Results 1 to 21 of 21
    Dec 10 2013
    Borden, Ontario, Canada
    TTV B7 RS4 Flywheel for 2.7T
    I was browsing for flywheels and clutch setups for when I remove my trans.
    I've wanted a steel flywheel after hearing about the many shitty situations regarding Fidanza flywheels and decided it would be better to go this route.
    TTV sounded like an excellent route and people love them. I've also read much about the B7 RS4 clutch upgrade for the RA4 flywheels and thought we could adapt these to work with our flywheels.
    So, TTV beat it to the punch and is now offering two flywheels for the 2.7T. One for standard clutches and one for the B7 RS4 clutch. Linked herehttp://ttvracing.com/product/audi-s4...ufacturer=audi
    The cost for this flywheel is a measly 30£ over the standard one, making upgrading to the B7 RS4 clutch that much easier. I asked Ben if the original hardware from the B7 RS4 clutch kit would be used to bolt the clutch to the flywheel. Still waiting on a response.
    Can anyone confirm this?
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Veteran Member Four Rings mauromj's Avatar
    Jul 23 2012
    Pullman, WA
    Quote Originally Posted by Bordom View Post
    Yes, original HW works.
    I ordered 2 of these and got them both last week.
    Dec 10 2013
    Quote Originally Posted by mauromj View Post
    Yes, I can read and I already read that.
    I'm asking about the HARDWARE from that clutch kit. Does it have to be modified to work with that flywheel or can I use the hardware that comes with the kit as is?
    IG: 24_et
    Sold:
    RIP:
    Jul 23 2012
    Pullman, WA
    The flywheel bolts do not come with the flywheel. You will need to purchase the stock flywheel bolts.
    Pressure plate bolts work across both the b7 and b5. I just picked up some M8x16 at the hardware store.
    Dec 10 2013
    Alright, so as I understand:
    -OEM flywheel bolts
    -OEM pressureplate bolts
    This is everything needed to work with the B7 RS4 clutch kit and this particular flywheel?
    IG: 24_et
    Sold:
    RIP:
    Jul 23 2012
    Pullman, WA
    -OEM flywheel bolts
    ya
    May 16 2008
    WA
    I thought Canadians were supposed to be nice and polite
    Jul 23 2012
    Pullman, WA
    Quote Originally Posted by getslideways View Post
    +1
    Dec 10 2013
    Hold my beer...watch this.
    +1
    My bad man. I thought I read something completely different than what I quoted. I'm sorry for not being Canadian.
    IG: 24_et
    Sold:
    RIP:
    Jul 04 2012
    Woodbridge, VA
    Are you just buying oem b7 rs4 clutch?
    Dec 10 2013
    Quote Originally Posted by vavJETTAw36 View Post
    Parts list at this time is:
    -Luk Repset from Rockauto
    -OEM flywheel/PP bolts
    -TTV 2.7T Flywheel with B7 RS4 clutch provisions.
    -B6 3.0 01E
    IG: 24_et
    Sold:
    RIP:
    Jul 04 2012
    Woodbridge, VA
    How much you pay total for the clutch, bolts, and FW?
    Jul 23 2012
    Pullman, WA
    -B6 3.0 01E
    This is literally the exact same setup I have.
    Dec 10 2013
    It'll be about $1k just for the clutch/FW+Hardware. This is CAD BTW
    Lol really? Twinning
    IG: 24_et
    Sold:
    RIP:
    Jul 23 2012
    Pullman, WA
    The TTV flywheel is very nice. I almost dont want to run it because it looks so good. lol.
    The 1 piece design is awesome.
    Jul 04 2012
    Woodbridge, VA
    Any chatter? My fidanza chatters all the time. But I think the extra 6 lbs of the ttv should help!
    Veteran Member Three Rings gmdiluca's Avatar
    Mar 29 2013
    Ontario, Canada
    I'm running a TTV b5 S4 flywheel with AMD clutch only have 100kms on it but so far so good. I really like it, the engine so much more free revving. The only con I've found is it makes a funny noise at low rpm. Not really chatter. Kind of like a scrapping sound. But I've been told by a couple friends that most aftermarket single mass flywheels have this issue due to the hollow bell shaped back of the FW.
    May 09 2012
    Virginia
    Bumping an old thread. Will be installing a new TTV flywheel this weekend mated to a B7 RS4 PP. Does anyone have the part #'s they used for the flywheel bolts and PP bolts? If for sure they are just the OE bolts, I can look that up. Thanks.
    Veteran Member Three Rings okkim's Avatar
    Dec 07 2004
    Finland
    Yes they are OE bolts.
    Mar 01 2011
    Calgary
    This kit is OK for the TTV 2.7T>B7 RS4 clutch kit?
    https://www.ecstuning.com/b-assemble.../n90705901kt2/
