Results 1 to 6 of 6
Thread: Loosing my mind
    Apr 27 2016
    Nova Scotia,Canada
    Angry Loosing my mind
    2003 Audi A4 1.8t fwd , car was into the shop to diagnose a misfire . car stutters/bogs under heavy acceleration. ( MISFIRE IN CYLINDER #1)
    Already tested:
    Coil packs
    Spark plugs
    Injectors
    Fuel pressure
    Fuel injector wiring
    Wiring harness from DME to ignition coil
    Fuses and grounds
    Mods:
    FMIC
    test pipe
    stage 1 flash
    aftermarket injectors
    Veteran Member Four Rings cjt671's Avatar
    Dec 14 2014
    B5 S4 sedan, 2018 Q5
    PNW
    Maf
    Dec 14 2014
    PNW
    Unplug and see if it still misfires
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Have you physically swapped the coil pack and injector from cylinder #1 to a different cylinder?
    With everything you have replaced and the misfire stays with the #1 cylinder it's time to run a compression test on that cylinder.
    Apr 27 2016
    Nova Scotia,Canada
    still is misfiring , mechanics spent 10+ hours searching say it could be my Eurodyne stage 1 ecu and i should replace it, would this cause these issues??
    Dec 28 2006
    Western Maryland
    Quote Originally Posted by KFrancis14 View Post
    I really doubt it would be a tune issue if the misfire is consistently on the same cylinder. If the mechanic is sure it isn't a a plug/wire/injector/compression issue it may be a faulty ignition driver in the ECU Clicky click.
    The ignition drivers are pretty cheap. Here's how to remove/replace a chip from the ME7 controller. The ignition drivers require the same procedure.
