Results 1 to 40 of 49
    Veteran Member Four Rings Dannydyn's Avatar
    Dec 20 2013
    Mercedes Benz ML350
    Headlights reflectors question (e-code style)
    To those who modded their headlights to get the e-code look: Is it possible to purchase just that reflector as a stand-alone part? Paying $1,200 just to delete the amber reflector (is there anything else I’m missing?), is a complete waste of money IMO, especially when you can at the very least, DIY it in some form of shape.
    I have seen people wrap them in vinyl, spray them in smoke/dark color, wrap the out headlights from the outside, etc….
    I’ve tried searching but came up empty handed: Out of all the performance vendors and forum sponsors out there, there is not a single one that sells these reflectors separately for a quick swap? – Even as an aftermarket item???
    Sent from my Samsung Galaxy Note 4
    2014 S4 | 6MT | Estoril Blue | Lunar Alcantara | Rotors
    AWE S-Flo | Bilstein B8 | H&R OE Sport | RS4 Grille | 35% Tint
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Light output is supposed to be better as well.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
    Veteran Member Four Rings jmeenach's Avatar
    Mar 17 2014
    Los Angeles, CA
    Quote Originally Posted by Dannydyn View Post
    I think there are vendors on ebay that sell replacement reflectors But as mentioned by blackfunk, there is more to the e-code light than just the reflector. The lens itself is smooth, whereas the US spec has little bumps, which blurs the cutoff.
    Pedal Responce Team's expedition ace/Banana Responce Team first responder
    2013 B8.5 A4 Quattro. RS grille / 20" 'Flower Petal' reps / AFE / VCDS mods / more to come...
    instagram
    Oct 14 2012
    Empty...for now...
    SE PA
    Quote Originally Posted by jmeenach View Post
    FWIW, take it from me, the cutoff provided by the Euro-spec headlights isn't so great either. Probably better than the US-spec version (although I never did a side by side comparison), but not crisp by my standards.
    SOLD 2015 Daytona Gray S4
    Veteran Member Four Rings theswoleguy's Avatar
    Dec 07 2012
    Atlanta, GA
    Quote Originally Posted by SteveYem View Post
    is it the projector or the clear lens that gives it that sharp cutoff with color flicker or a combo of both? Got a pic Steve?
    '01 Audi TTQ Roadster: QED motor, Pag 35R vband, spec twin, E85, Sold
    '03 GTI: Gutted, Parted & Transplanted
    '04 F250 6.0: 72mm turbo, 60 psi stupid fast for 8k lbs, Sold
    '15 Audi S4: Stock, S-Tronic, B&O, NAV, ADS w/ Sport Diff, Smart Key, glacier white w/ magma red, 19" Shamrocks lol
    Mar 17 2014
    Los Angeles, CA
    Quote Originally Posted by theswoleguy View Post
    I was referring to the projector lens when I said lens. My bad.
    instagram
    Veteran Member Three Rings csaudis4's Avatar
    May 11 2010
    If you're handy and willing enough to open up the headlight I don't see why not wrap or spray the reflector yourself. I, too, was searching for "readied" reflector but then ended up wrapping mine for a reversible solution. My experience was that opening the assembly was more technical than wrapping.
    As to seller, someone was selling transparent reflector on the forum for a brief moment but the volume didn't justify the cost so he quit shortly after. That's when I decided to do it myself. I also remember finding a commercial website selling these reflectors at a robbery price. Just can't find it after 2 years. You don't want to get charged that much anyway...
    N6p and Tapatalk
    2010 Ibis|Magma & CF|6MT|Prestige|Sport Diff|B&O|Drive Assist
    Past PC Gunmetal OEM rims, Strat SSK, WeatherTech Junk
    Now 20% sides, 80% ceramic, Lamin-X head/tail, PPF, S/C emblem, Aries 3D, RS4 pedals, VMR V701GM, APR StgII+, EC Shifter, EC AK, oCarbon, Roc-Euro Intake, 034 Trans Mount, RED Start/Stop, Ti-Carbon Reflector, Audi Hold Assist
    Future Rear Sway, B8.5 Wheel
    New Home 6/10/2016
    Veteran Member Three Rings silverf0x's Avatar
    Dec 14 2015
    Montreal, QC
    I got this answer to pretty much the same question here:
    http://www.audizine.com/forum/showth...1#post11536362
    Murdered B8.5 S4
    Build Thread
    Senior Member Two Rings Shaun Perry's Avatar
    Jan 02 2013
    San Ramon, CA
    I took my car to a local member, and he did the J-code mod for me.
    From my readings yes the e-code lamps have better projectors whether that induces more output, or a cleaner cut off, and the Amber reflector is then a clear reflector.
    I requested to wrap my ambers in this carbon vinyl, he also cleaned the inside portion of the headlamp very thoroughly as there was this unsightly residue/dirt/grease inside. And then a few days later I used VCDS to turn off the Amber light inside of that reflector(although once it was wrapped the Amber light was virtually unseeable but I did the deactivation anyway)
    $1,200+ compared to $80 a headlight was a trade off I'm completely happy with. My main thing was to clean the inside of that residue but the Amber being wrapped was a great plus so I said what the hell.
    If any of you live here in nor-cal I'm happy to share the contact info of the member that did this for me.
    Dec 14 2015
    Montreal, QC
    I'm in a similar situation I would love to have clear reflectors and black housing, I don't really care about the "better" lighting that the ecodes provides since I don't really use my car at night.
    I don't want to wrap/pain the reflector as Policemen are really strict about the reflector being present and orange over here so I want to play on the fact that I will still have reflection and with the amber led behind I can still show the right color when the car is ON.
    I hope I find a way to do this without having to buy eCodes since 2000$ CAD seems like a lot for two reflectors..
    I don't know if I could simply put the reflectors in some solvent or other solution to remove the orange part??
    Murdered B8.5 S4
    Build Thread
    Dec 20 2013
    Mercedes Benz ML350
    I’m going to give this PlastiDip special color a shot. Sounds like it does exactly what we’re looking for (i.e. keep the reflector’s texture, while smoking it out).
    https://www.dipyourcar.com/products/smoke
    PLASTI DIP® SMOKE IS A SEMI-TRANSLUCENT GREY PRODUCT. CAN BE USED FOR TINTING OR APPLICATIONS WHERE A DARKER, BUT SEE THROUGH FINISH IS DESIRED. CREATES A MATTE FINISH - NOT GLOSS.
    Dec 14 2015
    Montreal, QC
    Just has an FYI: Having seen this on taillights and even headlights on rice cars over here, the result is pretty matte. You can easily see the difference:
    Murdered B8.5 S4
    Build Thread
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by silverf0x View Post
    I'll apply 50 coats then...
    Dec 14 2015
    Montreal, QC
    Well you'll still end up with a matte finish. And after 50 coats it will not be translucent anymore. You're better off saving yourself some time and go with 4-5 coats of blacks..
    Murdered B8.5 S4
    Build Thread
    Veteran Member Four Rings DannyDeez's Avatar
    Sep 11 2004
    16 Q5
    Westchester, NY
    I love my ecodes. Worth every penny.
    2016 Monsoon Gray Q5 Prem Plus, Tech, Sport, 19's (Click for thread) (Sold)
    2012 Brilliant Black S4 Prestige, 6 speed (Build) (Sold)
    2015 Brilliant Black A3 Cab (Sold)
    2006 Quartz Gray A4, 6 speed (Sold)
    2013 Phantom Black S5, 6 Speed (Sold)
    2001.5 Nogaro S4, 6 Speed (x2) (Sold)
    Dec 14 2015
    Montreal, QC
    I so wish we could get in contact with the reflectors manufacturer (if third-party)..
    To people who bought eCodes:
    If it weren't for the added lighting quality (let's say you would keep them off all the time). Would you still have bought them?
    Murdered B8.5 S4
    Build Thread
    Dec 20 2013
    Mercedes Benz ML350
    Btw, DipYourCar sells a gloss, clear coat spray as well. You can spray that on top of the smoke. Also, don't forget that the reflector is behind a glass cover, which provides further 'gloss' effect. I'm going to give this a shot.
    Senior Member Two Rings dyl0n's Avatar
    Dec 14 2014
    New Orleans, LA
    That cutoff
    B8.5 S5|P+|DSG|Sport Diff|APR Stage 2+|APR Stage 2 Intake|ST Coilovers|20x9.5 RS5 OEM Rotors|AP Racing 370mm BBK|Pirelli P-Zero 275/30|Ecodes|B&O
    AWAITING BOOST SEASON
    Veteran Member Three Rings $nooze's Avatar
    Jan 02 2012
    if your going to mod the headlight yourself and want a better cut off on the headlight beam(your doing that much work may as well go all the way) look into the sti lenses. theres a guy that is local to the b7 forums, he was doing headlight work and chose to upgrade the lenses to the "sti" lense and light output was phenomenal. as well as for the side marker (amber) delete you can look into european forums and see if there are any damaged headlights that still have that portion intact and make an offer for the piece/connecting hardware.
    '11 B8 S4 6mt
    Oct 14 2012
    Empty...for now...
    SE PA
    I'm actually not sure what it is that provides that crisp cutoff. I don't have any photos, but I can say that the projector lens on the ecodes has less "dimples" on it than the us spec projector lens.
    Sep 11 2004
    16 Q5
    Westchester, NY
    For me personally, I couldn't care less about the lighting quality.
    I've bought ecodes on all my Audis strictly to rid myself of that horrible orange reflector. It's a sickness I know. It's definitely not normal to hate a piece of orange plastic.
    Dec 07 2012
    Atlanta, GA
    Quote Originally Posted by dyl0n View Post
    That cutoff
    Are these e codes or lens upgrade via retrofit
    Sent from my Nexus 6P using Google's ProjectFI
    Jan 06 2008
    Dacia Sandero
    Arizona
    No question.
    B8.5 []S5 . BBS . H&R . AWE . DEVAL . Stërn . 034 . OEM+
    Veteran Member Four Rings b8audis4's Avatar
    Nov 06 2013
    Ohio
    Quote Originally Posted by 4RingRook. View Post
    No question.
    Yes, still would have bought them. It is worth it, and you will get money back on resale.
    2011 Audi S4 - Ibis - Magma - Premium Plus - XPEL - STIR PLUS - Anti Laser Priority - AWE Resonated Exhaust - Ecodes - Alu Kruez - BBS CH-R (Mops)
    Dec 14 2014
    New Orleans, LA
    Ecodes from tag
    Veteran Member Four Rings Brother Owl's Avatar
    Mar 24 2015
    Denver
    Love my ecodes, got them instead of oem during an insurance claim. Worth every penney
    B8.5 S4 Estoril Blue Crystal 6MT : IE DP 3.2PR
    Denver to Vegas in 9:26
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    I was sourcing the clear reflectors from Europe for awhile and selling them. Haven't been able to get any for a few months now, have a huge waiting list. Guess no one is wrecking their cars as much.
    There are 10 kinds of people in this world, those who know binary and those who don't.
    Mar 17 2014
    Los Angeles, CA
    Anyone in SoCal that could help me do the jcode mod? I can't justify $1200 for clear reflectors (I'm used to my cutoff) but would be happy to pay someone to help me wrap my reflectors
    instagram
    Dec 14 2014
    New Orleans, LA
    Just do the right thing and get ecodes.
    Dec 20 2013
    Mercedes Benz ML350
    I have to say that this is one of those things where the 'right' thing is a major financial decision too.... ☺
    Mar 17 2014
    Los Angeles, CA
    It's a big chunk of change to achieve what I want. I could send these lights out and have the interiors custom painted for less than ecodes.
    instagram
    Dec 20 2013
    Mercedes Benz ML350
    Couldn't agree more
    Mar 17 2014
    Los Angeles, CA
    Couldn't agree more
    Maybe I'll win the lottery and I won't care about the cost
    instagram
    Dec 07 2012
    Atlanta, GA
    This is what I'm doing. Black out housing, carbon fiber amber delete, lenses upgraded.
    Veteran Member Four Rings yjypm's Avatar
    Oct 08 2015
    Evil Headlights in LA quoted me $300 thru Yelp for blackout the reflectors. I haven't had time to check it out.
    Current: '18 M3 ZCP
    Mods: | E85 | BMS Intake | MPE | BBS Fi-R | Brembo GT F+R BBK |
    Sold: '14 Estoril Blue S5 P+
    | B&O | Sports Diff | B&W Nappa | Nav |
    Mods: | EPL 179/57+DSG | P&P TB | Revo SC Cooler | Ecode Head+Tail | ECS RS5 Front BBK | Macan Ducts | Brembo GT Rear BBK | AWE Touring | IE Intake | Bilstein B12 | USP Led kit | CR-15 | 034 Rear SB+Links | AluKruez | ECS Trans+Diff Inserts | Apikol Diff Mount | VCDS | P3 |
    Dec 20 2013
    Mercedes Benz ML350
    My lens replacement (e-code style) and Plastidip arrived.... Looks like I have a weekend project lined up!
    Veteran Member Three Rings Batman0424's Avatar
    Dec 11 2015
    2020 SQ5, 2020 Audi Q3, and 2010 Mini Cooper S
    Hopewell, NJ
    Do you have a place lined up to do this work? I would like to upgrade my headlights, but if the ecodes aren't going to provide a crisper cut-off, then a custom job might be the answer.
    2020 Audi SQ5
    Dec 20 2013
    Mercedes Benz ML350
    Quote Originally Posted by Batman0424 View Post
    ONEightynyc.com
    Oct 14 2012
    Empty...for now...
    SE PA
    So when you say 'lens', are you referring to the clear plastic housing (front of the headlight housing assembly) or the lens for the projector itself?
    Dec 20 2013
    Mercedes Benz ML350
    Lens for the projector. This is essentially an E-code style lens (no bubbles), only better, at a fraction of the cost of e-codes. Plus, while I'm there, I'll be blacking out the housing and getting rid of the amber reflector.
