Results 1 to 10 of 10
    Active Member Two Rings razgriz10000's Avatar
    Feb 25 2015
    Detroit
    Question P R N D S all lit up
    Hello all.
    Can anyone tell me what it means when the
    P R N D S are all lit up?
    It won't shift lower than 3rd gear, even when stopped. It will shift up to higher gears though.
    What could all the possible causes be?
    2007 A4 B7
    2.0T Quattro
    110,XXX miles
    APR Stage I
    Forge DV
    BSH Top PCV Block-Off Plate
    Feb 15 2016
    Cambridge,Ontario
    You my friend are in limp mode.
    Your car has detected a serious transmission issue and has put you in "limp mode" to get you home.
    Time for a scan.
    might want to review your transmission warranty
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Oct 20 2008
    Denver
    Feb 15 2016
    Cambridge,Ontario
    1976 Yamaha XS 360
    Veteran Member Three Rings 1killera4's Avatar
    Mar 18 2014
    Dunedin Florida
    Pffffft.
    Oct 20 2008
    Denver
    are you sure you covered them all ? :)
    remember he did ask you to give him ALL the possible causes .. ;)
    well...
    About 113 results (0.17 seconds)
    lol.
    Feb 25 2015
    Detroit
    My bad guys...jeez. yes I had already done some searching. Just like a bit more of a personal response especially with how old some of the posts are. But thanks I guess.
    2007 A4 B7
    2.0T Quattro
    110,XXX miles
    APR Stage I
    Forge DV
    Sep 02 2008
    Boonies VA
    Quote Originally Posted by razgriz10000 View Post
    Would you have preferred someone sent you flowers?
    Not entirely sure what more you would have wanted? As the guy posted above there are 113 threads on the topic, it's more than likely your problem falls under those. Not going to get a more personal response when all the info is already out there and none of us are there looking at your car.
    White Wagon
    Oct 24 2015
    Perth, WA
    Razgriz, you need to scan your car mate. Only then can we be sure-ish of anything.
    My respray thread
    Veteran Member Four Rings eyesolution's Avatar
    Sep 23 2012
    Atlanta
    I've had this happen to me once in the cvt. It went away luckily for me. But the fix is to get the TCU changed to a new one it's not easy as its inside the transmission
