Results 1 to 23 of 23
    Aug 24 2013
    Ballston Spa, NY
    Engine swap on S4. Anything else?
    I have a new 4.2 motor waiting to go into the car with 121k miles. The motor includes a new clutch and flywheel. It's going to get JHM headers. new mounts, supercharger, and some other stuff. I do not plan on taking the gearbox out. Is there anything back there that would be a good idea to replace while I have access? I would like not to have to take the motor out for another 100k miles. There's a few things in the front that I already know have seen better days such as a couple of coolant hoses that are really soft from oil leakage. I have no idea what's behind the engine, therefore, I don't know what to expect in terms of which parts are likely worn past their usefulness. Also, are there any upgrades that would otherwise be impossible to install besides those listed. Thanks
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    timing this is priority with this engine.
    Senior Member Three Rings hkdolphins's Avatar
    Dec 03 2014
    Noggy Avant, B8.5 Allroad
    SF/CA
    Quote Originally Posted by atmetal View Post
    new engine - do you mean those ebay new one ask for 10K?
    B6 Noggy Avant, B8.5 Allroad
    Aug 24 2013
    Ballston Spa, NY
    Quote Originally Posted by hkdolphins View Post
    Yes. Why do you ask?
    Veteran Member Four Rings Lucca M's Avatar
    Jan 17 2014
    Past Bmw M3 coupe Euro 1998
    New Jersey
    Check steering rack for play and leaks. Power steering hoses too
    2004 Black RS FAUX B6
    JHM LWFW, Stage 4 Clutch, Short Throw Trio, IM Spacers, JHM 91,
    034 Street Density Engine, Transmission, Snub Mount & Zero Tolerance Bracket, Rear Diff Inserts,
    PowerFlex Diff insert, Custom 2.75'' Akropovic exhaust, Cross Drilled/Slotted Rotors,
    Rns-E, B7 steering wheel, Schmidt VN Line 3 piece 19x10, Airlift Performance Suspension, Recaro Sport Seats, Ecodes and many many more...
    Insta: luccamentone
    Dec 03 2014
    SF/CA
    Im also debating to get one. I feel my engine still strong with ~ 1.25Q oil per 1K miles. it's not my daily drive and i plan to keep it as long as it can.
    I think this new engine is a good choice if i want to keep my car running for another 100K miles
    Apr 18 2012
    1995 Toyota Land Cruiser (FJ80/FZJ80)
    Central Texas
    if i were going through the trouble of swapping a new engine in with a high budget (>US$20,000), i would budget for:
    • refinishing the cylinder bores and new piston rings, if not sleeving, and do it first because it would tell me wether the rest of the engine is worth the time
    • at least the timing tensioner components and cam adjusters
    • JHM heads
    • the upgraded JHM belt tensioner and lightweight pulley (i'm not sure about a LW clutch, the momentum of the heavy one is valuable when shifting)
    • 4:1 center diff
    • proper oil temperature and pressure sensors, with accompanying displays
    • engine mounts
    • clean the starter solenoid, or just replace
    • water pump
    • AC compressor bearing (it will need a new dryer, too, since the system has been opened)
    • inspect the power steering pump, or just replace
    • oil check valves and valley pan gasket
    • all hoses: coolant, hydraulic, vacuum, emissions, crankcase, everything - maybe in fancy schmancy silicone or whatever
    • all plastic coolant and vacuum fittings
    • most gaskets
    • most sensors
    then, after all that, would i decide wether to spend the money on a supercharger. i'd hate to spend the money on a big power upgrade and then spend the next two years fixing small components that are annoying to get to.
    - emilio
    Veteran Member Four Rings sandspeed's Avatar
    Mar 13 2007
    05 S4 Avant Abt AS400 clone, 14 SQ5
    Sunny UK
    What was wrong with the old engine?
    -Tim
    Aug 24 2013
    Ballston Spa, NY
    That was my idea as well. When I got the problem the current engine has, I was pretty certain it was timing related. At 121k miles, I figured the clutch should be done too. The only local shop I would trust to do the job correctly quoted me 8 or 9 thousand. I almost bought a new car. In particular, I wanted a CTS-V. But a friend sent me a link to the ebay engine. I found that if I do the work myself, I can get several jhm upgrades in addition to the new engine for about the budget I had for the CTS-V. I would have had the shop do the timing chain, but for something as easy as a motor swap, I'm willing to save money and do it myself. After it's all done, it should be much faster than a stock CTS-V too.
    As for what was wrong with the current motor, I wasn't there for it's failure. I know it had been making a ticking noise for a while, which I guessed to be a timing chain component. I had left the car with a friend who drove it only to experience a sudden failure. I don't remember exactly what he said, but the aftermath was 5 cylinders were misfiring. There was also camshaft sensor codes. I believe the 4.2 is an interference engine, so there's no indication of timing being messed up too badly if at all, but it's definitely related to the timing system.
    Nov 03 2011
    All Over!
    With the amount of work you intend to do, especially the installation of JHM headers, I would strongly recommend pulling the motor and transmission as a single unit, then separate on the bench,
    The bell housing bolts aren't easy to get to in the bay, and JHM long headers are easiest to fit and feed into he car with the gearbox attached.
    1986 Type 85 Audi 90 quattro
    Dec 03 2014
    SF/CA
    My engine has ticking noise (at bumper side) sometime when cool start(not each time) too, and went away after it. I didnt notice its related to timing, which engine component should related to?
    I was also wonder the ebay is a 2008 brand new engine, even it will all manufacturer updated parts, may any component has aging issue even it's brand new?
    Mar 13 2007
    Sunny UK
    So the cylinder bores haven't been inspected?
    -Tim
    Aug 24 2013
    Ballston Spa, NY
    Quote Originally Posted by sandspeed View Post
    Are you referring to the old engine or new engine? The answer is no in both cases. Though if you were asking for the new engine, I would ask why I should have the cylinder bores inspected?
    Feb 18 2014
    Arizona
    I'm guessing he meant the old one. If it's just the timing that's bad and cylinder bores are still good then 121k miles isn't too bad, if there's no scoring then I'm sure someone will want to take it off your hands and fix it for their own use
    Mar 13 2007
    Sunny UK
    Quote Originally Posted by 2004B6S4 View Post
    Exactly. Finding a good donor short block for rebuilds is sometimes a challenge.
    -Tim
    Veteran Member Four Rings badger.'s Avatar
    Mar 31 2014
    '18 RS3 | '05 S4 Avant
    KY
    *timidly raises hand*
    '18 RS3 Glacier White: DS1 Stg 2 | Wagner EVO1 IC | 034 4" Turbo Inlet | 034 4" Intake
    '05 S4 Avant Brilliant Red: JHM Tune | JHMv1 Headers | Fast Intentions Catback | Ported IM & Spacers | JHM LWCP | JHM ATF Cooler | Thor Skid Plate | Koni Yellows | Apikol Rear Diff | JHM LW Rotors | AudioQ 1200D w/Dual 10" CVRs
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    10k? wtf
    drop your car off at your local audi tuner, have them put, a 2.7 w/stk, will have a way better car than what you have now.
    or
    build rebuild your engine with new rods, overbore higher compression pistons cams and a tune
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Aug 24 2013
    Ballston Spa, NY
    While I appreciate the input from everybody, I was looking more for maintenance suggestions. I wouldn't say preventative maintenance as that implies use of the maintenance schedule, but corrective maintenance would also be inaccurate. Except for the new engine, this car has 121k miles on it. Certainly there are wearable components accessible only when the engine is removed that might be good to replace before the new engine goes in. These might include the slave cylinder or throw out bearing, which I recently figured out myself because everyone here wanted to suggest additional performance stuff. I know a sort of asked for upgrade suggestions, but this was in the context of the accessibility granted by a removed engine. Regarding the component replacement, I don't know how much wear these components receive so I'd like to know what would actually be a good idea and what would be mostly just a waste of money.
    Apr 18 2012
    Central Texas
    i think i gave you plenty of an answer. you should take care of a lot of stuff before even considering spending the money on a supercharger.
    Quote Originally Posted by GrapeBandit View Post
    worst advice ever - the guy is looking to reduce his long-term maintenance. i'll take the oil consumption over semi-annual head gasket replacements, not to mention the joy of a V8.
    - emilio
    Veteran Member Four Rings dsgray16's Avatar
    Jun 11 2013
    I would upgrade the timing wear parts with JHM upgraded replacements even though it's a new engine..
    Also, as others have said, pull the trans with the motor for header instal.
    Events: Time to register for Avantoberfest 2018!: www.avantoberfest.com
    Instagram: Audisport_Wagon
    Cars: Full B7 RS4 Avant swap http://www.audizine.com/forum/showth...S4-Avant-Build
    B7 RS4 sedan in Phantom Black - just a clean OEM+ daily driver
    Aug 24 2013
    Ballston Spa, NY
    Quote Originally Posted by emilio View Post
    worst advice ever - the guy is looking to reduce his long-term maintenance. i'll take the oil consumption over semi-annual head gasket replacements, not to mention the joy of a V8.- emilio
    Well put. I had a 2.7T in an A6 once. Never again.
    Quote Originally Posted by dsgray16 View Post
    I thought about this. JHM doesn't sell the reinforced guides separately but they'd probably be willing if I called and asked. I was dubious on the benefit since they only have one of the guides reinforced and even then, it's still made of some plastic. Ideally, I would get all-metal guides. It would be nice for the timing to be indestructible even over hundreds of thousands of miles. As for the mechanical adjuster, that is already in the works. Are there any other timing upgrades that I'm unaware of?
    Jan 29 2010
    north ga
    You don't have to get the guide from JHM......they just use the guide from the RS4. You can get it yourself from ECS, GAP, etc.... That's really the only metal guide that fits the S4, the others are slightly different so you will still have to use plastic guides for all but that center one
    Jul 23 2007
    10k? wtf
    or
    my previous s4 is b5 maybe faster with stg 3 just only v8 give u sound like Beethoven symphony
