Results 1 to 16 of 16
    Established Member Two Rings MathildaS3's Avatar
    Apr 14 2015
    Palm Beach Gardens, FL
    LED turn signals
    After reading a post or 2, I shopped Ebay and found LEDs for $23 shipped. They're super bright! New LED is on right side, with original incandescent on the left.
    http://m.ebay.com/itm/181909064710?_mwBanner=1
    2016 Sepang Blue S3. MagRide, SuperSport seats, B&O, RS3 grille, wheel spacers 10mm/17.5mm, K&N drop-in filter, stock intake mod, LED interiors, Spulen engine mount insert (modified), BMS JB4 tune. Sleeper AF...
    Sep 14 2006
    wow thx for sharing. It's not throwing any codes right?
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Senior Member Three Rings miro01's Avatar
    Mar 26 2012
    '97 B5 A4, '15 8V A3
    OC
    No codes when I switched mine a few months ago.
    Sent from my SM-G925T using Tapatalk
    Apr 14 2015
    Just took the first drive after installing them last night. No codes.
    Established Member Two Rings sub-zero's Avatar
    Jan 25 2016
    Cleveland, OH
    what's the install like?
    Apr 14 2015
    Unscrew ~3" cap, pull socket straight back, replace bulb in socket, push socket straight forward, replace cap. I was trying to find a clip or twist the socket out, but it's just a snap fit into the housing.
    Sep 22 2014
    Austin, Texas
    just got mine. same eBay seller. took 2mins. so much better. still wish I had the led day time running light amber signal from the full led headlights but this is a huge improvement.
    Established Member Two Rings interestingjim's Avatar
    Jan 11 2016
    Massachusetts
    Question. I was driving and got a front left turn signal bulb error. Stopped and saw the bulb fell out and is rolling freely inside headlight housing. Any recommendations to get bulb out? Hoping to not have to remove the bumper/headlight entirely
    Apr 14 2015
    Jan 11 2016
    Massachusetts
    Quote Originally Posted by MathildaS3 View Post
    Thanks! I'll have to pick one up and try it!
    Veteran Member Three Rings Baggio's Avatar
    Aug 28 2013
    University Heights, OH
    Quote Originally Posted by interestingjim View Post
    Still under warranty? I would take that to the dealer to figure out.
    2015 Daytona Gray Pearl Effect Audi S3 Quattro | Daytona 1 PKG | USP Motorsports interior LEDs |
    | APR Stage 2 ECU 93 HT & TCU tune | K&N | rain tray delete from airbox | REVO CF intake scoop | Spulen turbo inlet hose | APR turbo muffler delete |
    | APR IC | CTS Turbo inlet, outlet, and throttle pipes | Neuspeed 3" catted downpipe | 034 dogbone mount insert | 034 rear subframe inserts | Spulen intake coolant hose | ECS SS brake lines |
    Jan 11 2016
    Massachusetts
    Quote Originally Posted by Baggio View Post
    Yes but I've replaced the original halogen bulb with these LED ones, so not sure if that has any affect on whether or not they can fix for free under the warranty.
    Aug 28 2013
    Probably not. They will say you probably didn't mount it correctly. But they may have an idea on how to get them out.
    Jan 11 2016
    Massachusetts
    FYI picked up the tool for $8 and got the bulb out in 5 minutes. Thanks!
    Apr 14 2015
    Any time, dude. Glad that did it.
    May 11 2016
    MA
    Will these work with LED headlights? I heard they may be different but would like to confirm. Thanks
