Results 1 to 24 of 24
    Sep 04 2011
    Central NJ
    MY16 S6 0-60 w/o LC
    I have a MY16 S6 without any modifications and wanted to test my 0-60 without using launch control just by flooring the gas pedal. My testing equipment was the Ross-Tech Hex-Net connected to VCDS on a laptop either by USB cable or WiFi (did not make a difference). The car was in dynamic mode, the transmission in S mode, and the electronic stability control was on. When I floored the pedal it seemed like eternity before the car started to move (perhaps almost a second). The 0-60 times reported by VCDS acceleration module were consistently about 5.0 seconds. Does that sound reasonable? I had previously tested using Torque Pro and a bluetooth dongle but my phone was flying around and the times were between 6.5 and 7.5 seconds. I knew that wasn't right probably caused by slow GPS refresh rate and phone not being immobilized. Any suggestion how to improve 0-60 without using LC or getting a tune? Any suggestions on how to measure 0-60 more accurately short of getting a VBOX sport?
    Nov 23 2015
    Oklahoma
    If you were pushing the brake and gas at the same time, it might be retarding you throttle input...
    Sep 04 2011
    Central NJ
    Quote Originally Posted by markreed View Post
    Didn't do that. Had my right foot on the brake. Let the brake go and stomped on the gas.
    Veteran Member Four Rings richib86's Avatar
    Nov 05 2006
    Fair Lawn
    if you dont want to use LC you're better off brake boosting the car...
    2019 S4, Quantum Grey, Magma red, Presitge, Black ops, Sport package, Driver assist, Dynamic steering, Carbon mirrors and spoiler, Xpel XR ceramic 35%, Alcantara flat bottom wheel w/ RS paddles, Alcantara shifter, TAG reflectors, APR Stage 1, CTS testpipe, Resonated Miltek, P3 gauge, KW H.A.S., ECS Intake scoop, ECS Carbon intake, ECS Intercooler with charge pipes, ECS Carbon engine cover overlay, ECS Carbon ECU cover, O34 trans insert, O34 rear sway bar, HRE P101 20x9.5 ET35 w/ 265/30/20 PS4s
    Senior Member Three Rings hubris's Avatar
    Jul 07 2015
    Midwest
    Quote Originally Posted by richib86 View Post
    Can you brake boost without APR? I thought that was one of their improvements with the tune is it unlocks pedal input from both brake/gas.
    2014 S6 | Prestige | Ibis White | APR Stage 2 | Milltek Turbo-back Exhaust, Resonated, ValveSonic, High-Flow Cats | P3 Boost Gauge
    Veteran Member Three Rings jstrebel's Avatar
    Oct 02 2006
    Tucson, AZ
    From what you describe I don't think you actually were using LC. Procedure is: 1 hold down the TC button for a second, you will then see a message of ESC in sport mode followed by Braking Guard Off in the console display. Then while in Dynamic + S left foot brake all the way to the floor, hard. Pause a second. Now right foot floor the gas, RPM's will rise to around 4500-5k and hold there.. Now just release the brake and yer gone.
    2005 A4 1.8t Ultrasport: SOLD.
    2016 S7: Build Thread - SOLD
    2023 R8 AWD Performance: Build Thread
    2024 RS6: Reel
    Oct 02 2006
    Tucson, AZ
    Derp.. Read your post again, you said 'without LC' my bad
    2024 RS6: Reel
    Sep 04 2011
    Central NJ
    Thanks for all the replies so far. I was just wondering if 5.0 seconds 0-60 sounds about right for a stock S6 just flooring the gas pedal and not using launch control.
    Jan 30 2015
    2012 A6 3.0T Prestige + others
    Irvine/CA
    Quote Originally Posted by hmuller View Post
    quick answer would be no, that should be for stock A6 3.0T number (+/- 0.3s depending on situation)
    - Michael
    2012 A6 3.0T Prestige:
    GIAC Dual Pulley 57.1+187 / Merc HX / Injen Intake / OEM muffler mod (Quad Tips + X-Pipe) / Eurocode drivetrain inserts / 034 Swaybar / Volk wheels / Bilstein+Eibach / RS front grill / Deval Carbon rear diffuser / Maxton Front Spoiler and Side Skirt add on / Carbon trunk spoiler / Carbon mirror / Stoptech rotors.
    Nov 05 2006
    Fair Lawn
    OP is also using VAG for 0-60 which also isnt the best way of measuring it
    Sep 04 2011
    Central NJ
    Any cheap suggestions for better ways to measure it? I didn't really want to spend $430+ to get the VBOX sport.
    Jul 07 2015
    Midwest
    P3Gauge is cheaper (mine was $380 but you can pay less if you're patient and wait for a sale), and it integrates right into your OEM vent and looks very stylish. Plus it offers instant readout on boost (I keep mine displaying boost all the time), EGT, temps, throttle position, RPMs, 0-100, 0-60 of course, etc., all kinds of neat stuff.
    Dec 10 2011
    991 C2S, Stage 3 S4, E46 M3
    CLT | MKE
    P3Gauge is cool and certainly offers lots of neat data, but isn't "better" in terms of measuring 0-60, I assume, since it's using the same data as VCDS does.
    -Hayden
    B9 Q5 | Brilliant Black
    E46 M3 Cab | Steel Grey
    Veteran Member Three Rings Dguth's Avatar
    Dec 14 2011
    Dublin, OH
    MY16 S6 0-60 w/o LC
    So what's the best thing to buy or use to measure 0-60, 1/4 mile times, boost, etc. I'm looking into getting something. I loved my jeep SRT, it had all of this built in.
    2014 S6 | Glacier White | Prestige Package | B&O Sound | Tinted & Lowered | APR Stage 1.1 Tune | APR TCU Tune | XPEL Front | Flat Bottom Steering Wheel | Soon to be installed: RS7 Turbo, RS7 Intake, AMS Coolant Upgrade, AMS High Flow Downpipes, RS6 Grill and APR Stage 3 Tune
    Jul 07 2015
    Midwest
    Quote Originally Posted by LINDW4LL View Post
    Correct, it uses the same data via OBDII as VCDS, however it reads at a much higher rate than VCDS to my knowledge so it is inherently much better.
    Mar 14 2008
    Audi S5, Porsche 718 Spyder, Audi RS5
    MA
    I have found that the best way to launch the car without launch control is actually not to just stomp on the gas. There is a definite delay if you do this, especially if the stability is still on. Turn the stability off, but then push the accelerator down in a smooth steady fashion.
    Current Fleet: Porsche 718 Spyder * Audi S5 Sportback * Audi RS5 Sportback
    On order: Audi RSQ8 Performance
    Senior Member Three Rings luv2sleep's Avatar
    Jun 12 2012
    I agree with VVG. Turn the stability control off and you get better throttle to rubber response fosho! Computers are nice but sometimes they get in the way.
    Sep 04 2011
    Central NJ
    Quote Originally Posted by hubris View Post
    The log from VCDS connected to my Hex-Net shows ten reads per second. Do you know what the refresh rate is for the P3 vent gauge? At $389 it is only a little cheaper than the VBOX sport which is a 20Hz GPS logger but it definitely looks stylish.
    Sep 04 2011
    Central NJ
    Update: I while ago I bit the bullet and bought a VBOX sport and it confirmed the 0-60 times previously measured with VCDS. Using the sequence described above (i.e. just flooring the gas without launch control) I got about 5.0 seconds very consistently. A few weeks ago I upgraded to stage 1 APR ECU/TCU and K&N air filter and now acceleration is in a different league. Same procedure, just flooring the gas, the VBOX sport reports 0-60 times of 3.8-4.0 seconds with the occasional 4.2 seconds. I have not yet tried launch control but since I'm no longer limited to 200 launches I may give it a try one of these days. Stay tuned.
    2016 Audi S6 Prestige
    2015 Audi Q7 S line Prestige
    Senior Member Two Rings FourRings115's Avatar
    Sep 28 2016
    Hoboken
    Can you elaborate on the 200 launch limit? Warranty issues? Thanks!
    '16 S6
    ‘14 Porsche Cayman S
    '18 Subaru Forester (company car)
    '11 A8L 4.2 (sold)
    '07 A8L 4.2 (sold)
    '04 A6 2.7T (sold)
    Sep 04 2011
    Central NJ
    Quote Originally Posted by FourRings115 View Post
    If you are stock, the use of launch control is limited by Audi to 200 times. A TCU tune can overwrite this limit (e.g. APR TCU tune limit is 3000). I'm planning to flash back to stock before visiting the dealership for any service. If I'm lucky, I can avoid warranty issues this way, if I'm unlucky, I'll have to pay to play.
    Feb 25 2014
    Texas
    Use launch control and report back!!!
    Mickey (AKA: AudiS4B8)
    Instagram: ze_nardo6
    10.65 @ 129mph
    Veteran Member Four Rings zcd2.7t's Avatar
    Jan 19 2010
    MI/CA
    Using the sequence described above (i.e. just flooring the gas without launch control) I got about 5.0 seconds very consistently...I have not yet tried launch control but since I'm no longer limited to 200 launches I may give it a try one of these days. Stay tuned.
    FWIW, Car and Driver got 0-60 in 3.7 seconds with L/C and 5-60 (roughly equivalent to your launch technique) in 4.9 seconds, so your results sound spot-on.
    The "Dynolicious" mobile app reported 0-60 in 4.2 seconds using L/C the one time I used the app in this car...
    2022 Tesla Model 3 Performance
    2023 Genesis GV60 Performance
    2015 Q5 TDi - Torque, baby!
    (Gone) 2013 S6, Glacier White over Black.
    (Gone, never forgotten) 2011 S4 Prestige S-tronic wSTaSIS stuff
    Sep 10 2015
    VA
    I was getting 3.8-4.0 seconds to 60 on stage 1+ but was having grip issues with launch control. Waiting for the trans tune to see if this would help.
