Results 1 to 18 of 18
    Apr 16 2010
    BC
    Does Audi Care cover Brake Fluid change?
    Does Audi Care in Canada cover cost of brake fluid change? I have a 14 S4.
    I'm looking at the maintenance schedule and at the bottom it says Brake Fluid – replace every 2 years regardless of mileage.
    http://www.audi.ca/etc/medialib/ngw/..._year_2014.pdf
    Veteran Member Four Rings MrFunk's Avatar
    Apr 04 2012
    MSP
    No. They check it only. If they replaced it that would be explicit.
    Mar 21 2015
    My dealer said they would replace my fluid as part of Audicare at my 25k service. I would ask the dealer if I were you.
    Veteran Member Four Rings B8 S4's Avatar
    Apr 27 2014
    United States
    My dealer replaced mine for free for my 45k audi care
    Dec 05 2014
    Saskatchewan, Canada
    The wife's Q5 had the brake system flushed as part of the audi care here in Canada.
    Oct 13 2009
    MN
    Yes its covered. They changed mine at my last service.
    Jul 14 2013
    British Columbia, Canada
    Quote Originally Posted by purelife View Post
    Yes, I did mine at Capilano for my 85,000KM service and they replaced it as part of Audi Care.
    2011 Phantom Black Effect S4 6MT Prestige, Sport Differential, Flat-Bottom Steering wheel with red stitching, RS4 Aluminum pedals, 034 Transmission mount, Roc-Euro Intake, Roc-Euro Short Shifter, 90mm AWE Touring Exhaust with stock downpipes, Unitronic Stage 2+, JHM 179mm Overdrive Crank Pulley, MercRacing heat exchanger, Stasis rear sway bar, CR-15, Gloss Black RS4 Grille, Sachs Xtend Clutch, 034 Density-Line Motor Mounts, Bilstein B12 Suspension Cup-Kit
    Veteran Member Four Rings AudBoost's Avatar
    Apr 05 2005
    Tampa, FL
    I have an appointment next week for my final Audi Care service and they are flushing the brake fluid.
    2016 S6
    Veteran Member Four Rings Johnnycash's Avatar
    Jul 31 2014
    2015 Hyundai Genesis. 1995 impala ss
    Mpls, Mn.
    dealer replaced mine at 35k service for free, had audicare.
    2011 QGM w/black optics, EPL stg1, HRE p43sc w/pss, b-12pro-kit, 034 trans mount, cts intake, stoptech drilled/slotted, akebonos all around, vmr 710 w/nokian r2s, stock rotor wheels w michelin as3+, autostyle custom floormats, 3m paint protection on entire front.
    Veteran Member Four Rings Acejam's Avatar
    Dec 22 2009
    MA
    Just had mine flushed via AudiCare at my dealer for my 25k service. It should be included in the USA.
    2014 Brilliant Black S4
    DSG / Prestige / Black Optics / Sport Diff / B&O / Carbon Atlas Inlays / Magma Leather
    Modifications: APR Stage 2 Dual Pulley + TCU, JHM 187mm Crank Pulley, APR Open Intake, APR CPS, AWE Touring Exhaust (90mm Silver), KW HAS, 034 Rear Sway, 034 Mount Inserts, Hawk HPS 5.0, S5 Rotors w/ PS4S (Summer), Peelers w/ LM-32's (Winter)
    Senior Member Two Rings osspasha's Avatar
    Sep 18 2013
    yes
    2013 S4 B8.5
    Don't let fear and common sense stop you
    Veteran Member Four Rings MVR 155's Avatar
    Apr 04 2013
    2018 Audi S6, 2015 GMC Yukon Denali and 2002 Corvette Z06
    Bartlett, IL
    Mine was flushed/replaced as part of my 25K mile service last fall (I was only at 22K but was 1 year from my previous service) as I have the Audicare service policy which is good to 45K miles.
    2018 S6 Prestige, Glacier White/Black, S-Sport, Driver Assistance, Black optic, Carbon inlays, Cold weather, Vorsteiner VFF 103's in carbon graphite.
    2002 Corvette Z06
    Mar 20 2015
    McKinney,TX
    I've had Oil and DSG fluid replaced for free
    Mar 21 2015
    Quote Originally Posted by EIAlfonso View Post
    That is definitely on the Audi Care list of things to be done. Those are not in question.
    Veteran Member Four Rings jokingjimmy's Avatar
    Oct 20 2014
    Mk2 TTS Raodster Scuba Blue
    Pittsburgh, PA
    Had mine flushed and replaced at my 25k. Although they then replaced my rotors and pads due to brake squealing. Tried to talk them into doing the SQ5 Brembos, but they didn't bite lol. But hey, I'll take brand new front brakes at 25k any day, no complaints!
    Everything graciously mispelled by Apple
    Current: 2013 TTRS Suzuka Grey
    Also: 2011 TTS Roadster Scuba Blue
    Previous:
    2014 S4 6MT Nogaro Blue Pearl
    2016 TTS Sepang Blue
    2013 A5 Midnight Blue
    2013 VW GTI DSG Grey
    Sep 05 2012
    In Canada too - they did it for me, but I had to remind them. When they saw it written like that they did it no problem. They also needing some more repeated reminders to do the DSG service when it came due.
    Veteran Member Four Rings GeoJoe's Avatar
    Jun 08 2012
    2022 Q7, 2018 Q5, 2016 Porsche GT4, Subaru Sambar, Honda Acty Van and a 2018 Tundra Loooooooong bed
    ATL GA
    Once
    Dec 07 2014
    Mn
    Mine was just flushed at the 15k.
    Sent from my LG-H901 using Tapatalk
    2014 S4 DSG///Unitronic Stage 2+.
