Results 1 to 9 of 9
    Dec 24 2014
    No. VA
    Washer Nozzle for vision camera???
    I have night vision package, it has this little thing next to the camera... Washer fluid is leaking out of it. Is it a nozzle or is it a washer fluid vent??? Please advise before I take it in to the service.
    Veteran Member Four Rings sirmium's Avatar
    Feb 10 2011
    MotorCity
    Its windshield fluid sprayer to clean lens
    Sent from my keyfob
    '23 Tesla Model X | '17 Ducati Supersport S
    Dec 24 2014
    No. VA
    Okay... But it won't stop leaking washer fluid.... I see puddle of washer fluid on the floor.
    Feb 10 2011
    MotorCity
    Quote Originally Posted by quad_drive View Post
    Nozzle might be broken
    Sent from my keyfob
    Mar 29 2014
    Hampshire, UK
    Are you sure its washer fluid on the floor?
    The system is not under pressure, until you operate the washers at which point it sprays the camera.
    Can you have someone operate the washer while you are watching the nozzle spray?
    2016 S7 Sepang Blue ///Matrix//Bose//Self Park//Lane Assist//ACC//F&R parking cams//Blackvue DR750//Phone Box//Sunroof//Privacy glass//Carbon mirrors//Neidfaktor Steering wheel//RS Knob//OEM RS Grill//Suntek PPF//De-chromed//Modded Exhaust//Cete ASC v2 installed//APR Stage 3 w/RS7 Turbos and intake pipes + TSU//Eventuri CF intake//Carbon Diffuser
    Gone: 2014 Audi A7Q 3.0 TFSI
    Gone: 2011 Audi A6Q 2.8 TFSI
    Feb 26 2010
    Los Angeles, CA, USA
    I find new things to discover everyday on this forum...never knew there's a washer nozzle located next to night vision camera!!!
    Dec 24 2014
    No. VA
    Quote Originally Posted by jkwelsh View Post
    Yes. Positive on the washer fluid... I can see it slow dripping out of the nozzle. Must be a bad seal or something...
    Mar 16 2004
    NC, USA
    I just went through this (in case you're tracking), here's my solution:
    Pop the plastic trim off above the grill, everything is accessible from there thankfully. 3-4 torx and the assembly is off, unclip the hose to get some more slack, move the entire thing up and out. From there I unscrewed the washer nozzle from the camera, unclipped the cable to the camera, set it aside. Wrestled with the clamps that would hold a planet from the grips of a black hole, got the check valve off. Peered inside and it appeared that some debris had made its way through the tube and was causing the valve not to close fully, and therefore the drip drip. Cleaned it out, blew as hard as I could and heard not a single tiny squeak of a leak. Before cleaning it would make some noise and I could easily blow air out.
    So, after much fear, it ended up being just fine. So if you have a mystery loss of windshield washer fluid, check for dribbling around the night vision camera if you have one.
    As an aside mod "while I was in there" I put a screen protector on top of the night vision lens. Took the plastic surround/trim off, cut to fit, and I have a tiny bit of extra protection. Probably should have used something more substantial that what I did, but it's what I had laying around.
    Senior Member Three Rings 2wookies's Avatar
    Jun 03 2016
    Omaha NE
    It's fun to point to forward and hit your buddies. I know, I'm a man child.
