Results 1 to 8 of 8
    Established Member Two Rings aswisscheese's Avatar
    Mar 19 2014
    01 yukon denali (wifes rig) 77 F-150 (memories in my heart) 96 A4
    United States
    Car is cutting out HELP
    Ok so hears where im at. My car is intermittently cutting out. It just up and dies while driving. When it does the car cranks over like no tomorrow but wont fire up. Then after a few minutes it will fire up and drive. It might go a few days without cutting out or like 30 minutes. Its only while driving and it is not consistent to throttle. The fuel pump is two years old from JHM fueling kit. The car is stage 3. I have replaced the fuel pump relay and no change. While cranking over when it wont start, I put my ear on the pump access cover and it sounded like the pump was running. Im so lost. The only code that is coming up is P1556 Negative Deviation. Or 17964 Charge Pressure Control.
    May 16 2008
    WA
    those codes are usually related to boost leaks, the next time it happens unplug the maf and try starting it. Leaks in the system will deliver different amounts of air to the engine than the MAF has calculated and cause it to run poorly.
    Jul 04 2012
    Woodbridge, VA
    Yep ^ is right. Motor is saving itself from damage.
    Pressure test the system. Probably a TBB or IC hose popped off a little.
    Mar 19 2014
    United States
    Thank you I will do both things. Question when driving it is totally fine power wise boosts strong would it still be a leak. Could it be the N75 valve?
    38 Cars and Counting 9701.596
    Mar 19 2014
    United States
    I also say the car only cuts out at cruising speed. Actual speed does not matter but not under hard acceleration.
    Dec 20 2015
    If audi is like any other car that would make sense, it will go into open loop under WOT and likely not even rely on the maf.
    Established Member Two Rings BOO$TedS4's Avatar
    Oct 06 2015
    96 jeep Cherokee sport, 95 Mitsubishi Eclipse GSX
    Williston ND
    My car just started cutting out as well. I throw no codes and my air to fuel and boost is normal. Any ideas?
    Mar 19 2014
    United States
    Quote Originally Posted by BOO$TedS4 View Post
    I have a fuel pressure gauge tied in and a volt meter on the fuel pump but my car has not cut out in over 5 weeks. Im still hunting. I didmy CPS and it was better for 3 days then no joy again. But again thatwas weeks ago
