Results 1 to 21 of 21
    Established Member Two Rings FU5E's Avatar
    Apr 11 2012
    2013 Audi A4, 2008 Porsche Carrera, 1956 Packard Executive
    Troy, MI
    looking to join the newer audi crowd
    I am in the market for a B7 or (B8 possibly) as a DD. I come from the B5 platform which is staying. I prefer a manual however there is one for sale near me I really like that's an auto. a bit high on miles but depending on maintenance id consider. I'm concerned mostly with traveling across the country for one and finding it has the oil consumption issue. How is the reliability of the autos and how do I try to protect myself from the 2.0t oil issue Carfax only shows so much.
    __________________________________________________ __________________________________________________ ___________________________
    2013 Audi A4 2.0T APR Stage 2
    2008 Porsche Carrera - APR tune, Tubi Exhaust.
    2005 Audi A4 TQM 6 speed. K04 Stage II (sold)
    2001.5 Audi 1.8TQM A4 GT2871 elim. unitronics 440cc, vibrant 500hp intercooler, custom 3" mandrel bent exhaust..... (sold)
    https://tweetlerperformance.com/
    Senior Member Four Rings JDillon15's Avatar
    Jul 11 2014
    Chicago, IL
    I would definitely avoid the CVT (only on FWD cars, so if it's Quattro, you're good).
    Maintenance is relative - I don't think it's too bad, but I do a lot of work myself. To each their own.
    I would also avoid early B8's (2009 & 2010) as many of those had oil consumption issues.
    Moro 06 A4 Quattro| Totaled
    Silver 06 A4 Quattro | Sold
    Legal Advisory for Mec's Cabinet Dec 2014-Present
    *Advised the shit out of legal situations
    *Succeeded like never before and rose to the top like a phoenix from ashes
    *Can Take a ZJ with a poker face
    Senior Member Three Rings Mlambrecht17's Avatar
    Aug 11 2014
    Minnesota
    My b7 has been reliable. I have an 06 2.0t auto, it does have the torque converter issue so if I could do it again I would buy a manual. Also cam follower and timing belt are your main priorities for maintenance. Timing chains, pcv, and coil packs are another thing to consider and watch for. I'd recommend getting an s line or an 08 body because of better styling in my opinion, also try to find one with bixenons. That's the thing I regret most about my b7. Your best bet is to buy from an enthusiast because often times they seem to know what they're doing.
    Feb 08 2012
    Dallas, GA
    Quote Originally Posted by Mlambrecht17 View Post
    Same here. I have been pretty pleased with the 2.0T quattro except for the Tiptronic transmission. I'm still not sure how I'm going to handle this one.
    B7s have cam follower, coolant flange, vacuum pump, engine mount issues. B8s (early ones anyway) seem to have oil consumption and chain tensioner issues. Personally, I liked my chances with the B7 better. Plus, I like the lines of it a lot.
    Apr 11 2012
    Troy, MI
    I don't consider it a proper audi if it's not quattro lol, looking at an 08 S-line 6 sp. Carfax shows 2 owners 2 service hist. Entries and an also an 09 auto has stg 3 Apr. Miles are high too. I love the 08 black/black 6 sp. Just wish I knew more service history
    Veteran Member Four Rings Copen-cisco's Avatar
    Sep 06 2013
    B7 Audi A4 Avant+ B7 Sedan and '69 912
    Dublin, CA
    We have two black B7's - dont get a black car :)
    Kristian
    l Audi A4 2007 Avant l 2.0T TIP l Custom Stage 2 tune l IE HPFP l 034 HFC l 034 TIP l Rev Snub mount l 034 motor mounts l ST Coilovers l RS4 rear sway bar l Milltek Cat-back Resonated l S4 Recaro l RNS-E MKII l 19" Peelers
    Jul 11 2014
    Chicago, IL
    Quote Originally Posted by FU5E View Post
    Be very careful if you buy a 2008 - They came standard with the s-line appearance package and many people will tell you it is an s-line when it is not.
    There are a couple giveaways:
    won't have s-line on the steering wheel
    won't have s-line on the door sills
    has a 4-spoke steering wheel opposed to a 3-spoke
    There may be a few others I'm forgetting.
    Apr 11 2012
    Troy, MI
    Quote Originally Posted by Copen-cisco View Post
    Excellent advice, my big turbo b5 is black I should know better. Lol
    Veteran Member Four Rings QuattriumMT6's Avatar
    Aug 24 2013
    1991 Toyota Mr2 Turbo
    Stockton, CA
    Quote Originally Posted by JDillon15 View Post
    won't have s-line on the door trim
    Yep. Door sills should have s-line on them. Wheels should be 18" either 5 spoke or 18" multi spoke of Titanium Packaged. I can't remember if Color DIS was just an option or if it came standard on S-lines (please correct me if I'm wrong).
    Senior Member Three Rings 67Twisty's Avatar
    Jul 11 2015
    North Carolina
    I have an '08 Sline with the red DIS. Doesn't bother me, but color was obviously not standard. I have the RS4 pedals which also came standard with the Sline package in '08. You can't always rely on the wheels as they may have been changed by PO. Check the spare for clues if the original 18" are missing. Red sport shocks should be visible through wheel well unless PO went with aftermarket suspension. Lower front fascia on Sline bumper is different on true Sline vs the appearance package (fog light inserts are black rather than body colored). Oil consumption won't show on Carfax unless dealer took corrective action. The problem ran through the 2011 model year, but was worse for B8s on 2009 and 2010 as stated above.
    Andy
    ‘17 Q7
    ‘07 Avant 6MTQ
    ‘03 525i Touring
    Jun 17 2013
    jersey city nj
    I have the Tip with 225k miles on it and the out of it daily. Im gonna it till the transmission drops to the ground. Then another one and it some more
    Veteran Member Four Rings dalmation53's Avatar
    Aug 20 2013
    Miami
    OP get a B7.. B8's are meh.... the Quality materials on the B7's is soooo much better. try to find one with timing belt already done if it has more then 100k. cam follower, DV valve and PCV are crutial to replace before modding.
    Ivan
    Jan 06 2009
    If you prefer manual then don't settle for an auto. I did and hate it. It's my first auto car in 15 years and I hate it. Actually my B7 just sort of fell into my lap at a super deal so it would have been dumb not to buy it but I still hate the auto. I don't know how people drive them and actually enjoy it.
    B6 2.7t BEL tuned by Bische
    B7 2.0t
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    Owning all 3 I can tell you they are very different cars. The b7 will "feel" more like your b5, smaller and an interior pretty much unchanged from 2002, the first gen fsi 2.0 is so so, and the autos suck, the b8 is completely different from a b5/6/7, longer wheel base and a way better tfsi 2.0t (minus the oil consumption but the b7s have that issue also) the manual is very good, the interior is much better on the b8s imho, but honestly go test drive them for yourself, I think you will feel that the b7 is already 10ish years old.....
    Jun 17 2013
    jersey city nj
    Quote Originally Posted by ADCS View Post
    I the tiptronic when Im ing is NYC traffic
    Jan 06 2009
    I hate the auto the most when stuck in traffic....Stop changing gears unnecessarily!! lol. And the sport mode is a joke. I much prefer my manual B6 when stuck in traffic....needless to say the B7 is in 'manual' shift mode 95% of the time.
    B7 2.0t
    Senior Member Three Rings johnruan's Avatar
    Oct 01 2014
    Audi Q5
    chicago,il
    B7 is 10yrs old car. If you have access to E85 gas and like tuning your car I would look for b8.5 2013. Only some of those models compatible with E85 and with E85 tune that thing is a beast.
    Apr 11 2012
    Troy, MI
    Quote Originally Posted by johnruan View Post
    I'm not up to date on the B8 but since E85 is part of my b5 build that's something I might consider searching out. Drove a b7 true s line before and liked it just didn't make sense then. DD a jeep grand cherokee now auto, big and slow.
    I plan to keep looking under $15k though so it doesn't interfere with re-building my b5 the way I want it. Kinda keeps me in the B7 model.
    Aug 11 2014
    Minnesota
    You can find a nice titanium A4 for under 15k. Those imo look the best for b7s.
    Veteran Member Four Rings B-Time's Avatar
    May 03 2009
    East
    Quote Originally Posted by 67Twisty View Post
    Incorrect. There is only one S-line bumper. All 2008s had an s-line bumper.
    Oct 23 2015
    Australia
    hi Fu5e,all good advice above and Ive been trying to work out how to purchase a B8 eventually and evaluate the oil burning issue before purchase...
    (but only just started modding my B7 lol )
    But if you go for the B7 and and service history is not fully documented, ask the seller to pull the HPFP and if its got issues he pays/you leave,otherwise...maybe you pay or split and purchase at the agreed price.
    With the oil issue though,its tough.Its impractical to test the car for soo long to evaluate that.So unless its documented that its been fixed or that it has an issue-I just haven't worked that one out yet ?? -Maybe full Audi service history will guide you...otherwise go for oil-safe 2013+ ( cost a bomb here but cheaper in US ) Good Luck !
    Heidi - Audi A4 B8.5 T Q S-line,7 DSG,-Ibis white- E-tuners stage 1 ecu/tcu, lowered on Vogtlands ,19"rotors,quad exhaust,S4 diffuser,full Maxton skirt kit,AEM intake,10" Android auto screen
