sound and not much gain, if any at all.
    On Dynamic Mode, the car will pump a little gasoline on downshifts: your "farting noise".
    I am able to skip tracks when I connect my Ipod.
    Prism Silver RS5
    Veteran Member Four Rings superswiss's Avatar
    Jan 07 2013
    San Francisco Bay Area, CA
    Quote Originally Posted by PedroRS5 View Post
    On Dynamic Mode, the car will pump a little gasoline on downshifts: your "farting noise"..
    That's a myth that was started by Jeremy Clarkson. The sound on downshifts is just the throttle blip. The "fart" sound on upshifts comes from the ECU cutting fuel to the engine, so that the rpm drop fast enough for the next gear.
    2019 AMG C63CS, obsidian blk, blk leather w/ yellow stitching, aero pkg, CF pkg I+II, 19/20 wheels, lighting pkg, multimedia pkg, heat&vent seats, AMG perf seats, digital cluster, night pkg, parking assist, driver assist, european delivery
    2013 panther blk RS5, Ti pkg, blk leather/alcantara, nav pkg, sport exhaust, driver assist pkg, rear shade, alu kreuz, ECS spacers 15f/10r, ECS tru-float rotors, ECS brake lines, Hawk HPS pads, european delivery (sold)
    Jul 25 2011
    maybe just a bit more throttle response because I guess the exhaust is a bit more free flowing but that is about it in terms of performance. I'll upload some sound clips soon
