Results 1 to 7 of 7
    Apr 29 2016
    Pittsburgh, PA
    S4 B7 doesn't start after short circuit, help
    Hi guys, I had short circuit in my 2007 S4 B7
    Now it doesn't start... And cluster display doesn't show any information. All fuses checked.
    Please, take a look at attached video.
    What can be wrong?
    Thanks in advance.
    https://youtu.be/hDlwjJuNqHw
    https://youtu.be/5LHf9TxnLaw
    Apr 18 2012
    1995 Toyota Land Cruiser (FJ80/FZJ80)
    Central Texas
    how did it short?
    it looks like there may be a problem with the ECU's power. a wire or connector could have blown, but my money is on a blown fuse. there are two other places you should check for blown fuses besides the main panel: under the driver's footwell there are several large 30-40A fuses, and under the ECU there are 5 fuses (3x 15A 1x 20A, 1x 40A, if i recall). the driver's footwell is easy to get to, just a couple screws to remove the cover.
    the ECU is a pain to get to, though, since you either need some incredibly deft tools or you need to remove the wiper arm to get to one screw. however, you can probably do it in less than 30 minutes with a wiper arm removal tool ($15-25), just make sure to put some penetrating oil at the base of the wiper mount before you start.
    - emilio
    Apr 29 2016
    Pittsburgh, PA
    Thank you!
    I just checked this fuses:
    I will check rest of them on weekend.
    I hope just need to replace fuse
    Nov 12 2015
    Oregon
    well for starters, your battery seems dead. have you charged it up or tried to jump it?
    My build log
    Apr 29 2016
    Pittsburgh, PA
    Quote Originally Posted by VinnysS4 View Post
    Not yet, I will do it on weekend
    Nov 12 2015
    Oregon
    what kind of short circuit did you have?
    My build log
    Apr 29 2016
    Pittsburgh, PA
    Thank you guys for all your posts. I tried to jump it and the car was running! But I need to replace the battery...
