    Active Member Two Rings allenb's Avatar
    Aug 02 2014
    99 Avant, 98 Passat, 63 VW dunebuggy
    Lake Orion, MI
    Thumbs down Brake caliper sliders seized
    Hey guys my rear brakes completely locked up about a week ago. Figured the caliper piston was just locked out or it was something to do with my E brake. Ordered pads and rotors cuz they were due and id assess the damage. Turns out the brake caliper sliders are locked out and will not budge. One spins with a wrench but will not push in but the other will not spin or push in. Am I missing something here? Is there a way special way i need to push them back in? or do I need new rear caliper brackets? Thanks for the help in advance.
    Allen
    C5 Avant
    IG: allen_union
    Oct 02 2013
    05 allroad FBP 6mt, 06 VW Passat Komfort, 08 VW Touareg V8 FSI
    pennsylvania
    Rears call for a special tool. The piston needs to be spun/twisted to retract back in. You can rent said tool from most local autopart stores or I believe Harbor freight sells a kit for a reasonable $40.00.
    Veteran Member Three Rings Sparkstack's Avatar
    Oct 13 2012
    Bits of a 2003 S6, 1990 turbo Miata, 1996 LS400
    Naperville, IL
    Is the op talking about the piston or the sliders?
    My sliders were seized also. Easiest way to try and remove them is to use a threaded rod and screw it into the bolt hole. then use a socket large enough to go over the slider and rest against the caliper. Finally with a large washer and a nut on the other end you can pull it out.
    2002 S8 - Daily driver.
    2003 S6 - R.I.P. (parting out - PM me if you need anything)
    1996 LS400 - Wife's whip. Thing is bullet proof.
    1990 Miata with FM Turbo - Pocket rocket.
    Aug 02 2014
    Lake Orion, MI
    Used a friends torch. Did the job. Then cleaned the sliders extremely well and loaded them up with grease like new. But thats a really good idea Sparkstack I will def have to try that if it ever happens again.
    Allen
    C5 Avant
    IG: allen_union
    Veteran Member Three Rings suth31's Avatar
    May 16 2014
    2002 A6 2.7T 6-speed, 2003 350Z supercharged 6-speed, 2001 Hayabusa, 1995 Bronco
    massena, ny
    I had the problems of pins drying out and sticking multiple times. I decided to buy new slide pins from autozone for 8$ each pair. I am hopeful
