Results 1 to 3 of 3
    Established Member Two Rings m47thew's Avatar
    Feb 03 2016
    2001 Sierra 1500 HD
    Quattroland, Canada
    Custom tuners these days?
    As I continue to prepare and research for my B5 RS4 build one of the biggest decisions, as most of you know, is the turbos. And one of the major factor affecting turbo choice is available tunes. I've been looking at K04's or F21's so far as it is really more than enough power for my needs and the car is my DD so reliability is a big factor. For now I'd like to put a feeler out there and see what options we have for custom tunes. I'm in Edmonton, Canada but I would assume that with the right software and tuners my data logging can be sent over and the tune can be customized to best fit a particular build. I know that there are always generic tunes provided by some of the bigger companies but every car is different and therefore every tune should be too. I would also prefer to build that relationship in the case of further developments, upgrades, etc.
    Thanks in advance for your advice/input.
    2001.5 S4 - Milltek SuperDual Exhaust, GIAC Xplus tune, 034 adjustable upper control arms (front and rear), density line lower control arms, front sway bar end links, rear sway bar + reinforcements, KW V3 suspension...
    Veteran Member Three Rings Corradovolksb's Avatar
    Aug 29 2013
    2018 VW Atlas
    Phoenix AZ
    Sent you a pm
    May 05 2011
    Edmonton
    I'm in Edmonton and would be interested as well
