Results 1 to 6 of 6
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    2006 C6 3.2 - oil flooded spark plug hole - valve cover gasket
    Changing plugs, I found the spark plugs submerged in oil.
    Purchased valve cover gaskets, but found out that there are TWO (2) what I would call valve covers that have the potential to leak and let oil get into the spark plug hole.
    One is the main cover under the plastic valve cover.
    But then there is a second one below (likely not called valve cover) that ALSO has a seam with the spark plug hole.
    Do I need to change BOTH. I only ordered the upper one (than pulled up under valve cover gasket search).
    Aside from valve cover gasket letting oil leak onto the plug hole: what else should I check?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Senior Member Two Rings Saifxnyc's Avatar
    Oct 19 2012
    Pittsburgh, PA
    I changed the one on the top they come in a pair of two and it resolved my problem the middle spark plug had some oil on the passenger side. No issues ever since and it's the same spark plug that is in there. I have to change them at some point.
    Jan 30 2014
    1st gen Q45s
    FL, USA
    well the vcg is easy (relatively speaking). the second seam is an RTV only seam between the cam girdle and the head. lotta work to reseal those.....
    Feb 20 2010
    Brighton, MI
    Sure hope it was the top one, and not the 'cam girdle'.
    How to check on the 3.2 that the underlying cause is not over pressure in the crank vent system?
    https://www.dropbox.com/s/v9ui9gh97v..._2917.JPG?dl=0
    05 Golf TDI
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by vtraudt View Post
    Not familiar with the PCV system of 3.2 (and the 3.2 in general). But have had a few 2.0T FSI engines with PCV related issues.
    What to check/verify/test on the 3.2 in this respect?
    05 Golf TDI
    Jan 30 2014
    1st gen Q45s
    FL, USA
    I suspect the PCV issues on this series is rooted in the breather/separator.
    so for 'overpressure' maybe start by removing the oil fill cap (could splash) at idle? if properly scavenging (under vacuum), I'd expect a blip in idle speed and an adjust on the STFT (if you are set up to monitor it).
