Results 1 to 12 of 12
    Nov 19 2013
    Rome, GA
    3.0 running rough all of a sudden....
    Driving home last night, my car seemed to all of a sudden run like crap. It had basically no power and would barely idle. I did an Auto-scan via Vagcom. Here is what I came up with:
    Got any ideas? I figured it was a coil pack issue and I plan on replacing all of them tomorrow.
    Aug 27 2013
    Philly
    Ahhh. The 4,5,6 misfire issue. I've been battling this for A LONG time (actually only like 2k miles, but thats a long time for me). I swapped fuel pump, coil packs, but I would still end up getting the 4,5,6. Mind you, I was running a kompresd tune which has since been deleted off the ECU(overwritten with Zimbu's tune) so it can cause no harm to anyone else. Im 99% sure this tune caused me to blow a set of stock coils, as well as a few R8 coils. I'm not sure whats up with it, but before tune I had no misfire issues, and after the tune its been nothing but misfire issues.
    Anyway.....
    One night my car FINALLY threw a code for the front o2 sensor on the drivers side (bank with cylinders 4,5,6). I swapped it out with an NTK sensor from amazon and BAM! No issues and the misfiring went away. I'm not sure what took so long for the sensor to throw a code, but when it finally i did I sat there thinking "Yup, that makes perfect sense". I'm not saying thats 100% your issue, but if the coils don't fix it, it's probably time for a new o2 sensor. I plan on doing the passenger side soon just so they are both up to date with the same mileage.
    Nov 19 2013
    Rome, GA
    My car has been throwing the P0431 code. I cleared the code this yesterday morning and then started running like crap yesterday evening. Would the P0431 more than likely refer to the O2 sensor?
    Aug 27 2013
    Philly
    Quote Originally Posted by Mikelb01 View Post
    Thats for the rear o2 sensor. That sensor does nothing but measure the efficiency of the catalytic converter. It's reading DO NOT adjust any engine PIDs. Pretty much every 3.0 has those codes, unless you put new sensors/cats/o2 sensor spacers in. It took a long time of my car running rough before the front o2 sensor code was tripped. I believe that code was a P0150.
    Nov 19 2013
    Rome, GA
    Welp, I replace all of the coil packs tonight and the car still won't start. I didn't have very long to work on it. Any ideas on what I can look at tomorrow when I have more time? Any help is appreciated! After my problems the other day, it won't even turn over. Worst part about it is the car is stuck at my Exes house!
    Aug 27 2013
    Philly
    Didn't know you had a no start condition. Time to narrow it down. Likely a spark or fuel issue. Clogged fuel filter maybe? Is the fuel pump priming when you turn the key? You can usually here it hum the first time you turn the key to the on position
    Sent from my Nexus 6 using Tapatalk
    Nov 19 2013
    Rome, GA
    I'll have to listen to it tomorrow when I go back to work on it, but I don't recall hearing it pressurize. If the fuel pump goes out does it make a buzzing/hissing noise? I thought I heard something the other day when it started having trouble, but couldn't really tell because of a neighbor playing his radio too loud. My car has 175k on it. Since I've owned it (145-175k), I've replaced the fuel filter once. Is there a schrader valve on the end of the fuel rail on the 3.0's? Not sure if the fuel pump has ever been replaced? Also, I haven't done the timing belt yet.
    Veteran Member Three Rings 19jdog's Avatar
    Jul 28 2014
    2006 Mini Cooper s - 2013 Mini Cooper S - 2007 C6 Avant - 2006 GSXR 750
    SACRAMENTO
    No start? I say check fuel pump, fuel pump fuse, and fuel filter. You could also unhook the fuel rail crank the car and see if it squirts all over the place.
    How old are the coil packs? I doubt they all went at the same time thou...
    11 Q7 Prestige TDI S Line - Stance SF 03 20x10
    04 B6 A4 USP 2.7t
    USP CLUB MEMBER #198
    BEL 2.7t SWAP- Rohana RC7 19x9.5 33mm - 034 REAR SWAYBAR - TIP TO 6 SPEED SWAP
    Aug 27 2013
    Philly
    No valve on the rail. There's an inline fuel gauge you need to add into the line right before the soft line turns into the hard line.
    The pump will groan when its dying. Usually it's a quick half second hum when working properly
    Nov 19 2013
    Rome, GA
    If my fuel pump did shit the bed, would it cause my car to misfire/run rough as crap with virtually no power and possibly not even run?
    - - - Updated - - -
    If my fuel pump did shit the bed, would it cause my car to misfire/run rough as crap with virtually no power and possibly not even run? Forgive my ignorance.
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Yes.
    Veteran Member Four Rings ZimbutheMonkey's Avatar
    Mar 27 2010
    solar system
    Quote Originally Posted by SJorge3442 View Post
    Anyway.....
    Hey long time no speak, I didn't know that you actually flashed my file to your car, how did it work? (good I hope )
