Results 1 to 29 of 29
    Senior Member Three Rings cinesnow's Avatar
    Jun 10 2012
    stg 3+ b5 s4 (black) b5 s4 (white) '01 allroad 6mt, 993 targa, '05.5 elise, '65 356c
    Local park bench
    let's talk custom coolant tanks
    Hello az,
    I'm in the process of making a couple of custom tanks for my racecar and dd and had a couple questions.
    Has anyone ever made their own?
    Also looking to learn at what pressure the coolant cap was designed to open at?
    If anyone has any info or has tackled this before please help me compile what is known here for others who may want to learn and save some time.
    TIA
    Racing is life, everything that happens before or after is just waiting...
    Dec 10 2013
    Borden, Ontario, Canada
    I saw one before on here. Can't remember if it was an A4 or S4 though. Looked like a nice unit
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Veteran Member Three Rings Audi9's Avatar
    Jul 20 2014
    B5 S4, 8V A3, 8V.5 RS3
    San Antonio, TX
    I've used tanks made for other applications that have dimensions similar to what I needed. Worked out great
    Established Member Two Rings nothingbutwin's Avatar
    Jun 23 2011
    Green Bay wi
    Coolant pressure caps usually open at 12 or 14 psi.
    May 16 2008
    WA
    Quote Originally Posted by Audi9 View Post
    such as?
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    why even run a coolant tank? i know a4rob just ran a filler neck inline. much cleaner looking in the bay
    - - - Updated - - -
    Quote Originally Posted by getslideways View Post
    such as?
    maybe the round vw mk3 coolant tanks?
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Mar 07 2010
    RS4 B5, RS6 V10,RS3 8Y
    CA
    Quote Originally Posted by GrapeBandit View Post
    - - - Updated - - -
    sorry for the dump question, how do you check fluid level if it leaks
    Misano Red RS4 2001 Transforming Phase
    Dec 10 2013
    The cluster will alert you
    IG: 24_et
    Sold:
    RIP:
    Veteran Member Three Rings slowrideBC's Avatar
    Jun 10 2012
    2000 s4
    I had one made that used the stock cap. Looks pretty slick too.
    2000 S4 - silver- RS4 OEM widebody racecar
    Dec 13 2010
    FL
    Quote Originally Posted by Bordom View Post
    how will the cluster alert you since there is no more coolant tank sensor hooked up? i would think the low coolant light would stay on since it's no longet connected. maybe a resistor in the sensor wires?
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    The water is what connects the circuit. If you just bridge the wires it tricks the cluster into thinking there is still a circuit.
    There was a guy that made a few batches. He did try to sell or did sell a few too. Im sure a search would net the results.
    Here: http://www.audizine.com/forum/showth...m-coolant-tank
    Jun 10 2012
    2000 s4
    /\ pic?
    Give me about a week and I'll get pics.
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    OMGHI- this guy has a badass avant
    and custom coolant tank.
    http://www.audizine.com/forum/showth...nt-Build/page4
    Jun 10 2012
    Local park bench
    In case anyone is interested, i'm going to make a run of five or so coolant tanks in the stock location over the summer after I see how this one works. They will use the stock check valve from your original cap and will have a drain petcock as well as a pressure gauge. I'm also looking into doing a power steering reservoir, if anyone has any interest in something like this please discuss or hmu.
    Dec 10 2013
    That is not the stock location lol
    IG: 24_et
    Sold:
    RIP:
    Jun 10 2012
    Local park bench
    You are correct, I just wanted to illustrate the components and how they all look welded up. I'll update when i make the one on the driver's side of the engine as soon as I get it finished
    May 16 2008
    WA
    Any means of seeing coolant level?
    Jun 10 2012
    Local park bench
    we discussed a sight glass but there is a mark inside the tank under the cap. will be using the low level sensor as well
    Jun 10 2012
    2000 s4
    Jun 10 2012
    2000 s4
    Veteran Member Three Rings e30mclow's Avatar
    Feb 08 2015
    An Irishman living in Canada
    Pardon my ignorance, but why is this necessary? Is it simply the fact that you're expecting/allowing it to run hotter than you'd comfortably trust the OEM reservoir to handle?
    Beautiful fab work for sure.
    Current: 1998 Mitsubishi Pajero Evolution
    1990 BMW E30 with 1JZ
    Previous Bad Ideas: 2000 Black Stage III (BW-K04); 2000 Imola Stage III (BW-K04)
    Previous "Better" Ideas: Euro e30 m3, Euro e34 m5, Inca Orange 2002Tii, '89 325iS, '89 318i, '90 318iS, '91 318iS, 2 X '87 316, '89 320i, '81 316 and so on..
    Veteran Member Three Rings y3ti's Avatar
    May 25 2014
    Long Beach, CA
    Quote Originally Posted by e30mclow View Post
    Slowride's build thread title says it all...
    "because racecar"
    Veteran Member Three Rings killerkali's Avatar
    Jan 01 2011
    Nor cal
    plastic will break eventually from heat. I've seen so many track cars days ended just from breaking coolant res
    Nov 14 2013
    I'm down. For the power steering res. it would be
    cool to build a set of high pressure line for a PS
    cooler.
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    you should fab up a way to be able to see how full it is. like the gauge idea a lot. if it had like a site glass or something i'd be in.
    something like this.
    only because i'd like to know before the light comes on that I'm low on coolant, most times I'm low I'm not at home...
    Mine - Silver 01.5 S4 stage 2 - st - apr - ssac - apikol
    Wife - Imola 00 S4 stage 2 - st - ssac - podi - usp - 034
    Ours - Silver 92 S4 custom coilovers - 3 inch exhaust - ak motorsports
    Indigo Pearl 92 Coupe
    White 07 Q7
    Nov 02 2014
    06 9-3 Aero 2.8T, 96 Miata
    Winchester, VA
    Quote Originally Posted by audacity View Post
    Honestly a sight glass is really unnecessary. Just check it periodically. Your vehicle should not be consuming coolant, if it goes low you have an issue.
    Stock engine with some rods tossed in. 11.25@132mph.
    Dec 04 2008
    5 audis and an f250
    Cresco PA
    Quote Originally Posted by DieselElectric View Post
    yeah honestly. your right but for people who don't want to idk pull the whole car apart every time something is wrong, while you could instead add some coolant here and there. seems like a small bung and a 5 dollar glass is barely something to snub as far as one less step to actually make sure everything is fine. b5 is hard enough. make it easier.
    cinesnow, maybe you could make one up for my c4. my tank is grossss
    White 07 Q7
    May 16 2008
    WA
    +1 for a quick way to see the level. Its nice to in a quick glance confirm that things are as they should be. I dont always like relying on electronics to tell me when trouble is afoot.
