What's the best way to tighten the UCAs at the correct torque and with the appropriate preload? I used the angle measurement to the top hat (70 -81 mm) from the service manual and a proper torque wrench (Bentley says 50 nm), but now the bushings are starting to fail again. I only have about 10k on these and they're Lemforder replacements. Kind of pisses me off to have to do them again.
I can't see how you could reach these bolts to torque once mounted and with the wheels back on. Maybe I could get to them with a spanner wrench on ramps, but no way I can fit my torque wrench in there. Does removing the Jack stands and jacking up the hub work any better? I'm mildly lowered but not to the point of needing adjustable control arms.
