Hello again Audizine. Lately while driving I've been noticing the shifter has some wiggle/ movement while in 2nd gear. I've read posts on this forum and others about the same thing. Read everything from possible synchro going out to this being normal. The car is a 03 A4 with a manual 5 speed. The car has 190,000 miles on it. Engine was replaced with a rebuilt one approximately 10,000 miles ago, I got the old engine from the seller. I already purchased Audi gear oil from ECS to do a trans fluid change...don't know what kind of fluid the guy used in the transmission. He also replaced the clutch when he did the engine, I got the old clutch to. All other gears have no movement and it seems to shift good between gears. I am planning on changing out the snub mount. Just wanted to get some opinions if this is something I should worry about, or if it's normal? Also any suggestions if there is anything I can do to keep it from wiggling around would be appreciated. For some reason it draws my attention. I've read about changing mounts, installing a short throw shifter, etc. looking for some experienced opinions. Thanks!!
