Results 1 to 4 of 4
    Sep 18 2013
    Cleveland
    Looking for leads on a vibration
    Hello, I don't post here much but I thought I'd go wide on my search for a cause to this vibration.
    So, I got new 225's fitted this morning in place of the 205 snows (finally!). I had been feeling a vibration at mid-speeds and chalked it up to some bearings and horribly choppy winter tires. However even after the new tires, it's still there.
    It feels almost like sunroof buffeting and I mostly feel it in my butt. It vibrates the armrest in the up position. It's wheel-speed dependent as coasting in neutral doesn't affect it and neither does engine rev.
    In the last few months I've had a used rear diff installed in place of my burnt original (vibration slightly lessened), two right side wheel bearings (slightly lessened again) and these tires (biggest difference).
    Where should I be looking for this?
    99.5 a4 1.8tqms Brilliant Black
    APR Stg 1, 710n, A8 brakes, OEM Xenon Kit, 034 PCV, 034 street density mounts, fog light mod.
    Mods on the table: too many to list.
    Senior Member Two Rings MarcRogers's Avatar
    Jan 18 2016
    PA
    Center support bearing? I was going to say unbalanced wheels but that's can't be in considering you had this problem with both sets on.
    Veteran Member Four Rings GOODBYNAAIR's Avatar
    Nov 17 2011
    1973 MG Midget, 1995 F150 302 v8, 2007 A4 Avant 3.2 v6, 2014 Odyssey EX-L
    Fredneck Maryland
    me things Bent wheel OEM wheels are soft.
    SOLD the GOINHAM A4 ---> GT2860 Project
    Senior Member Three Rings ElSabio182's Avatar
    Feb 26 2006
    Boston (formerly Rochester NY)
    So the issue is present on the old tires and the new tires...but both sets of rubber are mounted on the same wheels? Maybe you're way beyond that in your diagnosis, but just to state the obvious: get your balance/alignment verified by a second shop and check the wheels for bends? One or two wheels with small bends would certainly fit the symptoms you're describing.
    TOTALED: 2001 A4 2.8L QST - RIP, April '07 (carnage pics)
    TOTALED: 2000 A4 2.8L QSM - RIP, Sept. '09 (Totaled...really??)
    TOTALED: 2001 A4 2.8L QSM - RIP, Aug. '13 AGAIN?!
    Current: 2001.5 A4 1.8T QSM - A8 front brakes / KW V2s / front-rear 034 swaybars & endlinks / JHM DTS / Valeo clutch / S4 tie-rods / S4 skirts / Sport Cloth seats
