Results 1 to 8 of 8
    Senior Member Two Rings grrrrrrr's Avatar
    Mar 27 2008
    valencia, california
    Audi Genuine Ibis White Touch Up Paint Code LY9C
    Anyone used one of this? Any advice for touch up paint.
    Veteran Member Three Rings carlosvjr92's Avatar
    Nov 25 2015
    Miami, FL
    I've heard good things about dr color chip. Tried using it over the weekend though and I guess there was still wax over the chip and it didn't work as well as it should have
    2018 RS3 (Cumulus Blue) - APR Stage 2 || APR Intake || APR Downpipe
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Definitely use Dr. Color Chip. I do detailing as a strong hobby/side job and I always order it up when working on cars. Customers are amazed at how perfectly it matches and blends.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Mar 27 2008
    Quote Originally Posted by pdqgp View Post
    do they use oem paint? easy to use?
    Sent from my SM-N920I using Tapatalk
    Nov 10 2014
    Apex, NC
    i recommended Dr Color Chip to my cousin based on this forum and he said it was horrible and paint didn't match.. he has a GS350 navy blue'ish color .. maybe white will be a better match
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
    Nov 25 2015
    Miami, FL
    Quote Originally Posted by grrrrrrr View Post
    From what I can tell they do. When you order from their site you have to enter the year, make, and model of your car along with the color
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    +3 on Dr. Color chip. Used it on my S4 and Tacoma. Easy to use and great results. My wife has done some on the Tacoma, and she commented on how much better it was than the factory junk.
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
    Jul 10 2015
    SATX
    I used a company called touchupdirect purchased through Amazon on two cars (just search your paint code) and had great results. Decent ammount of paint in each tube and has not clumped up despite numerous openings/uses.
