Results 1 to 4 of 4
    Feb 15 2016
    Cambridge,Ontario
    vacuum pump fitting oring dimensions
    There is small oring where the fitting for the booster goes right to the pump, Its the one that shrinks and causes the fitting to rattle in place. I have seen this fixed with JB weld but does anyone know the dimensions to said oring ?
    thanks
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Feb 15 2016
    Cambridge,Ontario
    Okay never mind I found out after some searching
    it is a Viton 20 mm by 2mm the fitting can be removed and the oring replaced without gobbing JB weld all over your car . unfortunately you have to take the vacuum pump out ot do it properly so you will likely need the 56mm by 2.5mm oring to replace it.
    cheers.
    1976 Yamaha XS 360
    Nov 15 2011
    Montreal | I sell in USD
    cheers.
    linky link?
    *****I sell in USD*****
    Feb 15 2016
    Cambridge,Ontario
    http://www.oringsandmore.com/metric-viton-fkm-orings/
    BTW I called Audi of Oakville as they have the 56mm oring in stock .... $43.00 .. I told him I wanted the ORING not the whole pump ... he said then thats $356.00
    1976 Yamaha XS 360
