I've done some searching but could not find anyone with the specific sound I am getting.
I had $27k worth of crash damage on my 2014 S4, and got my car back just before new years this year. Along with the repairs, I had the shop throw on a new set of Michelin PSS because the OEM continentals were loud and at the wear bars. Car currently has 15k miles, 3k of which was from after the accident.
Since the repairs the PSS tires were night and day compared to the OEM tires and the car drove great and super quiet freeway cruising. In the last few weeks, though, I've noticed a bit of humming on the freeway. Its about the frequency of the freeway drone american v8 trucks get with a bad exhaust. Its fairly faint, and disappears with the radio at volume levels of "8" and above. I can "feel" the same humming noise through the gas pedal. The strangest thing is tha it ONLY happens at EXACTLY 73-76 mph. If I drive outside that speed range, I hear nothing. It happens on all pavement surfaces, more noticeable on quiet smooth asphalt. No change with side load.
I first looked for tailgating trucks/SUVs LOL....That wasn't it since it happens when I'm the only car on the road.
Next explanation is tire noise. I always seem to get visible heel-toe tread block wear on my audis after 2.5k, so decided to X rotate to reverse the wear like I did for the OEM tires. This did not fix the noise.
I know, you are probably thinking wheel bearings, but i did my best to check for play while rotating tires and found none.
About the same time I noticed the freeway noise, I also noticed that under moderate or harder braking, I can hear and feel "scraping/grinding" during the last few MPH before coming to a stop. Smooth at higher than 5mph. Not sure if its related, or maybe another sign of wheel bearing failure?
Any ideas?
