Results 1 to 29 of 29
    Established Member Two Rings ljbx4's Avatar
    Feb 13 2011
    LI, NY
    Haven't posted in a while My BAT 01E
    Hey guys haven't posted my car in a while for those of you who haven't seen my previous threads it's a 03 a4 BAT on Eurodyne 5858 turbo 01E trans 565AWHP daily driven now for about 15k miles on D2 Racing coilovers enjoy!!!
    Senior Member Three Rings B6ayfour's Avatar
    Jun 21 2015
    2014 S4 6MT, 1989 535i5
    LI, NY
    Those rims..
    14 B8.5 S4 6MT Current Daily
    01.5 B5 S4 6MT SOLD
    04 C5 A6 2.7T S-line SOLD
    02 B6 A4 1.8TQM DG Sport Package SOLD
    Motoza Stage 2, USP front end conversion w/ Cupra lip, S4 rear bumper, 18" BBS CH, OBX catback exhaust, Genesis 380cc injectors, PSI concepts test pipe, Stratmosphere Hyperboost DV, CX Racing FMIC, Forge TIP, S4 BBK, etc...
    Dec 19 2011
    Colorado Springs
    ..In for build / engine specs!!!! Looks dope man! lovin the turbo manifold set up!
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    what fuel made 565awhp, i know its not pump
    . . .and whats the et & trap speed? since that's all that really matters
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Veteran Member Four Rings Wet0willy01's Avatar
    Nov 17 2008
    05 A4 USP, 00 S4, 01 A4, 16 A3
    Glad to see its hold in up
    Feb 13 2011
    LI, NY
    Pump 93 and some water meth melted disc to flywheel on the two step last attempt at the track it's my daily also so until my e30 build is finished I won't be taking it to the track yet
    Jan 24 2008
    Pennsylvania
    Looks good, and damn those are some numbers! Must be a blast. Looks like you have the Sportec replica front bumper and had some issues securing/fitting the driver's side corner?
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
    Feb 13 2011
    LI, NY
    No it's just hanging cause a brick fell off a truck and smashed the bumper and ripped the bottom bolts out :(
    Apr 01 2011
    B5 on jack stands
    charlotte
    what kind of tune do you have? injectors? cams? stroked?
    powered by
    Hot Boi parts
    Feb 13 2011
    LI, NY
    IE street strip cams 1000cc injectors IE rods stock piston custom tuned with Eurodyne
    Apr 01 2011
    B5 on jack stands
    charlotte
    that's awesome! everything very well done
    powered by
    Hot Boi parts
    Oct 30 2006
    B8 A4 Avant 6spd
    I think our cars would be a good race =)
    -18 718 GTS
    Aug 26 2005
    Quote Originally Posted by B6ayfour View Post
    Those rims..
    Wheels, not rims...
    Vorsprung durch Technik
    Aug 26 2005
    Quote Originally Posted by ljbx4 View Post
    Really sharp looking Audi! Must be a real lag monster.
    Feb 13 2011
    LI, NY
    Full spool 43 psi at a little over 4K rpm
    Nov 17 2008
    .48 AR must really make a difference
    -Andrew
    2005 Dolphin Grey Ultra Sport
    630AWHP HTA3582R 1.8L 93+ Meth
    Before camber and tire stretch, there was horsepower and performance.
    Jul 12 2016
    Rochester, MN
    holy bananas! bet that's a fun little daily! any vids of the car??
    Veteran Member Four Rings PreciseD's Avatar
    Feb 05 2014
    Stock pistons? How long do you think that will last?
    ----- My EFR 7670 Build Thread ----- "The thing about quotes on the internet is you can not confirm their validity" - Abraham Lincoln -----
    Nov 17 2008
    He had 15k on it a while back.
    -Andrew
    Feb 05 2014
    Quote Originally Posted by Wet0willy01 View Post
    With this setup? I thought he just finished it a few months ago. I have a hard time believing stock pistons are going to hold up to 43 psi and that much power.....
    EDIT: Yeah just saw it said 15k miles of DD use.
    Jan 24 2008
    Pennsylvania
    It defies logic, in a very good way!
    Feb 05 2014
    Quote Originally Posted by Turbavanttro View Post
    Yes it does.... I've seen these disintegrate and much lower pressures and power....
    Veteran Member Four Rings gtsingh91's Avatar
    Sep 27 2008
    2005 A4 1.8TQM, 2001 A4 1.8TQM, 2007 350Z
    Long Island, NY
    Where in LI are you from? I haven't seen your car around
    Instagram: @_vishis
    2001 Audi A4 1.8T Quattro - 5 Speed - Silver
    2005 Audi A4 1.8T Quattro - 6 Speed - Revo Stage II+ - Light Silver Metallic
    2000 Audi S4 2.7TT 6 Speed - EPL Stage II - Hibiscus Red Pearl SOLD
    Feb 13 2011
    LI, NY
    Suffolk county Islip ronkonkoma and just did anther oil change 20k miles strong water meth is the key to not melting the Pistons 700hp is the highest I have seen a stock piston hold so I should be fine
    Nov 17 2008
    What size nozzles are you running?
    -Andrew
    Feb 13 2011
    LI, NY
    375
    Nov 17 2008
    How many 375 nozzles are you running?
    -Andrew
    Feb 13 2011
    LI, NY
    2 one on the intercooler one in the throttle body
    Jun 21 2005
    Milton, Ontario
    What mixture are you running for water meth? Very big numbers - good work!
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
