Results 1 to 30 of 30
    Senior Member Three Rings t3han0maly's Avatar
    Aug 31 2008
    2013 MB GLK350, 2016 Nissan Frontier PRO4X
    Atlanta, GA
    Michelin Pilot Super Sports 92Y or 96Y
    Hi All,
    I searched but didnt find an exact answer. At 10800 miles my stock Continental are nearing the end of their lives and like everyone else I'm wanting to go for the PSS'. On doing a quick search I found 2 tiers, 92Y and 96Y.
    I know what the differrence between the two is (weight rating)
    92 = 1,389 lbs
    96 = 1,565 lbs
    I was curious which version folks are running. Why did you pick the one you did? I'm fairly certain I can get away with the 92Y.
    Bonus question, is it possible to fit a 265 wide PSS on the stock peelers? I've read the PSS's are more "square" than the Continentals were so the 265 may be too wide?
    Advice and thoughts are appreciated.
    2014 S4 P+ 6MT Glacier White Metallic/Black - MMI + Sport Diff + B&O + 19" Peelers
    The Ex's: 2013 A4 P+, 2009 Mustang GT (Whippled), 2008 Audi A3 (GIAC Stg I), 2003 Corolla (TRD S/C 16PSI Road Course Car)
    Apr 11 2012
    some tireshops won't install 92y on a B8 s4, that should tell you something.
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    It would fail tech spec at a track day to. I know the half mile shootouts I've done check tire load rating against factory.
    Sent from my Nexus 6P using Google's ProjectFI
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Aug 31 2008
    Atlanta, GA
    Quote Originally Posted by will13k7 View Post
    Quote Originally Posted by theswoleguy View Post
    Thats good to know. I guess I know which one to get then.
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    From tire exploding
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
    Established Member Two Rings paulo6's Avatar
    Apr 17 2014
    Ford Explorer, Honda Element. retired a Cobb Tuned E60 535xi for the S4
    Ann Arbor, MI
    Belle tire installed 92Y on mine 10k miles ago - no issues. I'm still alive
    Paul. S4 Prem+, Grey, Optic Black, Sport Diff, Nav+, BO
    Jul 21 2004
    South Florida
    Definitely a bad idea. Everything will be fine...until it isnt. Get the 96.
    Mike
    2018 Audi S5
    Gone-
    Jan 09 2008
    Winnipeg
    What's everyone's thoughts on the speed rating? I had one tire shop refuse to sell me tires for my S4 because the tire didn't have the (Y) speed rating, they were W. I wish I had thought to ask how that policy works for winter tires. I went to a different shop (same chain) and they had no issue with it.
    Just wondering if anyone here has an opinion on running something less than (Y). My car is never going to see 270km/h which is what a W is rated for and the (Y) is for over 300 km/h...can the B8 S4 even reach that assuming you disabled the electronic speed governor?
    Veteran Member Four Rings Bruno_s4's Avatar
    Mar 12 2010
    Richmond Hill, Ontario
    Yes my tire shop definitely recommended the 96Y. Same weight anyways....
    2010 Sprint Blue S4 DSG | Sport Diff | GIAC Stg 2 + TCU | S4Matty ported charger/throttle body | PLM | AWE Touring + Resonated DP | ECS Kohlefaser | H&R Clubsport RSS | Renn Motorsports RS-51 19 x 8.5 | Super Sports | Stoptech ST60 BBK | Endless RF650 | 034 X-Brace | CR-15 | 034 Rear Bar | 034 Rear Diff Inserts | ENLAES Spoiler | Driving Passions Diffuser| RS4 Grill | STVBEK Front Lip | Clear Corners |Philips Ultinon 6000k | G6 6500k LED Fog | FBSW | JL Audio 10W6v2 | 500/1v2 | LC2i
    Aug 03 2014
    Queens
    Quote Originally Posted by eurotic View Post
    With some tunes you can see above 300km.. You can run something less than Y.. Winter tires are rated lower and people run them.
    After a certain speed it becomes dangerous (assuming you'll go above the speed the tires are rated for), the structure of the tire wasn't made to go above it. Usually they're rated at sustained high speeds where tires start to build heat and start to flex outward/distort causing performance problems.
    If you do a quick burst.. You'll be fine going above the rated speed for a quick second. But it's really rated for sustained high speeds.
    Previous
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by DGVR6 View Post
    Realistically my car will never hit even the limit of the H rated snow tires (130mph or 210km/h). My local track I think down the front straight it's about 180-185 km/h that we can hit. Not that I'd do that in snows but you see my point.
    I know that certain shops need to cover their butts especially because people do silly things.
    Veteran Member Three Rings StealthBlackA4's Avatar
    Aug 23 2012
    2012 Porsche Carrera 4S
    Erie, PA
    Good info here, especially since I'm in dire need of new tires after just only 6,600 miles. I'm running on slicks haha. These Continetals really were as terrible as everyone else was making them out to be, not to mention that god awful tire drone at slow speeds . Glad my go to tire will always be Michelin PSS for all of my performance vehicles.
    2015 Sepang Blue S5- APR Dual Pulley Ultracharged, APR TCU tune, CR-15, AG M580s, Girodisc F/R rotors, EBC Red Stuff pads, APR Open Box CF Intake, AWE Track Exhaust with AWE Resonated DPs, etc...
    2017 Mythos Black S6- Stock
    2020 Nardo Grey RS3- Stock
    Veteran Member Four Rings pdqgp's Avatar
    Mar 06 2015
    a 12 Second boat, & Wife's Lincoln
    Columbus, Ohio
    Quote Originally Posted by bhvrdr View Post
    Mike
    ^^ this. I wouldn't recommend the 92's. Load bearing isn't something you want to mess with on tires.
    2018 Midnight Black Metallic AWD Infiniti Q50S Red Sport | Burger MS JB4 | 395awhp/430awtq
    2018 Ruby Red Metallic Lincoln MK-C Reserve | AWD 2.3l EcoBoost - Wife's
    2014 Brilliant Black S4 | S-Tronic | 187mm APR Stage 2 Dual Pulley & APR TCU Tunes | APR CPS - SOLD
    Active Member Two Rings Bmil128's Avatar
    Jun 27 2014
    Quote Originally Posted by pdqgp View Post
    I can vouch for this as well. I had 91s installed on an Acura I had long ago that specified 93s and had two sidewalls slowly fail.
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by Bmil128 View Post
    Scary stuff. Add in the torque and power from the S4 and AWD and think about the stress our tires are under. Not worth the risks. Any installer worth their salt should not install a tire that's underrated too.
    Veteran Member Four Rings LYKUNO's Avatar
    Jul 18 2010
    NE Ohio
    Just ordered a set of PSS in 255/40ZR18 (99Y) XL. Max load is 1709lbs, tire weight 25lbs, tread width 9.5". $229 each with free road hazard protection. Then again, this is for an 18".
    2023 S5 Sportback | Prestige | District Green | Rotor Gray Napa | Sport Diff | Black Optics | Satin Bronze HRE RC104s
    Gone but not forgotten - 2011 S4 | Prestige | Jet Blue | HRE R40s
    Aug 31 2008
    Atlanta, GA
    Thanks for all the info on the weight. I'll be going with the 96's.
    Anyone able to chime in if I can fit 265's on the stock peelers?
    Dec 10 2012
    New York
    Tire rack sold me 92y when I put the model info into their website. Have run them for about 5k miles without an issue.
    Mar 06 2015
    Columbus, Ohio
    Quote Originally Posted by switchedstance View Post
    Are you on 18's or 19's? You'll probably be fine but it's too close for my comfort.
    IIRC Curb weight of the car is like 3900lbs give or take a few. It has a horrible 62/48% distribution which makes it front heavy. That's about 1,200 lbs per tire on the fronts just sitting still. Add in driver, cargo/passengers and then add in forces such as the fact that we're running at a suggested 41psi, they are being exposed to conditions such as it being an AWD platform and perhaps your driving environment and conditions and the sidewall on those tires are being exposed to a more impactful amount of stress from heat than the higher rated ones would be. In other words, I wouldn't go auto crossing or even to a fun road course day trip with them. That's just me though. I'm very surprised they didn't match you to what the stock tires such as the conti's are rated at which is the 96Y code.
    Dec 10 2012
    New York
    IIRC Curb weight of the car is like 3900lbs give or take a few. It has a horrible 62/48% distribution which makes it front heavy. That's about 1,200 lbs per tire on the fronts just sitting still. Add in driver, cargo/passengers and then add in forces from driving conditions such as it being an AWD platform and perhaps your driving environment and conditions and the sidewall on those tires are being exposed to a more impactful amount of stress from heat than the higher rated ones would be. In other words, I wouldn't go auto crossing or even to a fun road course day trip with them. That's just me though. I'm very surprised they didn't match you to what the stock tires such as the conti's are rated at which is the 96Y code.
    Live and learn I guess. so at 1389 per tire, that's 5556lbs they can support before being overloaded. With the weight distribution factor, I should still be OK. I recently retired from the "stance" scene and you'd probably cringe at the tires I've run before without issue. 245/30/20 on an 11" wide wheel on my a5 l, have done a 215/40 on a 10.5" wide wheel on my GTI, never an issue. I'm sure the manufacturer programs in a factor of safety when it comes to load rating. That said, no intention to compete on these, maybe some spirited driving. Though, this conversation will make me think about how I load the car for a road trip from NYC to Vermont this month. I'll continue to stay super vigilant about pressures.
    Mar 06 2015
    Columbus, Ohio
    I agree you'll probably be fine. In the past more than now I did a lot of Autocross and road course events so I'm more sensitive to the subject as I've had tires fail due to heat and witnessed others with sidewall failure.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Jul 21 2004
    South Florida
    I just tried to add the 92y tires for an S4 and it allows it but adds the warning: XL tires required (which these aren't). I'm actually surprised they allow it. You wont have a warranty on the tires of course. Either way, glad the OP got the right ones. The sidewalls can separate when you go with too low of a rating. You may be fine for awhile or you may have a blowout at an inopportune time.
    http://www.audizine.com/forum/showth...ss-than-3-days
    http://www.audizine.com/forum/showth...-Discount-Tire
    http://www.audizine.com/forum/showth...Lesson-Learned
    Mike
    2018 Audi S5
    Gone-
    Dec 10 2012
    New York
    Mike
    I'dont remember seeing that warning. Michelin accepted the tire warranty registration and Tire Rack accepted the road hazard guarantee. Hmm.
    Mar 06 2015
    Columbus, Ohio
    As you scroll down you'll be given the choice of which load bearing version you wish to buy. I have no double the warranty was accepted, etc. as I'm sure their are simply just registering the tires to you vs cross checking the load bearing requirements vs your selection.
    Apr 11 2012
    I ran 92y since that's the highest load rating I could get for summer tires in 245 30's for a 20x9" wheel. After about I'd say somewhere around 10K miles, I had two separate occasions, a month or so apart, where my front right tire blew out on the freeway without hitting any hard bumps or potholes that day. There were no punctures. I could never be 100% sure, but I'd say it was a combination of slight stretch and the 92 load rating.
    The car was very controllable when they went, but I pulled over right away and had the pleasure of changing a tire on the freeway with cars screaming by twice.
    Just my experience, it's your car/life, do what you want
    Mar 03 2010
    Pitsburgh, PA
    Eh, that literally doesn't add up...
    Mar 03 2010
    Pitsburgh, PA
    Don't sweat it. The XL (96Y) rides very well. I've driven some harsh XL tires before, this is not one of them.
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    Quote Originally Posted by administerturbo View Post
    Heck yah man out ads up ! His car weighs 110% total. Duh. <snicker snicker>
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Veteran Member Four Rings fitzydude's Avatar
    Jul 05 2014
    Houston
    I've been running 92Y, that's what my car had on it. The conti DW's were a pound or two lighter in 92Y form.
    2010 S4 / 6MT / 034 RSWB & Motor Mounts / AMS Cooling / EC Alu Kreuz & inserts / B12 suspension / CTS SC & JHM OD Pulley (PR:3.139) / JHM STS & Stg 4 clutch / Magnaflow w/cutouts / CTS Downpipes / V710 / Eventuri-Euro / USP clutch line / E35 / Chipwerke 3-1 / Revo - 467 awhp
    Aug 31 2015
    California
    Costco is offering a $70 instant savings for a set of 4 Michelin PSS. Net price per tire: $217.49 (In my area)!!
