Results 1 to 18 of 18
    Sep 17 2015
    Austin, TX
    Headlight washers? I had no clue my car had them
    One day while in the driveway I pulled the lever to spray the windshield and noticed washer fluid was splashing at the end of the hood. Sure enough some sprinkler-looking nozzles come out of nowhere just below the headlights and spray the headlights. I'm not sure they do any good but it does look very cool watching it.
    Anyways just thought sharing it.
    2015 S3 Prestige | Sepang Blue | Pinnacle 30 Tint | Suntek PPF |
    Mar 21 2015
    On the S4 they only operate while the lights are on. Don't forget about them after you wash your car.
    Senior Member Two Rings UWbadger91's Avatar
    Apr 03 2016
    Wisconsin
    Quote Originally Posted by six.machete View Post
    Is yours a prestige? I see the cutouts on my bumper but have never noticed them come on. I've only had the car for about a month though. I have a premium plus.
    Sep 17 2015
    Austin, TX
    Yes. It's a prestige. Give it a try. I don't remember if my lights were On tho.
    Active Member Two Rings s3clusion's Avatar
    Apr 16 2015
    Houston
    Yes, headlights have to be on.
    Apr 11 2012
    lol, it was weird the first time they went off for me too, I was like wtf is that noise and where is that extra water coming from. It also blurred my headlights a little bit for a little while. seem kind-of useless.
    Nov 16 2013
    doe
    you wouldnt think they were useless if you got snow and slush like we do in the northeast. I think they are mandatory in canada and also in europe.
    Sep 17 2015
    Austin, TX
    Quote Originally Posted by OneOfOne View Post
    Very good point.
    Dec 11 2015
    Syracuse,NY
    I don't think I have it....2015 A3 Premium
    2015 black A3 Premium---APR stage 2+DSG tune, APR carbon fiber intake, Bilstein B16 PSS10. USP downpipe, Milltek non-resonated catback. emmanuele design carbon fiber rear spoiler
    Mar 21 2015
    Quote Originally Posted by ximo03 View Post
    Just look at your front bumper under the headlights for a 2x3 rectangle
    Dec 11 2015
    Syracuse,NY
    I have that but I highly doubt that is a fake one
    Mar 21 2015
    I was reading a post yesterday that said the A3 didn't have headlight washers, don't know though. Turn your headlights on and pull the stalk to wash and you will know if they work.
    May 06 2015
    United States
    They are more trouble than they are worth in extremely snowy/cold climates.
    When temperatures dropped down during the polar vortex, windshield washer fluid froze in the lines, breaking the pop out washers.
    Even before the weather gets that cold, if you're driving through a blizzard (i.e. Regular lake effect conditions) you'll find that they tend to get clogged from the ice that will build up along your leading edge of your car. Expensive to replace, easily broken, minimal to no benefit to visibility. (If it's cold enough to freeze your headlamps, it's cold enough to freeze your headlamp washers)
    Senior Member Three Rings roadrunner_oz's Avatar
    Mar 30 2015
    Australia
    I disabled my headlamp washers. Suppose it depends on your climate, but it is very annoying when they spray soapy water over a clean hood
    S3 Sedan - Glacier White SSP2 Black Optics trim. UniTronic S1+ & DSG Flash. Neuspeed RSe10. GFB DV+
    Mar 21 2015
    Quote Originally Posted by roadrunner_oz View Post
    Mine squirt windshield washer fluid
    Mar 30 2015
    Australia
    exactly, all over the hood.
    The cycle is to use the headlamp washers every x times the windshield washers are used. I think that the default is to use the headlamp washers every 5th windshield washer cycle. I changed it in VCDS to 1000. The other alternative to stop the headlamp washers is to put the lights in off position prior to using the windshield washers.
    Mar 21 2015
    I was poking fun about your soapy water coment lol. . I'm well aware of how they work and you can shut them off completely with vcds.
    Jun 05 2015
    Thanks for the insight. I was looking for a way to disable these headlight washers.
