Results 1 to 15 of 15
    Senior Member Two Rings BrillBlackb5S4's Avatar
    Sep 10 2015
    Rhode island
    Car rattles after scraping bottom
    Last night i scraped the bottom of my car decently bad then after 15 minutes of driving it now sounds like a rock trapped in a tin can shaking really loud. Too loud that it's embarrassing to drive now. It always does it when you hit 10 mph. Any ideas what it could be it sounds like it's coming from the drivers side. Maybe driveshaft or Bell housing?
    Veteran Member Three Rings y3ti's Avatar
    May 25 2014
    Long Beach, CA
    it's probably your exhaust.
    May 30 2015
    canada
    ^^ check your flex pipes
    Veteran Member Four Rings Tjtalan's Avatar
    Jul 19 2014
    Tulsa
    Sounds like it's time to get under your car
    Veteran Member Four Rings slowSfaux's Avatar
    Apr 26 2015
    Phoenix, AZ
    Quote Originally Posted by Tjtalan View Post
    No kidding. Could have climbed under there in less time than it took to post this thread. In all seriousness, we can all throw ideas of every possibility your way, but you taking a quick poke around under there will more than likely reveal your issue.
    Sep 10 2015
    Rhode island
    I actually did look under it i forgot to add that and, everything seems fine. Today i jacked the car up ,and everything looks fine going to have to look at it more tomorrow or later today
    Nov 16 2014
    ovid ny
    I bet it's a heat sheild. There is enough if the on our cars. But that's what happened to me a couple times now.
    May 25 2014
    Long Beach, CA
    do you have cats still installed on your car?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    I bet heatshield too. I once ran over a dead rancoon or maybe something bigger than than and I was ting-ting-tinging-ting until I bent it back.
    I've always wondered about threads like this. I mean, why not just get under it and find the problem?
    2020 SQ7- Wife's ride
    2000 S4- Working?
    Sep 10 2015
    Rhode island
    Quote Originally Posted by jimmer009 View Post
    Heatshields on downpipes? Long gone
    Sep 10 2015
    Rhode island
    Quote Originally Posted by y3ti View Post
    I have SSAC twin 1 turbo back exhaust catless downpipes but 2 rear cats
    Sep 10 2015
    Rhode island
    Yeah, I believe it's the brakes they finally let go, going to get to the bottom of it tomorrow.
    May 25 2014
    Long Beach, CA
    The cats can break apart and the pieces will just bounce in the exhaust cuz they cant pass thru.
    I had that happen to me on my Chevy.
    Sep 10 2015
    Rhode island
    It doesn't do it when i rev the car. I'll just check it out more tomorrow thanks.
    Sep 10 2015
    Rhode island
    If you guys care jt was the bolts that connect the front axels to the differential every single one of them came loose about 8 of them maybe 6
    I dont think it had to do with scrapping the bottom
