Results 1 to 6 of 6
    Apr 25 2016
    UK
    A6 C5 springs - are they that hard to find? HELP!!
    Hi all,
    I've been given a 1999 4.2 Quattro that's been off the road a while. Everything else is coming along nicely and once this hurdle is behind me I should be able to get the MOT done and finally drive it but....
    Both front springs are snapped; I've got them off and ready to replace but I'm having real trouble finding the right springs. The ones that came off were green/yellow paint marked so I want to go OEM and replace like for like if I can. It has air on the back and I believe sports sus on the front?
    Does anyone know of any specialist suppliers in the UK that might be able to help with sourcing these? I'm having no luck at all...
    Thanks,
    Si
    Veteran Member Three Rings carmudgeon's Avatar
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    They're not hard to come by in the States, I just a ordered a new front pair for my 2002.
    Previous vehicles: 2012 TTS Roadster - 2017 Golf R - 2002 S6 Avant - 2013 S4 - 2008 Subaru STi - 2007 Mazdaspeed3
    Established Member Two Rings CAL4.2's Avatar
    May 21 2014
    2001 Mustang GT 5-Speed
    Best luck would be with Ebay to find used front springs (A6 4.2 or S6 type) or you could take the opportunity to put on aftermarket such as H&R or Eibach full spring set if you don't mind a drop in ride height. That would likely require you to upgrade your shocks/struts which you may not want to do.
    Current:
    FOR SALE '02 Audi A6 4.2Q Tip (98k mi) Sport & Prem Packs, 18z 6Piston Fr Brakes|Bilstein|RS6 18x8 ET35|A/S 245/40|Gruvenparts)
    '01 Ford Mustang GT 5-Speed (135k miles):Coilovers & stuff (Bilstein|Stoptech|Porterfield|Maximum Motorsports|FordRacing|Michelin PSS)
    '03 Honda S2000:Totaled
    '05 Honda S2000:Sold
    Veteran Member Three Rings suth31's Avatar
    May 16 2014
    2002 A6 2.7T 6-speed, 2003 350Z supercharged 6-speed, 2001 Hayabusa, 1995 Bronco
    massena, ny
    wish I could help you out. I have an entire front and rear set of springs with struts off of a 50,000 mile 4.2 a6. But they are heavy and would cost a ton to ship to the UK I am betting
    Apr 25 2016
    UK
    Cheers Suth. If I have no luck in a few weeks I might take you up on it - depending on the cost... Have a specialist trying to get hold of the pair as I type.
    I can find a variety but none with the right paint marks which is suppposedly crucial.
    Oct 23 2012
    1995.5 S6 Avant
    Kansas City
    Springs are specific to a chassis, gross vehicle weight rating, and type of suspension, that's what the color coding indicates. Different springs may physically fit but the car won't handle properly, or at least won't handle as intended.
    If you're trying to order new springs from a dealer it might be easier to look it up for the suspension code on the build sticker.
