Hey guys,
For those of you who have the RS4 grille with a DETACHABLE rings bracket…. I have a few questions and need some help here.
I purchased an RS4 grille (pictured below) that came with the rings bracket detached. I tried messing around with it to no end, but couldn’t figure out how make that bracket stay on the grille.
My initial assumption was that the bracket had broken off the grille (not knowing it’s detachable). The seller of the grille then advised me that the Audi rings must be attached to the bracket first in order for the bracket to attach to the grille – is that true? I’ve been sifting through hundreds of picture of RS4 grilles, brackets, and rings. There is nothing from what I see pictures that would appear as if the rings would change the attachment mechanism of the bracket onto the grille. In other words, I don’t see anything in the rings emblem itself that would somehow affix the bracket onto the grille.
I’ve already wasted a whole evening removing the bumper and having to abort after not being able to make the bracket stay on the grille. Though admittedly I didn’t try (didn’t know at the time) that supposedly the rings must be attached to the bracket first, before attempting to attach the bracket to the grille.
Before I go waste another few good hours in vein, can someone with detachable rings-bracket grille confirm that the rings indeed need to be attached to the bracket FIRST, in order for the bracket to attach to the grille?
Thank you in advance
Appreciated
