Results 1 to 19 of 19
    Jul 20 2009
    2001 A4 Stage 3+
    Spokane, WA
    Brake Bleeding Sequence
    Topic was discussed in this post: http://www.audizine.com/forum/showth...e-Brake-Rotors
    and was indicated for LHD as
    Bleeding sequence
    1 - Left front brake caliper
    2 - Right front brake caliper
    3 - Left rear brake caliper
    4 - Right rear brake caliper
    And sho nuff this is what the Erwin manual has.
    But my certified Audi Tech says to do it the conventional way - RR, LR, RF, LF. Who should I believe?
    Oct 30 2012
    Arizona
    Senior Member Three Rings Cairo94507's Avatar
    Dec 22 2015
    San Ramon Valley, CA
    I have never heard of bleeding from closest to furthest.
    '16 S3 PP Monsoon Gray/Black- DD
    '17 Macan GTS- Wife's DD
    '71 914-6 (the real deal) Toy
    Mar 24 2016
    UK
    I'd like to know this too saw it shown both ways but looking to replace my flexible lines in the next few days so would be good to know for sure.
    Can't see it making that much difference in all honesty or we would have heard about it by now.
    Senior Member Three Rings roadrunner_oz's Avatar
    Mar 30 2015
    Australia
    Quote Originally Posted by Cairo94507 View Post
    Agree, but repair manual states that is the method
    S3 Sedan - Glacier White SSP2 Black Optics trim. UniTronic S1+ & DSG Flash. Neuspeed RSe10. GFB DV+
    Dec 22 2015
    Maybe they figure you are using a power bleeder?
    Mar 30 2015
    Australia
    6.2.1 Hydraulic System, Standard Bleeding
    with Brake Charger/Bleeding Unit
    Special tools and workshop equipment required
    ♦ Brake Charger/Bleeder Unit - VAS5234- with Brake Bleeder
    Adapter - VAS5234/1-
    ♦ Brake Bleeding Tool Set - VAS6564-
    Note
    ♦ The bleeding of hydraulic system using the Brake Charger/
    Bleeder Unit - VAS5234- is described.
    ♦ A positive pressure of 2 bar required to bleed the ABS Hydraulic
    Unit - N55- .
    Procedure
    – Connect the Brake Charger/Bleeder Unit - VAS5234- .
    – Remove the protective cap on brake caliper bleeder screw and
    attach the bleeder bottle bleed hose to the bleeder screw.
    Note
    Use suitable bleeder hose. It must seat tightly on the bleed screw
    so that no air can enter the brake system.
    Bleeding sequence
    Mar 24 2016
    UK
    Quote Originally Posted by roadrunner_oz View Post
    Note
    Unit - N55- .
    Procedure
    Note
    Bleeding sequence
    I'm going with this albeit RHS & LHS reversed for RHD - thanks RR ;o)
    Mar 30 2015
    Australia
    Quote Originally Posted by Rob2k68 View Post
    not sure it makes a difference as none of the lines are shared after the ABS unit and just follows the path of least resistance
    Established Member Two Rings m3brad's Avatar
    Jul 22 2014
    Midwest
    +1
    Mar 24 2016
    UK
    Quote Originally Posted by reyoasian View Post
    wish they would just indicate driver or passenger sides instead of left/right sides...
    Good call - that would make life easier ;o)
    Mar 24 2016
    UK
    So I fitted my ECS brake lines today and am a bit disappointed with the pedal feel so I guess I need to bleed the brakes again.
    This is what I did (RHD car) :-
    Fit FR
    Bleed FR
    Fit FL
    Bleed FR
    Fit RR
    Bleed RR
    Fit RL
    Bleed RL
    I guess as soon as I disconnect a line there's a risk of air getting in so now all lines I done just doing a full bleed FR, FL, RR & RL should inprove things.
    Jul 22 2014
    Midwest
    You are correct. No reason to bleed until all lines are fit to the car. My sequence was farthest first, finishing at driver's side front. My pedal feel was/is perfect.
    May 07 2015
    2016 Monsoon S3
    Elon, NC Southeast
    Quote Originally Posted by m3brad View Post
    That's how I've always done it and did for my stoptech swap. No issues and great pedal feel.
    2016 Monsoon S3
    My slow build link - Onequick4door
    Mar 24 2016
    UK
    That's great thanks both for the reply I'll bleed again Friday.
    Mar 24 2016
    UK
    Bit of a random question, when you take the cap off the brake master cylinder reservoir does the yellow thing come out ? If so, how ?
    Thanks ;o)
    May 07 2015
    2016 Monsoon S3
    Elon, NC Southeast
    You don't need to pull the yellow cup out. Just be careful when filing the reservoir, it takes a couple of seconds for the brake fluid to work its way through it. I'm not even sure it comes out to be honest, but you don't have to mess with it.
    2016 Monsoon S3
    Mar 24 2016
    UK
    Quote Originally Posted by onequick4door View Post
    Nice one - thank you ;o)
    Mar 24 2016
    UK
    So I threw caution to the wind today and went RL, RR, FL & FR (RHD) and all is good ;o)
