Results 1 to 40 of 62
    Veteran Member Four Rings Party_Marty's Avatar
    Nov 02 2015
    Sector 9 Long-board, Rugby Kit
    In the woods
    Party_Martys Build. Keepin it classy with a touch of scotch.
    Hey everybody!
    I'm Marty, and you guessed it, I like to party.
    Enough with the small talk. I'm a fairly new Audi owner but my passion for Audi comes from childhood and growing up when my father bought a MK1 TT...
    My goals with this car is to keep it luxurious on the streets but make it a screamer in the sheets (350whp/350wtq). This is my daily so if its a larger task at hand, I'm forced to do my research until I am positive I can finish it in a weekend. So far I have been successful...Check out my build sheet and let me know what you think!
    2014 B8.5 Audi A4 - 6 Spd - S-Line
    Updated 5/21/2020
    Performance:
    CTS k04 Turbo
    United Motorsports Custom Tune
    CTS HFC
    CTS downpipe
    Custom built Party_Marty full 3" axleback exhaust w/ ECS 3.5" tips
    GFB DV+
    Treadstone TR8 IC
    Full Aluminum hard intercooler piping
    Southbend Stage 2 Clutch
    Stoptech SS Clutch Line
    Integrated Engineering Built Short Block
    Brakes/Suspension:
    Bilstein B16 PSS10 Coilovers
    034 Adjustable upper Control Arms
    Q5 front lower control arms
    Brembo 4 piston Calipers - Front (Q5 Swap to fit 245 rotors)
    Performance Drilled Rotors on all four corners
    Stoptech SS Brake-lines
    Entire brake system painted black
    Wheels & Tires:
    19X9.5 et37 Vorsteiner VFF103's finished in Mercury Silver
    255/35 Pilot PS4's
    18X8 et47 OEM 10-spoke S-Line Beauties
    255/40 Continental Extreme Contact dws 06 XL
    (Winter Setup)
    Exterior:
    35% Tint
    Debadged
    Front Splash Guards
    RS6/RS4 replica grill
    Custom headlights (tinted ambers)
    Silver Painted Accents
    Audizine Sticker
    Whispbar/Yakima lo-pro cargo box (winter setup)
    Interior:
    Euro Safety Triangle - gotta keep it safe haha
    eMK White Light LED kit
    Electronics/Audio:
    AMI back up camera
    Phillips extreme white DS3s
    Phillips LED H8 Fogs
    Ross Tech Goodies
    Dayton Audio center dash speakers
    Kicker DXA500.1 Amplifier
    Kicker 40CWS102 Sub-woofer
    BASSER Sub Enclosure
    Bluetooth Phone charging mount
    That's it for now but keep posted for more updates and modifications! I got a fever, and the only cure, is more modifications.
    Here is my car in its most current state.
    A nice youtube pull video:
    A video of the exhaust:
    Bought this elegant lady back in the year of 2015 on the 29th of October.
    Safety First! I purchased the first aid kit and safety triangle as well as the Audi compressor that fits in with the spare. I will be driving this car A LOT so I want to be prepared for anything.
    1/17/16 - JHM Short Shifter Install - It was pretty simple since I had the right tools. Get yourself the upholstery tool kit! You will use it everywhere on the car, not just here.
    2/28/16 - China AMI Back up Camera - Definitely a harder task for those with less experience. I have been doing this kind of stuff since I was a kid so popping the passenger side panels and glove compartment and wiring this kit in was only time consuming, but definitely doable. I installed the ECS Catch Can this weekend as well but I'm not posting pictures as I removed it and returned it.
    3/5/16 - Painting the brakes. I was going back and forth but decided with Black all around to give the car a very classy/stealthy appearance. Also, I knew I wanted to go with a thinner spoke design for new rims, so I wanted the brakes to be very clean looking, and also make the new wheels 'pop' more. They turned out great!!! This task was once again time consuming, it would be trivial for a new guy but its very doable. Make sure you have a quality torque wrench to make sure your car goes back together perfectly. It took a lot of elbow grease and patients to get it right.
    I Sanded them down real smooth!!
    3/11-13/16 - Tint and Suspension - Go to a reputable shop and get good esp if your car is black. The coilover system is not for the faint of heart. I had help from two of my brothers so I was lucky. It took me 9 hours to complete but we got all together perfectly. I'm still to this day playing around with the adjustable dampening and height.
    Yea, this is quite the tool, I know.
    The rear I didn't take pictures of because I was way to in the zone and just wrenchin away. But here she is, all lowered and shtuff...
    This is now my winter setup. I have ECS Spacers for this setup, 15mmF/20mmR. I love the stance and really I wont be sad when I switch to my winters because
    A: It looks sexy as hell
    B: I love driving in the snow!!!
    3/25 - New Wheels - Dyno Day - Alignment - I took it over to get stock numbers before I start bolting up all sorts of upgrades to see what MY car gains.
    I made a very respectable 200whp and 247wtq. I'm proud of those numbers!!!
    Shaved off 5 LB per corner...
    Shout-out to Jason Tung at GetYourWheels.com. Hit him up for your wheel needs!!! He hooked it up!
    Update 5/21 - Kick Comp-S sub installed in the OEM location along with a Kicker Amp.
    I also routed a remote Gain Controller to the Glove box so I can turn up/down as I go depending on the music. It really is a great touch and worth it IMO.
    Initial thoughts...well the lows are crazy loud, like they sound great, but personally I didn't want to go this loud. The mids and highs are barely there and that's what bugs me. I listen to all types of music and I want the sub to be crisp and clear. I believe this to be due to the fact that I'm using the trunk as a "enclosure". I ordered a custom box from BASSER from Poland haha. I'll update once i've installed and tuned.
    Sound System Update: BASSER sub-enclosure installed and it fixed the problem, all bass is now tight and crisp and I can turn it down to be "just right" for my taste
    034 HFC and CTS downpipe installed. I definetly like the setup. It gives the car a nice sporty sound. I can hear the turbo spool sooner and I can feel the car pull a little harder. It seems like a smoother/harder pull. I would highly recommend having a second guy help out. It made things go much smoother and faster.
    Update 6/30 -
    Treadstone TR8 intercooler back ordered, should recieve sometime in July hopefully.
    Go Fast Bits DV+ installed, I want to say I feel the boost come on a smidge sooner but its hard to tell, noise is the same. I mainly did this to be able to hold the higher boost from going stage 2.
    Stage 2 will come once I install the IC...
    Update 2/8/2017
    -TR8 has been on the car for a while. I went with GIAC at first (stage 2 or 1+ or whatever) but was not satisfied (esp since they cannot code 2nd O2 out) so I went with what everybody else does and got an APR stg 2 tune. Much more aggressive and I'm happy for now.
    Here is a dyno pull after the stage 2 tune.
    Of course when going stage 2, its inevitable that you will need a new clutch sooner, esp if you like to drive 'spiritedly'
    Update 4/24/2017
    The brembo brakes, SS lines, and Adams rotors are a huge improvement. I am so thrilled with the feel and the braking power.
    7/19/2017 - Just going to add by adding comments, editing the first post is a hassel haha.
    ---------------------------------------------------------- IG: party_martyy ----------------------------------------------------------------------
    ---------------------2014 A4 - 6 Speed - Phantom Black Pearl -------------- Peep the Build ---------------------
    Veteran Member Four Rings quattroforlife's Avatar
    May 24 2012
    2016 Tundra
    Southern CA
    Car looks clean!
    Good luck with the modding!
    Cure that fever
    Zach
    2016 Toyota Tundra // Methods | C4 Fabrication | Warn | Icon | Toyo | Baja Designs
    Gone, but not forgotten:
    2020 C63S Coupe // Nemesis plate frame
    2000 Toyota Land Cruiser
    B8 A4 // Just about everything
    Nov 02 2015
    In the woods
    Quote Originally Posted by quattroforlife View Post
    Car looks clean!
    Cure that fever
    Thanks man!!!
    Veteran Member Four Rings auditd0rk's Avatar
    Feb 02 2012
    Colorado Springs
    Looking good, Marty. A tune and HFC will unleash the beast!
    2012 A4 Quattro, Monsoon Grey | CTS K04, HFC | APR K04 v3 Tune | AWE Exhaust | Eurocode FMIC, Alu Kreuz, Sway Bars | Bilstein PSS10 | SPC UCAs | Apikol Rear Diff Mount | 034 Transmission Mount Insert, End-links | StopTech ST-60 BBK | S4 rear brakes | CR-15 brace
    Veteran Member Three Rings OzeyeruZ's Avatar
    May 24 2013
    Looks clean! Stage 1 tune to get a nice bump in power would be my next recomendation. From there you can build up or go straight to Ko4. Happy Modding!
    Oz
    2013 Scuba Blue A4 Premium
    EuroCode / APR / H&R / Bilstein / VagCom / AWE / NGK / 034 / GFB / HRE / Valentine1 HW / CR15 / Black Viton Injector Seals / Fluidamper / Ko4 #00Negative
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    VW Atlas and too many detailing supplies
    Wilmington NC
    Nice work bud!
    2019 S4 Build
    2013 A4 Scuba Blue Metallic - SOLD (never forgotten)
    IG: @steves_s4
    Veteran Member Four Rings bmoreS4's Avatar
    Apr 27 2011
    Couple Audis and a VW
    MD
    Good stuff, looking good man.
    2020 B9 SQ5 - 034+ / E85 / APR / CTS / MTM / VPS
    2001 B5 S4 - Stage 3 / E85 / Thanks to Brad
    2018 Atlas SEL Premium / Black on Black / Black Wheel Package
    Cheap/Fast/Reliable - Pick Two
    IG: @s4dad
    Jul 12 2010
    848 Corse, SQ5
    washington dc area
    wheels look great in person man! optical illusion LOL!
    Veteran Member Four Rings earhythmic's Avatar
    Sep 17 2006
    ‘17 F450, ‘24 Street Triple RS
    San Francisco Bay Area
    Good wheel choice!
    2013 Allroad - 12.18s 1/4 mile
    CTS K04| APR | IE | Magnaflow | AirLift 3H | Hotchkis | Vorsteiner
    clicky for build thread
    past: B6 S4, B5 A4
    Nov 02 2015
    In the woods
    Thank you everybody! I plan on going straight to stage 2 this summer. Keep posted!
    Quote Originally Posted by drumnjuny View Post
    HAHA right!
    Quote Originally Posted by earhythmic View Post
    Good wheel choice!
    Hey I was going to tell you the same thing!
    Dec 01 2011
    very nice, car looks great.
    question about this pic, does that middle black plastic area around the shift just pop off? do you need to remove the AC/heat controls to get that out or anything else, or just pop off with the removal tools?
    IG @theshawon
    Nov 02 2015
    In the woods
    Quote Originally Posted by Liquid Smoke View Post
    You have to remove the lower control module, its pretty easy, just take your time and pop it off starting at the top using the tools or a slim PLASTIC shim. you do not want to mar up the edges as this is seen from the outside.
    Senior Member Two Rings acidvoodoo's Avatar
    Mar 11 2016
    Providence
    Very nice! What percentage tint do you have?
    Stage 2 Banner Advertiser Four Rings GetYourWheels's Avatar
    Jan 23 2014
    Santa Fe Springs
    Daaaang!! Love how the VFF103s came out in the silver! Perfect color choice for the car
    Happy we could help you out
    Email : [email protected] | Call or Text: (562)219-2525|
    Your Wheel Fitment Specialist / Wheel & Tire Deal via DM
    Top Tiers Dealers - Avant-Garde / KlassenID/ VSForged / Stance / Vossen + More
    Veteran Member Three Rings kdaffy's Avatar
    Apr 17 2014
    MA
    great job painting the brakes! looks real good. how long did that take you and did you need to leave it to dry and cure for a certain amount of time before driving?
    Nov 02 2015
    In the woods
    Quote Originally Posted by acidvoodoo View Post
    Thanks! I have 35% on all the windows except the rear which is 20%.
    Quote Originally Posted by kdaffy View Post
    Thank you! The brakes took me a weekend. I started Friday work and didn't drive the car until Monday. After painting the system, I let it cure for 24 hours before driving. It has held up great so far!
    Veteran Member Four Rings JeriQo's Avatar
    Jul 08 2015
    i like it!
    ive been wanting those 103 wheels
    2012 BB A4 P+ S-line Exterior |FBSW RS Paddles/Pedals|CR-15|AFE Filter|ECS inlet|S4 Dual Exhaust|Ace Convex 19x8.5|ECS 10mm rear|Solowerks S1
    Nov 02 2015
    In the woods
    Quote Originally Posted by JeriQo View Post
    i like it!
    Thanks man!
    Yea they aren't cheap
    But then again, would ya just look at it! Just look at it! haha
    Nov 02 2015
    In the woods
    Update
    5/21 - New 10" Kicker Comp-s Sub installed (got a great deal on the whole system setup to pass it up)
    Initial thoughts - way to loud, I'm looking for a small upgrade in bass and this just shakes the entire car like i'm in an earthquake. Will be tuning it to see if I can have good lows, mids, and highs, but for now only the lows are there. I'm installed in the stock deck location so maybe a box is in order...but I don't want a box in the trunk. so I might take the whole thing out and just purchase some nicer speakers. Going to try to tune it for now...
    Feb 24 2013
    CA
    Do you have to the ami backup camera? And beautiful car bro, well done
    Nov 02 2015
    In the woods
    Quote Originally Posted by Slick_B8 View Post
    Thanks dude! Yes I do, I bought it from Eron, worked like a charm once I figured out where to plug everything into. He sends a great kit but just lacks directions on where everything goes.
    Nov 02 2015
    In the woods
    6/4 - Updated!
    Established Member Two Rings Hagasan41's Avatar
    Sep 16 2013
    Orlando
    Nice ride! Gotta apprecaite the the 6-spd!
    - - - Updated - - -
    Nice ride! Gotta apprecaite the MT A4's!
    2015 A4 Quattro S-line 6MT Glacier White/Black
    Nov 02 2015
    In the woods
    Quote Originally Posted by Hagasan41 View Post
    - - - Updated - - -
    Thanks man! Manual is the only way to go IMO.
    Nov 02 2015
    In the woods
    Alright, did some pulls so peeps can hear the car. Links below.
    https://youtu.be/k8xCRJg_r2M
    https://youtu.be/9Jd-LJrBwAI
    Jan 23 2014
    Santa Fe Springs
    Quote Originally Posted by Party_Marty View Post
    Sounds great Marty!
    Established Member Two Rings willski's Avatar
    May 08 2015
    2013 A4, 2.0T Quattro S-Tronic
    Melbourne, Aus
    Man that is so clean and nicely done, love the mods, and it makes me wish I got the manual (although the S-tronic isn't too bad). Exhaust sounds sweet in the vids too. Do you hear much turbo spool with your setup? and also, do you get a CEL light with your HFC, or are you running some kind of O2 spacer?
    After looking at that second pic I was about to ask what lip spoiler you have! Other pics confirm that its just a flattering angle of the standard trunk? Looks so tidy man, nice work
    Nov 02 2015
    In the woods
    Quote Originally Posted by willski View Post
    Hey thanks Willski!! I do hear the turbo, its not as loud as I want, but I'm going to be installing my IC and running a stage 2 tune that should live-en it up a bit more. The HFC does throw a code for "efficiency below threshold" or what not but I know It will go away when I tune for it so its not a big deal. Others have had luck with the spacers but i'm not going to bother.
    Yea I try to get good shots of the car that really show off its great looks! Thanks again!!
    Veteran Member Four Rings Just A B8's Avatar
    Sep 29 2012
    is Messy!
    Northern NJ
    Looking good sir! Keep it up.
    B8 A4 | PRESTIGE | S-LINE | SPORTS PACKAGE
    034 | AIRLIFT | AFE | APIKOL | APR | AVANT GARDE | AWE | BILSTEIN | DEFI | DEVAL | EUROCODE | HOEN | ROC-EURO | SPC | VIAIR | XPEL | YAKIMA
    Nov 02 2015
    In the woods
    update bump!!!
    Nov 02 2015
    In the woods
    Have done some work but have been lazy to post haha
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    Looking classy! and OEM+ Love it!
    Any thoughts on the Bilstein kit?
    Nov 02 2015
    In the woods
    Quote Originally Posted by A4 Centaur View Post
    I love it, It deff was the right suspension for the car. Its the perfect combo of sport and comfort in my opinion. Anybody that rides in my car is always so surprised at how comfortable the ride is, and how planted it feels when enjoying spirited driving
    May 24 2013
    Any clips of how the exhaust sounds like? Car looks awesome!
    Oz
    Nov 02 2015
    In the woods
    Quote Originally Posted by OzeyeruZ View Post
    Oz
    Thank you! I need to get a mic so they aren't crappy cell phone quality, I've taken a couple but the background noise ruins it...
    Jan 03 2012
    Wilmington NC
    Yea man, we both need that!
    2019 S4 Build
    IG: @steves_s4
    Veteran Member Three Rings B8_Dude97's Avatar
    Sep 05 2016
    Antioch, California
    Did you delete just the rear muffler? What's your exhaust setup?
    May 20 2017
    Orange County/California/SoCal
    can i get a link where you get your grill from and the quattro sign also
    2014 A4 Tiptronic, IE Intercooler, UnitedMotorsport, JHM HFC, STOCK Intake, AWE Tuning A4 Touring Edition Exhaust - Quad Tip. Sportline 7S Gunmetal 19x9.5 ET40, EuroCode Alu Kreuz, 034 Rear Sway Bar/End Links.
    Jan 02 2017
    Nothing but two thumbs up!
    Nov 02 2015
    In the woods
    Quote Originally Posted by B8_Dude97 View Post
    My full exhaust setup is: 034 HFC -> CTS DP -> stock middle muffler -> rear muffler delete with the dual 2.5" piping as shown above. I think it sounds perfect
    Quote Originally Posted by bhuynh1804 View Post
    It was all from the same buyer, I bought it from a guy on Ebay, stonecarbon i believe.
    Quote Originally Posted by Delfrikin View Post
    Thank you!!!!
