i have a 2005 avant 1.8t just got it recently.
yesterday i took a passenger power seat from a different a4 that i have and installed it into the car which had a non power seat before.
i put the back bolts in first and moved the seat back and when it stopped moving i thought it was all the way back. but when i wanted to move it again it didnt work in any direction
i tested all the motors and tested the whole seat in the other car and it all worked.
i did some research and found out that it is not that uncommon that the driver seat doesnt work,and the problem is usually the control module under the driverseat. but my driver seat works good. does anyone know if the passenger seat has a module like that too and where it is? because it doesnt work off of the driver module.
also lots of motors for the HVAC system dont work
i checked some of the motors and they worked but they dont on the car... could this be related somehow with the seat? through some kind of module? did anyone have similar problems?
8 Faults Found:
00710 - Defroster Flap Positioning Motor (V107)
41-00 - Blocked or No Voltage
01272 - Positioning Motor for Central Flap (V70)
01809 - Actuating Motor for Temperature Flap; Left (V158)
01810 - Actuating Motor for Temperature Flap; Right (V159)
01274 - Air Flow Flap Positioning Motor (V71)
00716 - Air recirculation Flap Positioning Motor (V113)
41-10 - Blocked or No Voltage - Intermittent
01171 - Temperature Sensor; Passenger Side Heated Seat (G60)
30-00 - Open or Short to Plus
01206 - Signal for Duration of Ignition Off Time
27-00 - Implausible Signal
