Results 1 to 9 of 9
    Mar 14 2016
    2004 Nissan Maxima
    Brampton, ON
    Tilt steering wheel
    Hey everyone, I had a issue this morning with my car randomly not starting. It is a 2010 A6 3.0T. I had the battery replaced and it now works perfectly! I am having a little problem now, when I bought the car a few months back the telescopic worked perfect but the tilt up and down seemed locked and wouldn't work.... I messed around with it and done deal it started working till the stupid car died this morning. The telescopic works perfectly right now but it will not tilt down or up and is stuck in the high position.! Someone please tell me if it's a lock or there is some kind of trick that I did last time.
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    2006%20Audi%20A8L%3B%201994%20Volvo%20850%20Turbo
    Same thing happened to my car when I took off the battery. Unfortunately, you need Vagcom to reset it. I'm not even sure how;I poked around in there for a bit last weekend, but haven't got around to it again
    Sent from my SM-N910T using Tapatalk
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
    Mar 14 2016
    2004 Nissan Maxima
    Brampton, ON
    Quote Originally Posted by cal3thousand View Post
    So the Vagcom will reset the issue and it will work again? Or is it a motor problem?
    Feb 19 2013
    Quote Originally Posted by Chaldo View Post
    Mine is likely a vagcom issue. Not sure about yours. but if it was caused by a power interruption, it's likely
    Dead:
    Jul 17 2011
    Sin City, USA
    When replacing the battery after a low voltage issue, you need to program the ECU with the new battery. VAGCOM is necessary to do it. Once you scan the car, you will have a ton of fault codes due to the failing battery. Clear the codes, program the new battery and I bet your issue will clear up.
    '09 C6.5 A6
    Mar 14 2016
    2004 Nissan Maxima
    Brampton, ON
    Where can I get a vagcom my friend? It looks like I would need it for everything I do
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    Try google or your local ads section.
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Jul 17 2011
    Sin City, USA
    Ross-tech makes VAGCOM. Stay away from the eBay ODBII scanners.
    '09 C6.5 A6
    Veteran Member Four Rings Dutch_A6's Avatar
    Aug 19 2012
    GMC Terrain
    Belleville, IL
    The tilt might be caused by a bad relay switch, mine was stuck high and wouldn't change vertically but would go in and out, I bought a used switch and that fixed the problem.
    Sent from my VS985 4G using Tapatalk
    Black 2012 A7 Prestige
    Zito ZF01 wheels
    EPL stage 2 tune
    Tinted marker lights
    Roc Euro intake
    AWE touring exhaust
    APR CPS
