Results 1 to 13 of 13
    May 02 2016
    Ft Lauderdale FL
    Brand new owner any advice would be amazing.
    So i just purchased a 2016 s3 prestige Florett Silver. The only option i didn't get was the black optic. After the break in period, i wanted to tune the car. I was thinking of going through apr, but after reading some things i'm not sure. And as far as the DSG tune goes, is it needed. Won't be keeping the car for longer than 3 years. So far i love it and am counting down the time until the engine is broken in. Quite the upgrade from a 2010 accord 5 speed. Any advice would be very much appreciated. Thanks so much.
    Nov 29 2005
    PHL
    I've had the UNI tune since January 2015, on my S3. It's perfect.
    I've had APR and REVO on other cars. They are all pretty close.
    For me, the fact that Uni is so smooth, and doesn't have ANY flaws, in combination with the fact that I can tune with my own cable = win.
    it's nice being able to just turn off the tune before dealer visits.
    and update the tune yourself, if there are updates.
    Good luck with her!
    2015 Audi S3 build thread just sold it!
    Cars & Coffee on Flickr
    Need to start a new thread for the new car, TTRS mk3
    Veteran Member Three Rings Food4Audis's Avatar
    Jan 17 2014
    Brea, CA
    For Lowering if you have magnetic ride, Id go with the lowering springs from Emmanuele Design. You will find a thread regarding his springs. Id take those over the H&R springs. Tuning..there are so many options and yes Id get the DSG tune. Enjoy!!
    2018 Graphite Metallic Prem Plus Q7 2.0T
    ACIE (Audi Club of the Inland Empire) Admin
    Instagram @food4audis
    2016 S3 / DPE Flowtech Wheeles / APR Stage 2 / Emmanuele Designs Lowering Springs / PURE carbon fiber accents / Neuspeed intake / Bull X exhaust / RS Grille
    2013 S5 V6 AG M580 Wheels / APR Stage 2 / AWE Touring Exhaust / Bilstein PSS10 / Eurocode Intake / RS Grille
    Apr 27 2010
    West Chester PA
    I have H&R sports with mag ride and they are excellent. Perfect height and ride. Every mode is perfect now. Stock springs are crap. I also have APR stage 1 and wish I had Uni if that tell you anything. Welcome.
    2015 S3 Daytona 1 Package | Unitronic Stage 1+ ECU | Unitronic Stage 1 TCU | H&R Sport Springs | CTS Intake/ Turbo Inlet | APR Turbo Muffler Delete | OEM Resonator Delete/ Flap Mod | Welded Magnaflow Tips | 19x8.5 ET 45 Forgeline ZX3R with 245/35/19 Conti DW | 20% Tint
    Stage 3 Forum Advertiser Four Rings ModdedEuros's Avatar
    Aug 23 2014
    Philadelphia, PA
    Would def check out UniConnect+ and flash Unitronic software. Did it to our GTI and S3 and love it. No need to go to a dealer anymore to flash
    Our S3 videos will be rolling out in the coming months but if you want to check out how it works, you can see it done on our MK7 GTI which is also on the MQB platform
    https://www.youtube.com/playlist?lis...1L2OWtcQigzvoQ
    Modded Euros
    Your Source for Audi & VW Performance Parts
    www.ModdedEuros.com
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    I have the APR Stage 1 ECU and DSG tune. It's smooth and the power increase was impressive. I am shocked how this car is with very little more than a tune. Changing the shift points with DSG tune helps a lot for D mode daily driving. It keeps the car in the powerband and throttle response is better. It also supposedly increase clamping pressure of the clutch packs for the high torque version of the tune.
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    those with the dsg tune, any significant increase in fuel consumption under normal driving?
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    Aug 28 2013
    Quote Originally Posted by diztek View Post
    Mine is about the same.
    May 02 2016
    Ft Lauderdale FL
    With any of the tunes, is the dsg tune necessary. I essentially live in the city so not sure i'm going to swap out suspension parts. Can the dsg handle the tunes without it being upgraded?
    Oct 30 2012
    Arizona
    I wouldn't say its "necessary" for stage 1.....but if you start other mods like DP and Intake, its always nice to have the DSG tune for faster, crisper shifting.
    May 02 2016
    Ft Lauderdale FL
    So the stock dsg can handle the upgraded 60-100 hp and torque?
    May 13 2008
    MQBs
    San Francisco
    Quote Originally Posted by Baggio View Post
    Same here, although nudging the gas up to 93 with e85 seems like it's using more fuel.
    Quote Originally Posted by davek2787 View Post
    Stage 1 is most likely fine, but Stage 2, I'd say a firm no.
    Quote Originally Posted by A20V200 View Post
    Personally I think it's more about clamping force and shift points.
    On GIAC Stage 2+, having the DSG tune to go with it cured the slipping. It was an uphill battle with GIAC, but in the end I'm happy with their product.
    Past: B7 S4 Avant | Glacier White 8V S3 Build ig: @harithalbadri
    Mar 22 2016
    Las Vegas, NV
    +1
    The DSG tune is a must imo.
