I've used a toogle switch to turn on my fan for years, I'd like to install a fan switch (probe) and have it do everything for me.
Left is my set up, right is what I want.
I would like to toss the toggle, and place a 180f fan switch in the lower radiator hose, I would get one of those billet 1" inline couplers that's tapped on the side to except npt fittings to insert the probe. The power wire would run to the fan switch, once it saw 180f it would complete the circuit and send power to the fan. Or is this completely wrong as the switch isn't designed to send power through it and not really a ~switch. And fan switches really only send a signal to a relay or power box, which it turn sends power?
I do not want to run one of those cluster phucks of a relay system, I'm trying to keep the system clean and not run wires back to the ignition system and alot of kits are single wire fan switch probes meaning they have to be self grounded into an aluminum radiator. They don't work on plastic.
If fan switchs are not power switches and only signal switches is there a power model out there? I want the fan switch to see 180f and complete the power circuit.
Not sure I want to tap into the exsisting 3 wire oem fan switch as hooked up to the system and the ac fan reads that signal.
