Results 1 to 10 of 10
Thread: Dead on the Hwy
    Veteran Member Three Rings Krusty's Avatar
    Sep 18 2012
    long beach
    Dead on the Hwy
    Hello Guys,
    Was just driving on the highway on 5th gear, just cruising and all of a sudden the car turned off, so I had to move to the shoulder and was freaking out. At the point of the incident I didn't know the car turned off, however after I was out of danger I just hit the ignition and the car turned on, without any issues. Wondering what the hell happened? Has anybody experienced this issue?
    2011 sprint blue s4, EC subframe stabilizer, ECS short shifter, Euro Impulse weighted shift knob, custom air intake, RS grille, CR-15, 034 rear diff mounts/rear diff carrier mount inserts, Apikol rear diff mount insert, 10mm(f)/12mm(r), ECS strut tower brace, ECS front adjustable end links.
    Nov 20 2014
    New York
    Maybe LPFP, the in tank pump is on its way out. Put your head next to the gas cap or on the back seat when the car is running and if you hear excesive humming or like an electrical clicking it's the pump
    Veteran Member Three Rings LordMagnet's Avatar
    Jul 20 2015
    Connecticut
    I hover around 3k rpm in 6th on the highway, constantly wishing for a 7th gear. Can't imagine being in 5th.
    2015 Audi S5 Coupe 6MT | Mythos Black Metallic : Black Nappa : Alu-Optic : B&O : Sport Diff. : 19" RS Rims : Carbon Fiber Inlay | APR Stage 2 : Roc-Euro Intake : AWE Touring Exhaust 102mm : EuroCode Short Shifter : USP Clutch Line : CR-15 Strut Tower Brace : 034 Mounts : H&R OE Sport Springs : 15mm/20mm Spacers : Tint 35% Sides / 20% Rear : Interior LED Kit : E-Codes : Vinyled Grille | 413 AWHP / 375 AWTQ
    Jan 26 2015
    2017 XC90, a workbench
    CO
    Ya that is seriously dangerous. I had it happen once after a quick 30mph right turn. Thought it might have been a fuel starvation issue, but the car would not respond to throttle inputs so I stopped and put on hazards. no CEL. Restarted the car and it was back to normal. I called it an automotive TIA. You tuned?
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
    Apr 04 2012
    MSP
    Quote Originally Posted by LordMagnet View Post
    I often cruise in 5th on inner city highways.
    OP sounds like a fuel issue. I'd guess pump.
    Established Member Two Rings S4Drew's Avatar
    Nov 14 2015
    Ft. Worth, TX
    +10 SO MUCH YES. I've got a couple roads I drive regularly that are 45mph limit, and im usually cruising around 50 in 5th gear. Of course, the car says to switch from 4 to 6 at 37mph. But highway speeds of 60+, 6th gear all the way, and when just cruising around 70 really feel the need for another gear to pull. My buddy with the DCT gets about 1-2mpg better than I do, which I attribute to this.
    Current;
    2020 GMC Sierra
    Previous;
    2011 B8 S4
    1968 Camaro SS
    2006 Mazda6 5MT
    1994 Buick Skylark
    2002 Mercury Cougar 5MT
    1985 Audi 5000S Turbo
    Nov 14 2015
    Ft. Worth, TX
    Quote Originally Posted by Krusty View Post
    Hello Guys,
    Agree with Sonic, take a listen to the car when running and listen for a hum that doesn't sound right. An old Audi I had used to do this and it was the fuel pump, and the hum was very apparent in the 5 or 10 miles before it crapped out.
    Current;
    2020 GMC Sierra
    Previous;
    2011 B8 S4
    1968 Camaro SS
    2006 Mazda6 5MT
    1994 Buick Skylark
    Sep 18 2012
    long beach
    There was some traffic, so nothing I could do about that.
    Sep 18 2012
    long beach
    Quote Originally Posted by sonic32 View Post
    Didn't notice anything then, however the radio was on. I have been paying attention at low speeds and nothing yet. I am not tuned yet. Anything else I should be looking for?
    Nov 20 2014
    New York
    Put your ear on the passenger side rear seat while the car is idling and also open the gas cap while car is running and listen in there see if you hear any mechanical humming. You're not gonna hear it while driving. It's not that loud.
