Results 1 to 3 of 3
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    2001 Allroad - air suspension - pump running
    The pump is running quite a bit.
    There does NOT appear to be a leak. Car can be parked on various height levels for days, without sagging.
    Yet, the pump kicks in often and runs quite a bit.
    Logged the 4 height sensors, and the reservoir pressure and reservoir valve and pump relay.
    Notice that reservoir pressure is often ZERO.
    After pump kicks in, climbs to only 4 bar (I am used to seeing as much as 16 bar, but certainly 10; pump has just been rebuild).
    Then, without any movement on the 4 height sensor, reservoir pressure drops down to zero within less than 1/2 minute.
    But also observed that reservoir pressure stays at 4 bar and holds forever.
    There appears to be a leak.
    How can I trouble shoot?
    Narrow down where to look for potential leak?
    Line/fittings from pump to reservoir?
    Reservoir to valve block (if there is such a line)?
    Valve block itself leaking?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Jun 19 2014
    Yonkers
    I had simillar symptoms and it turned out to be a weak air compressor.
    I tried rebuilding the compressor but it was too worn out.
    I ended up replacing it with a used one from a 2005 Allroad.
    Now the air compressor hardly runs and there are enough air stored in the reservoir to raise my car about 1 1/2 levels.
    A spray bottle with soapy water is the best way to check for leaks.
    Spray all potential leak points and look for bubbles.
    Feb 20 2010
    Brighton, MI
    Can a 'worn compressor' after rebuild leak the pressure out of the reservoir?
    The compressor can raise the car fairly quickly one from level to the next (as a possible other indication that 'worn' may not explain the reservoir not holding pressure).
    05 Golf TDI
