Results 1 to 3 of 3
Thread: Misfire
    Senior Member Two Rings lostInTheSmoke's Avatar
    Aug 06 2015
    Minnesota
    Misfire
    So about a week ago I've been having a misfire that has been going on p0300. So it's just not cylinder 1 2 3 or 4 it's going across all of them. So first thing anyone does is change plugs and coils. Did that and it still happening. Now if I'm just driving normal and don't go WOT it's fine. But when I accelerate hard I get the misfire and check engine light starts flashing. Now could this be a crankshaft sensor issue? I need help with this I just don't want to start buying the parts when I don't need them.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    Try the High Pressure Fuel Sensor
    Located on the fuel rail (06J906051C, confirm fitment)
    and
    Low Pressure Fuel Sensor
    Located on the high pressure fuel pump (06E906051K, confirm fitment)
    That same thing happenned to me, plus i repleced the fuel filter too (4F0201511E)
    Aug 06 2015
    Minnesota
    Thanks I'll look into that
