UPDATE: Partially solved down below. tl;dr: Still have a TC problem, but it's minor, only happens in cold weather, and does not seem to be related in any way to the hard shifting (snub mount fixed that) or the stumbling (ended up being a bad ignition coil).
2006 A4 2.0T quattro here. All winter long, I experienced a lot of the RPM surge under light throttle especially when the car was cold. At some point in there, I had my fluid replaced (Euro shop, genuine Audi fluid). It helped...a little.
Once the weather warmed up, that completely went away, but was replaced with a new symptom. I've been getting hard shifts from 2 > 3 and from 4 < 3 and a little hard shifting into 5th. Always once the car/transmission fully heats up. It's also mostly in D or S--not as evident in manual shift mode (although, it has happened). No more RPM bounce, though. So I started to worry there's something more wrong with the transmission than previously thought.
Finally got a chance to log some data with VAGCOM. Here's just a snippet of the log file:
According to Audi's TSB on this issue, slippage should not exceed 120RPM when the torque converter is in control mode (regulated, I assume) and should not have any slip in closed mode. You can see just from this snippet when I get on it, it is slipping fairly significantly. This was a WOT (you can see accelerator position) uphill getting on an interstate. At some point in the power band, I could feel like something was slipping and the engine RPM dipped just a bit. This is just a small section of the logs, but there are several places it goes >120RPM in TCC mode and probably half the times the TC is closed, it's got numbers > 0.
I assume this pretty much proves that I need to see about getting my TC replaced? Is the hard shifting a symptom of this too or do I have an issue with something else in the transmission too? I didn't notice any specific TC-related numbers that correlated exactly with the hard shifts in the logs, but it's hard to match those up exactly.
Lastly, is there any way to determine if I'm on the latest software revision? I can see my software revision for the TCM (8E1 910 156 C), but I can't find anywhere on the web that shows the latest per Audi.
tl;dr I'm pretty sure my torque converter is boned--I just want to make sure before I spend this kind of money.
