Results 1 to 7 of 7
    Veteran Member Three Rings Osher67's Avatar
    Nov 03 2012
    California/so cal
    Brake lights won't go off
    I've been trying to figure this out.
    My brake lights wouldn't go off so I figured it was the switch I grabed two when I was at the salvage yard other day neither make a difference pressed or unpressed only thing that makes them go off is when I unhook the switch from the harness.
    I relocated my abs but I did not cut up any of the stock wireing I don't think it's that but I don't know where to look exactly.
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Nov 03 2012
    California/so cal
    I wonder if it could be from my headlights not being on the car...
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Senior Member Three Rings MoparFreak69's Avatar
    Jan 31 2015
    2005.5 Audi A4 Avant 2.0T quattro
    Boise Id
    My wife's B7 had an issue where during the night the brake lights would come on and stay on. Tried a used switch, no luck. Replaced with a new switch and never had a problem since. You probably got a couple switches that are no better than what you already had.
    Nov 03 2012
    California/so cal
    Quote Originally Posted by MoparFreak69 View Post
    Thanks for the info I read somewhere they had a recall for switches I don't know if that Atrubutes to our cars or not, but I'll go to the dealer tommorow and see if a new switch dose the trick.
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Dec 19 2011
    Colorado Springs
    could have smoked your CECM.
    It'll make your cars lights do all sorts of weird shit if its damaged in any way. typically though they fail from water damage.
    '12 GLI EFR 7163 - '16 S3 IE Stage 2
    Nov 03 2012
    California/so cal
    Quote Originally Posted by B6A4Dave View Post
    Where is the cecm?
    -Josh
    2002 01A Quattro
    K04-15 (Unitronic)
    Veteran Member Three Rings Let it snow's Avatar
    Aug 24 2014
    02 1.8TQ Sport 5 speed, 05 1.8TQ 6 speed
    Vermont
    If you disconnect the switch and the lights go out it is the switch. It is a self adjusting switch. A used switch needs to be reset before installing. Get that new switch and be done with it.
