Results 1 to 11 of 11
    Feb 27 2011
    Winnipeg
    rear upper control arm bushings
    these are on wholesale closeout at rockauto and only $2.56 CAD each they are the upper rear arm inner bushings and take 4 per car, if you look hard enough at the picture you can see meyle in the rubber. I just ordered at bunch.
    Jun 30 2008
    Erie, Pennsylvania
    Not a bad idea. These things become unbonded from the casings with age and tend to make a terrible squeaking.
    Veteran Member Four Rings Turbo_B5's Avatar
    Oct 09 2012
    abunch of useless shit
    Notnomde Atrebla Adanac
    sweet, that solves my control arm bushing problem. bought two sets.
    EH F0UR 2001 A4 1.8TqM
    = Parked cause its junk.
    2002 Golf TDI
    = FASTER THEN YOUR B5.
    2018 Suzuki GSX-R750
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    1997 A4 1.8TqM SPORT
    @Turbo_B5
    Feb 27 2011
    Winnipeg
    yup I bought 12 lol they also had on wholesaler closeout a ton of cabin filters.
    Oct 09 2012
    I should of bought more :(
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Jun 11 2014
    Atlanta
    Good looking out! I can't seem to find a decent write up on replacing the bushings though. Anything in particular to look out for?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    I bought two sets as well. FYI, these are a pain in the ass to replace.
    First, they are tough to get out. I had to angle my air hammer just right and pound on it for a while until it would let loose.
    Second, they are a bitch to get in. I finally devised a way of sucking them in. DO NOT pound on the arm much or place much force across the arm. It will bend. Mine did. I bent it back and feel kind bad about it. So here's what I did. Grabbed a washer big enough to fit the outside of the hole, then make sure the inside hole in the washer is big enough for the metal part of the bushing to slide through. I then found a large socket, big enough for the bolt to go through. Mine was a 1 1/8th craftsman socket. I seated everything up and gave er the nuts with my 1/2 impact and it worked pretty well.
    Sorry the description of what to do is shitty but here are a couple pics without the arm thrown into the mix. The bushing would obviously be inside the hole.
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Feb 27 2011
    Winnipeg
    I air hammered the shit out of them to get them out of the arm, then with a sanding drum on a dremel I cleaned the rust out of the hole, sprayed some WD 40 on the outer sleeve of the bushing as well as inside the hole of the arm and used a harbour freight ball joint press and they went in like butter, it literally took 10 min to install the 4 inner bushings. The outer bushings are another story lol
    Oct 09 2012
    I should of ordered more.
    Sent from my Jailbroken iPhone 6s 9.0.2 using Tapashit
    2002 Golf TDI
    2014 Honda Grom
    2013 Golf TDI
    2001 A4 1.8TqM
    @Turbo_B5
    Feb 27 2011
    Winnipeg
    Quote Originally Posted by King_ View Post
    all 12 of mine just showed up yesterday along with a bunch of $3 cabin air filters.
    Veteran Member Four Rings B5nDisciple's Avatar
    Aug 23 2014
    2006 Honda Odyssey--Cannondale Caad 12--Giant Talon
    Tucson
    Just ordered 8. They're still available!
    Then Jesus said, “Come to me, all of you who are weary and carry heavy burdens, and I will give you rest." Matthew 11:28
