Results 1 to 15 of 15
    Apr 22 2013
    maine
    High beam dash light
    Just picked up a 2016 and when I put on high beams, I see no blue dash light. Is this normal? I had a 2013 that had blue light.
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    Probably hiding behind steering wheel rim. I can't see a cel nor my traction light when deactivated based on the angle and depth I have my wheel positioned to
    Sent from my Nexus 6P using Google's ProjectFI
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Apr 22 2013
    maine
    Quote Originally Posted by theswoleguy View Post
    Nope, but I'll look again. But yeah, steering wheel gets in way of fuel gauge for sure
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Quote Originally Posted by jzinckgra View Post
    Take it to dealer ,that is what the warranty if for. Are you sure the headlights are on? The auto setting is very wired . But if it is night time , and you can,t activate brights you have a problem that dealer will have to fix. Blue light on dash will come on when headlights go from normal to bright based on your activation with turn signal stalk, you push it forward.. You pull it back to flash.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
    Apr 22 2013
    maine
    Just checked again and nothing works, including blinkers. Would this be a simple fuse issue?
    Dec 07 2012
    Atlanta, GA
    Or something coded wrong if you played in vagcom. I did that by mistake on my 2012 S4. Would not activate high beams. Changed wrong bit/byte doing lighting mods
    Apr 22 2013
    maine
    I don't have vagcomm. Just got the car yesterday with 400 mi.
    Mar 21 2015
    Look into Carista. You need an obd adaptor and the app to do code resets and a bunch of other cool tweaks. 60$ all in.
    Aug 22 2014
    bloomfield,ct
    just take it to dealer.
    Apr 22 2013
    maine
    One other non related Q. Is the screen resolution on non nav mmi of lower res then nav? I had a 2013 nav model and all the screens for radio, Sat, car, etc were superior. The non nav s4 I have is orange on black but very pixelated.
    Dec 07 2012
    Atlanta, GA
    I do believe there is higher resolution on nav units.
    Apr 22 2013
    maine
    Quote Originally Posted by jygesq View Post
    Apparently gauge cluster is burned out. Diagnostic shows a bunch of low voltage errors. He said he's never seen this before. Nice.
    Apr 22 2013
    maine
    One other thing. This car was on dealer showroom floor for some period of time. When I was looking at it and dealer went to pop trunk, the trunk wouldn't open. Turns out battery was dead. This seems odd. Not sure how long car Sat without starting, but seems odd battery would be dead even if it sat for a few months.
    Established Member Two Rings jjslegacy's Avatar
    Oct 14 2006
    2015 S4/2013 Q7
    Cleveland
    I would imagine that is from people getting in and out and turning radio on etc. Seen that before on cars that sit in the showroom for months and batteries aren't maintained.
    JJ
    Aug 12 2013
    Lexington KY
    That's an interesting point. THese cars do some really weird things when the battery's low. I mean really weird. I'd not be surprised if that was the cause fo the dash not working and if you got the battery more juiced up and or replaced, it would work itself out. I've seen them no unlock or open doors due to battery, etc etc. crazy stuff that just seems unrelated.
    If they're good with flipping out the dash, have them do it but I'd also have that battery load tested to make sure nothing's wrong with it.
    - - - Updated - - -
