Results 1 to 29 of 29
    Veteran Member Three Rings Wagonholic's Avatar
    Mar 01 2014
    2001 B5 S4 Avant (Laser Red)
    Los Angeles, CA
    Drop-in rods...what else?
    Been a while since the last time I posted here, but I've got an upcoming project. I'm planning some upgrades on my car, and one of the major tasks is that I'm going to install some RPM rods (already have them) while the motor is out. As we all know firsthand, builds always have unexpected surprises, but I would like to ask those of you who have installed rods what other maintenance items you did while the motor was apart? I've done a lot of research, but I feel that there was no clear definitive thread on what should be done when installing.
    Here is what I'm planning:
    -New rod bearings
    -New piston rings
    -Gaskets (head gaskets, intake manifold, exhaust mainfold, valve cover, cranshaft seal, cam seals, oil pan)
    -Headbolts
    -Oil pan
    -Electric fan conversion
    The car is also due for a timing belt service, so I will be doing a Continental timing belt (don't want to have the Gates timing belt squeal lol)
    While the motor is apart, I'll take it to a machine shop for cylinder honing (due to new piston rings), cylinder head resurfacing, and block decking. Might as well since machine work isn't too expensive.
    Should I do the rear main seal as well?
    I'm pretty sure I'm missing a few things, so if there are any suggestions you guys have I'm open to anything.
    Justin
    I have a major problem, I'm a boost addict and a wagon addict
    #toomuchboost #racewagon #becauseracecar
    B5 S4 Avant - Laser Red. 6-speed Manual. 1 of 18. Unleashed by STUKLR
    Going big or going home. Doing a garage build. View my build thread.
    #YEengineering
    Aug 25 2012
    Elmore alabama
    I would definitely do both the front and rear main seals. The front seal is similar to the cam seals where as the rear is a flange type. May as well do this stuff so you won't have to later on.
    Veteran Member Three Rings y3ti's Avatar
    May 25 2014
    Long Beach, CA
    You aren't planning to balance the rotating assembly?
    Mar 01 2014
    Los Angeles, CA
    Quote Originally Posted by y3ti View Post
    Nope, not exactly necessary since I'm not building the head and revving to 8k lol. Most people don't anyway when doing the drop-in route, and the set of rods I have already has matched weights.
    Justin
    #YEengineering
    Aug 25 2012
    Elmore alabama
    Quote Originally Posted by Wagonholic View Post
    That's what some people do, but he also isn't shooting for 750hp and running 40psi. He doesn't have to balance if he is shooting for a power goal of let's say 550. He is building to his financial needs and power goals is what it sounds like to me.
    Mar 01 2014
    Los Angeles, CA
    Quote Originally Posted by S4tech2 View Post
    I should be okay at 749hp and 39psi then, right? Lol
    Justin
    #YEengineering
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    "Drop-in" and "rods" in the same sentence gives me the heeby jeebys.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    May 25 2014
    Long Beach, CA
    Even though the rods are matched to each other, they aren't matched to the crank.
    When I took my assembly in to have it balanced, the RPM rods had a decent amount of material removed from them.
    I only bring it up because I was recommended to balance it by an engine builder.
    What else do you have planned for the avant?
    Mar 22 2013
    AK
    What turbos and fuel are you planning to run......if you say Chicom K24 on SoCal piss pump you will not be needing rods. I would not crack open a well running good compression motor for the above. E85 or 605 /770's for sure.
    Mar 01 2014
    Los Angeles, CA
    I think we're all entitled to our own opinions. Personally I don't feel it is necessary (at my power goals), and I know several people who just dropped the rods in and called it a day with no issues. The block would probably let go before the rods do anyway lol.
    Quote Originally Posted by Drehmoment View Post
    SRM K24/RS6. On 91, 91/meth (majority of time), and E85.
    Like I said, I'm not completely eliminating the possibility of getting the rotating assembly balanced. My main purpose of this thread was to see if I had skipped over anything, and I appreciate the feedback so far.
    Justin
    #YEengineering
    May 25 2014
    Long Beach, CA
    Just trying to help.
    Veteran Member Four Rings rockcandy's Avatar
    Sep 08 2009
    00 S4, 15 S4
    Phoenix, AZ
    To waste your time going to a machine shop and not having the assembly balanced is ridiculous. Have you inquired about cost through a local machine shop? It's typically a couple hundred bucks while they're there. No brainier imo. To be honest, Your power goals have absolutely nothing to do with whether or not a motor should be balanced.
    B8 S4 owner who's lost his mind building his car. Come join me!
    Veteran Member Three Rings achb5's Avatar
    Feb 06 2009
    2001.5 S4 QM
    santa fe NM
    Cost me 150$ to have rotating assembly balanced up in Denver a month ago. Def worth it in my opinion.
    Veteran Member Four Rings NOTORIOUS VR's Avatar
    Jan 29 2009
    Would def. get the rotating parts balanced... It's not expensive. Certainly less then having some other sort of failure possibly caused by no doing it.
    FWIW, What RPM you're actually going to run has nothing to do with balancing the assembly, so when you say that you're not going to turn to 8k that doesn't mean anything.
    Aug 06 2008
    Canadia
    I would definitley do all the seals, you will be kicking yourself if you dont
    - - - Updated - - -
    Knife edge the crank if your getting it balanced
    the B5 S4 is like the mafia... there is only one way out!
    Jan 29 2009
    Quote Originally Posted by MacDaddy View Post
    That I would avoid personally
    Dec 10 2013
    Borden, Ontario, Canada
    Quote Originally Posted by NOTORIOUS VR View Post
    Why?
    Everything graciously mispelled by Android
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    Quote Originally Posted by Bordom View Post
    Why?
    serves almost no purpose on a forced induction engine. also, the only audi crank i seen bend was a knife edged 1.8t crank.
    -puts more load on crank bearings
    -crank will start to flex a bit more at higher revs and can lead to a premature failure
    -power gains to risk factor=not worth it
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Mar 01 2014
    Los Angeles, CA
    Quote Originally Posted by achb5 View Post
    If that is the case, then it's a no brainer lol.
    That is being planned, and I believe I have all the seals covered (no pun intended) in my original post
    Justin
    #YEengineering
    Mar 01 2014
    Los Angeles, CA
    Again, appreciate the feedback from everyone. I just wanted to make sure I had all the bases covered before I began the build, and it looks like balancing the rotating assembly was something I had originally missed.
    I will be starting a build thread in the next couple of weeks when everything begins to unfold. Oh, and I will have many K04 parts and turbos for sale as well once this is complete lol. In the meantime, any more suggestions/feedback is always appreciated; not just for me, but for others planning to do similar modifications.
    Justin
    #YEengineering
    May 25 2014
    Long Beach, CA
    balancing the rotating assembly is definitely going to cost you more than $150 all said and done. Taking out the crank requires new front and rear main seals, new main bearings, new main studs ($$$) or bolts, and thrust washers.
    You will need to take in the crank, pistons w/ rings, rods, flywheel, clutch, and all the hardware.
    That's just off the top of my head... I could be missing something.
    Dec 10 2013
    Interested in K04s provided they're in good condition
    IG: 24_et
    Sold:
    RIP:
    Veteran Member Three Rings ElementR's Avatar
    Nov 23 2013
    2016 Stg 2 S6, '93 Mustang Cobra Twin Turbo 347cid, '01 B5 S4 Tial 605's
    Grosse Pointe, MI
    I would definitely balance the rotating assembly. A good shop can do it for $200-300 tops. As these engines are internally balanced, they will not need the crank damper or flywheel. They will need your crank and one piston + rod + piston rings + rod bearings + wrist pin/locks.
    2001 Silver/Black S4, Built engine, Tial 605's @25psi on 93 oct, ET Spec Tune, JHM FMIC, JHM full trans rebuilt/upgrade, 3" SS dp + CBE, Vast intake + bipipes + tune, ST Coilovers, Hotchkis Swaybars, RS4 wheels and interior goodies.
    2016 Silver/Black S6 Sport Package, IE Stg 2 E85 & DSG tunes, IE intake, ARM DP's & Mid-pipes
    Aug 06 2008
    Canadia
    Quote Originally Posted by GrapeBandit View Post
    cool story bro, if your going to make stuff up next time make it believable.
    Veteran Member Four Rings jaychen's Avatar
    Feb 19 2011
    Earth
    lul
    Dec 13 2010
    FL
    Quote Originally Posted by jaychen View Post
    lul
    such a cool story that you have no fucking clue what you are talking about. maybe do some research on it before you open your mouth next time, because i am 100% correct.
    why dont you shoot an email to say integrated engineering, al at pag parts, or any competent forced induction engine builder about this topic, then post a screenshot of their response, then we will see who is loling at who.
    Feb 19 2011
    Earth
    calm down princess.
    Aug 06 2008
    Canadia
    You are 100% correct you say? Anyone worth listening to doesn't make a claim like that.
    Jan 29 2009
    Why?
    For me it's always about a balance... Street cars, especially AWD cars like/need rotating mass IMO. Makes them happier and easier to drive. Same goes for light FW's... too light and it's just not happy.
    I tend to advise people away from race car modifications for their street cars.
