Results 1 to 6 of 6
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Ripped door foam - fix tips?
    I had to remove the foam off the passenger side door of a 2006 Audi A6 Avant Quattro 3.2 (typo 3.0 corrected)
    In some areas I managed to pull off the glue, but bottom length ripped completely full length, and some corners are also ripped.
    Any tips how to patch it up? Just use duct tape?
    What to use to re-glue the part that is in tact?
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    2006%20Audi%20A8L%3B%201994%20Volvo%20850%20Turbo
    I used RTV silicone without tape. But I also didn't rip too much, mostly cutting it off. Duct tape can get nasty with time and heat so think of that
    Sent from my SM-N910T using Tapatalk
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
    Feb 20 2010
    Brighton, MI
    Need to apply something over the rips themselves.
    05 Golf TDI
    Veteran Member Four Rings c@@kieMonsta's Avatar
    May 17 2009
    Idaho
    You're post is kind of confusing. Do you have a 2002 Avant or 2006? 'Cus ain't no such thing as a C6 3.0 A6, but yes for the C5.
    Current:
    2019 Ford Expedition
    2009 3.0T A6 Avant w/Prestige package, Side Assist, and Cold Weather package
    2016 2.7 EcoBoost Ford F-150 XLT SCREW
    2007 3.2 A4 Deep Sea Blue Avant
    2006 A6 Arctic White Avant
    2002 1.8t A4 Sedan
    Feb 20 2010
    Brighton, MI
    Quote Originally Posted by c@@kieMonsta View Post
    C6 A6. front right door foam.
    05 Golf TDI
    Feb 19 2013
    Use this crap. It's cheap enough and will stay put in high heat. It's also the same crap used to wrap the wires and not leave a gooey mess. I just had to find it. (I Love Amazon btw)
    http://www.amazon.com/Tesa-Black-Hig.../dp/B00EH6IZ6Y
    Dead:
