Results 1 to 38 of 38
    Veteran Member Three Rings Avantmaniac's Avatar
    Feb 21 2007
    2011 S5/2011 A4 AVANT
    Houston, TX, USA
    Bilstein B12 is on
    I'm happy with the look/height/ride comfort,
    - iKe -
    2011 S5
    2011 A4 Avant
    Jun 05 2009
    2020 Ducati Panigale V4S
    Scottsdale Arizona
    looking good!
    Senior Member Three Rings NLPed68's Avatar
    Jan 21 2016
    1968 Chevy C10 Restomod, 1974 Bronco Crawler
    Hayden, AL
    Looks great!!! I'm still waiting (patiently ???) for my set. Supposedly mid-May.
    Thanks,\
    Ed
    2012 A4 Avant... APR K04 /c APR tune, B&B catback, 034 HFC, 19" Avante Garde M510's, Bilstein B12 kit, Eurocode F&R swaybars/endlinks, Alu Kreutz, RS4'ish' Grilles, ERON rearview camera, EuroCode FMIC & plumbing, Kohlefaser Luft-Technik intake System, Ross-Tech VAGCOM, R8 coils, S-Line steering wheel /c paddle shifters, S4 F&R brakes /c drilled & slotted rotors/EBC's/stainless lines, LED taillights, Not a Mod, but WeatherTech laserfit floormats, 20% Tint, More to follow
    Feb 21 2007
    Houston, TX, USA
    Quote Originally Posted by A4 Centaur View Post
    looking good!
    Thank you!
    - - - Updated - - -
    Quote Originally Posted by NLPed68 View Post
    It's worth the wait!
    - iKe -
    2011 S5
    2011 A4 Avant
    Veteran Member Four Rings avantagg's Avatar
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Nice looking avant! I went B12 last week too. 'Tis the season I guess!
    2012 B8 Avant (3.0t Swapped)
    034 DP | APR UC | Ported Charger | Mertop Headers | Milltek Resonated Exhaust | Bilstein PSS-10 | Alu Kreuz | CR-15 | H&R Sways | 034 Inserts | Ecodes | A5 Cluster Swap | 3G+ MMI | RS4 FBSW | Black Headliner Swap | BUILD THREAD
    Feb 21 2007
    Houston, TX, USA
    Quote Originally Posted by avantagg View Post
    Nice!
    - iKe -
    2011 S5
    2011 A4 Avant
    Aug 17 2015
    California
    My Bilstein B12 Pro-kit arrives tomorrow (sedan)!
    Please post what you are doing with your bumpstops and how the ride is compared to stock. There are a some conflicting opinions on here. Some people remove them, some trim them according to the drop, some leave them stock.
    Feb 21 2007
    Houston, TX, USA
    I left them stock, it's fine for my comfort but others will be differ though.
    - iKe -
    2011 S5
    2011 A4 Avant
    Veteran Member Three Rings OzeyeruZ's Avatar
    May 24 2013
    Looks sweet! I have the bilstein sports but with H&R OE's. Nicely firm for a DD, tolerable but there can be times I wish they were softer. Otherwise I love them on the Highways and twisties, and the drop is just right for me.
    Oz
    2013 Scuba Blue A4 Premium
    EuroCode / APR / H&R / Bilstein / VagCom / AWE / NGK / 034 / GFB / HRE / Valentine1 HW / CR15 / Black Viton Injector Seals / Fluidamper / Ko4 #00Negative
    Feb 21 2007
    Houston, TX, USA
    Quote Originally Posted by OzeyeruZ View Post
    Oz
    Tks! and Yeah man, I've been searching/asking here so this kit is the best suit for my needs, I wish the roads in Houston are smoother but not.
    - iKe -
    2011 S5
    2011 A4 Avant
    Veteran Member Four Rings 4ringnut's Avatar
    Apr 04 2015
    2019 Audi S4, 2017 Acura MDX
    Woburn, Ma
    The bump stops should be trimmed accordingly. Or you'll ride on them. It wil effect the ride, and the drop.
    Pedal Responce first responder.
    Jun 21 2015
    1999 T4 Eurovan
    Maine
    Quote Originally Posted by 4ringnut View Post
    I was wondering about this too. I left mine in and did not trim. Does it differ with the OEM sport suspension bump stops? My car had the sport suspension before this kit was installed. The ride seems only slightly lower now, but much firmer.
    Apr 04 2015
    Woburn, Ma
    You still have to trim the sport bumpstops to compensate for the 1.2"-1.4" drop from the regular suspension. I think the sport suspension is like 3/4" lower than standard.
    Veteran Member Four Rings Project Quattro's Avatar
    Mar 24 2014
    1984 Porsche 3.2 Carrera Targa, 2019 Audi SQ5 Prestige (hers)
    @phray this would look great on yours.
    Sent from the Pedal Responce boardroom
    2020 Alfa Romeo Giulia Ti Sport Carbon - 1984 Porsche Carrera 3.2 Targa
    Past: 2017 Audi A4 Prem+ 7AT, 2013 BMW 528i xDrive, 2013 Audi A4 Prem+ 6MT Sport, 2009 Audi A4 Premium 6AT
    Chairman Emeritus for the Pedal Responce Team
    Senior Member Two Rings Davidx1994's Avatar
    Feb 02 2015
    2019 Macan, 2015 Jetta TDI, 2009 A4 Avant
    Plainville, CT
    I've seen mixed answers regarding the bump stops too... Some people say that the front Bilstein struts have a bump stop built in and to not reuse them in the front, just the rear... Will be getting my kit soon, not sure what to do.
    Apr 04 2015
    Woburn, Ma
    I'm one of those people. They do have internal stops. But, if you bottom out the cage mount will come into contact with the strut body. So what I ended up doing was taking the 1.2" piece that I cut of the rear, and installing it in the front. You'll never come in contact with it during normal driving, but it will give you some cushion if you bottom out. Lettuce just did his install with my bumbstop method, and is very happy.
    Apr 04 2015
    Woburn, Ma
    I've reinstalled this suspension twice because of the bumpstop issues. And I can confirm that they have to be cut down. Installing the trimmings on the front is the best way.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    For the B12 ProKit, you re-use your stock bump stops front and rear, doesn't really matter if they are sport or non-sport suspension, for the B12 SportLine Kit, Eibach provides you with new front bump stops which are the same overall length as sport bumpstops but have a plastic reinforced top (if Eibach felt you needed new bumpstops for the prokit they would have included them), leave the rears alone. I have installed the prokit on my wifes car and i have the sportline kit on my car, didn't cut any bumpstops and they both ride great.
    Stage 1 more than you RS3
    Apr 04 2015
    Woburn, Ma
    Quote Originally Posted by o1turbo30v View Post
    And this is the advice that you gave me before I installed mine. And guess what? The rear of my car was 3/4" higher than the front. Even after a month. So I jacked up the rear, pulled down the bumpstop and lowered the car down slowly. I then raised the car again, and wouldn't you know, the bumpstop was back in place. Your car WILL ride on the rear stops if they are not trimmed. It is a fact. I trimmed down the rears by 1.2". And left the front ones off. The rear of my car instantly lowered an aditional 3/4". So now it was 26" to the front fender, and 26 1/4 to the rear. I ended up installing the trimmings from the rear on the front because of the metal on metal contact from bottoming out. And it is the ideal set up. From my actual experience your car will feel bumpy, and won't drop properly if you leave the factory stops alone. Period. The end.
    Apr 04 2015
    Woburn, Ma
    The ride was also very bumpy before I trimmed the rear stops. It didn't feel right at all.
    Feb 02 2015
    Plainville, CT
    Definitely going to be following your advice. Thank you!
    Apr 04 2015
    Woburn, Ma
    I'm going to make a dedicated thread to this topic to clear the air once and for all.
    Veteran Member Three Rings kdaffy's Avatar
    Apr 17 2014
    MA
    you should, but dont let that distract you from going stage 2
    Apr 04 2015
    Woburn, Ma
    Quote Originally Posted by kdaffy View Post
    Lol
    Active Member Two Rings FastFour's Avatar
    Feb 15 2016
    2015 allroad 2011 BMW 335d 2007 Honda S2000
    Ordered mine today and shipping out tomorrow. Allroad coming down...finally.
    Apr 04 2015
    Woburn, Ma
    Quote Originally Posted by FastFour View Post
    They make a b12 for the AR?
    Feb 15 2016
    They do...but I got the one for an A4 so it will come down to a more reasonable height...and by reasonable I mean another 1.4inches lower.
    Apr 04 2015
    Woburn, Ma
    You may be rocking some serious reverse rake. I'm not sure how that's going to turn out.
    Feb 15 2016
    Meaning the front will be higher than the rear? How?
    Apr 04 2015
    Woburn, Ma
    Because of the extra weight of the AR. I'm assuming the rear is heavier than an A4.
    Nov 28 2015
    Montreal, QC
    what is the drop on these ? 1.2 inch or higher ?
    Apr 04 2015
    Woburn, Ma
    1.2 in the rear. 1.4 in the front (on paper).
    Nov 28 2015
    Montreal, QC
    argg thats a bit too low for me. Bought the pss10 then having second thought thinking it might be over--kill but then again.. it's appears the pss10 is the only one that will offer a 10-15mm drop.
    Apr 04 2015
    Woburn, Ma
    Bro, if 1.2" is too low, why even bother?
    Mar 24 2014
    Quote Originally Posted by waxxonMTL View Post
    Retrofit OEM sport suspension. I found the Eibachs to be too low for my use case, but my current car has the sports setup and I couldn't be happier with it. No terrible wheel gap, but I can clear speed bumps and parking lot entrances no problem.
    Nov 28 2015
    Montreal, QC
    i couldn't care less about the drop lol i just want to feel more planted ;)
    Apr 04 2015
    Woburn, Ma
    Just upgrade your swaybars.
    - - - Updated - - -
    Quote Originally Posted by Project Quattro View Post
    You have a terrible wheel gap Jordan. Sorry. lol.
    Mar 24 2014
    - - - Updated - - -
    ... have you seen a non-Sport A4? 2 finger gap is close enough. You should see the speed bumps in my complex; @ryanhmusic and @lambda13 and @goreckless can attest.
