Results 1 to 9 of 9
    Nov 28 2015
    Montreal, QC
    to replace end link with sway bar or not ?
    My mechanic is telling me that buying new end-link like the moog might be a waste of money.. So, just curious, how many of you had to change the oem end link because they were shot and how many miles your car had ?
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    I replaced my stock units a few years back along with sways and I'm never going back. It was to me more transformative than even installing my Alu Kreuz. I can't speak for moog alone but to fully realize the benefits look into doing your sways as well.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Apr 05 2009
    1984 Audi 4000S Quattro, 1989 Toyota MR2 SC, 1960 Alfa Spider
    SF BayArea
    the rear stock ones are stubby and pretty stout. probbaly won't see any improvement replacing that set. the fronts are pretty flexy though, and I noticed a difference when I swapped out the fronts for an alloy one even on a low miles car
    Mar 21 2015
    Active Member Two Rings Bmil128's Avatar
    Jun 27 2014
    I used Moog front and back and only changed my rear sway bar. The Moog rear links have polyurethane bushings but the fronts do not, they are identical to the front except the links themselves are steel. Definitely have a bit more feel in the front as a result even without the Alu Kreuz (mine is coming in this week)
    Dec 14 2015
    Orange County, CA
    Quote Originally Posted by Bmil128 View Post
    I just recently got my Moog rear links from Amazon but i'm trying to figure out where the 2 washers go. Does one get sandwiched between the link and the bar and the link and the arm? Thanks!
    *GONE* 2016 S4, Premium Plus, BO Package, DSG, Sport Diff, Daytona Grey, CR-15 Strut Brace, EuroCode AK, 034 Trans Insert, ECS Drivetrain Inserts, 034 Rear Sway Bar, HRE FF01 19x9.5 Wheels, Brembo GT 380mm BBK, EPL Stage 1 & DSG Tune
    2020 BMW M2 Competition, M Drivers Package, White
    Jan 09 2008
    Winnipeg
    Quote Originally Posted by Lbsigman View Post
    I would think the opposite, between the link and the bolt/nut so that as you are tightening it there is something there to ride on.
    Oct 30 2012
    Oxford, MS
    Quote Originally Posted by eurotic View Post
    See pictures here.
    Sep 24 2014
    2015 Audi Q3 Quattro, 2017 Corvette M7 Grand Sport, 2017 Audi SQ5, 2019 Porsche Macan, 24 Jetta GLI
    Central NJ
    I have the front and back Eurocode bars, set to stiff, and the factory endlinks....they seem to be holding up fine so far (15,000miles with the new bars). I would not call the front endlinks "flexy"....I am sure the bars can't exert enough force to stretch or compress the steel rod of the front endlinks....for the money, if you want the last 5% of roll control from the swaybar, get the Moog polyurethane ones...but its the bars that make 95% of the handling improvement to the car.
