Results 1 to 13 of 13
Thread: Will not start
    Mar 14 2016
    2004 Nissan Maxima
    Brampton, ON
    Will not start
    Hey everyone hopefully someone might be able to help me out. My 2010 a6 3.0t randomly did not start today. The car has the original battery, it only clicks once and does not turn the motor over. I tried using booster cables and no luck. Could this be the starter? It always took a few cranks to start before, now I'm thinking of buying a new battery.
    Jul 17 2011
    Sin City, USA
    I would start with the battery. It may have enough juice in it to power the interior, but not enough to start. Do you have VAGCOM as you will need to code the new battery to the system.
    '09 C6.5 A6
    May 22 2010
    N.E. Connecticut
    Could be a bad connection at the starter. Check that 1st make sure the connections are clean free of corrosion. ( unhook positive on battery 1st )
    Next would be to clean completely the battery terminals and set it up on a slow overnight charge... Next is look at your alternator connections. again clean those up ..
    All the above will not cost you but time and effort. ( unless you don't have a battery charger which you should... Once everything is cleaned and hopefully running go have the battery checked to see if it is holding a charge... If no then a new battery may be in order... If it is the original than 6 years or less is about life expectancy especially in very cold climates.
    Established Member Two Rings kocyk123's Avatar
    Nov 02 2015
    2001 Audi A8L
    Harwood Heights IL
    I would also go through all fuses and relays.
    Current rides:
    1. 2013 Hyundai Azera Tech 50k miles
    2. 2001 A8L 4.2 Quattro 211k miles
    Sold:
    1. 2007 A6 4.2 FSI Quattro 77k miles
    2. 2007 Acura TL Nav at 86k miles
    3. 1996 A6 Quattro at 155k miles
    Mar 14 2016
    2004 Nissan Maxima
    Brampton, ON
    I can't just remove old battery and add a new one? I don't have a vagcom and don't plan on paying Audi over 60.00$ for a battery install.
    Mar 14 2016
    2004 Nissan Maxima
    Brampton, ON
    I know for a fact that the battery terminals are good and clean. Not too sure about the starter and alternator tho. I also don't have a battery charger as you mentioned above.
    Veteran Member Four Rings ichi d's Avatar
    May 10 2013
    Toronto,ON
    I think audi has to recode the battery once a new one is installed. I could be wrong tho.
    C7 S6 / AWE Touring / -14mm / EuroTails /
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by ichi d View Post
    It doesnt have to be Audi, but VAGCOM is needed. The power module (big black thing on the positive batterty termianl) regulates the power to and from the battery. If you just swap batteries without updating the ECU, the car will run but you will get a message "low voltage, battery will charge while driving" everytime you start the car.
    '09 C6.5 A6
    Veteran Member Three Rings cal3thousand's Avatar
    Feb 19 2013
    2006%20Audi%20A8L%3B%201994%20Volvo%20850%20Turbo
    Does the car 'try' to start and not go? Or does it not even try?
    If it doesn't even try, I would say a sensor (crank or cam) might be the cause. If it cranks but doesn't start, battery.
    Danton Black: 2009 Audi C6.5 A6 Sedan (Quattro, 3.0T, Prestige)
    I miss my Avant, longing for a 2011 3.0T
    Dead:
    Griselda, aka Grizzy: 2007 Audi C6 A6 Avant (Quattro, S-Line)
    Just some small cosmetic mods while getting to Stage 0
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by cal3thousand View Post
    Not necessarily true. When my OEM battery failed, it would not even try and crank over. Just clicked once and nothing; similar to the condition the OP described. The power control module on the battery is going to preserve as much energy as possible so when it reads a major power drain, it starts shutting down systems. The starting mechanism is the first to be shut off as it takes the most power at start up. The car wants to keep the lights (hazards, etc.) operational instead of allowing the battery to be completely drained.
    '09 C6.5 A6
    Feb 19 2013
    That makes sense.
    So best would be just run a VAG COM scan and see if it's battery or other right?
    Sent from my SM-N910T using Tapatalk
    Dead:
    Jul 17 2011
    Sin City, USA
    Quote Originally Posted by Chaldo View Post
    That makes sense.
    That would be correct. However, OP does not have VAGCOM.
    '09 C6.5 A6
    Veteran Member Four Rings maga4's Avatar
    Aug 12 2011
    Olathe, Kansas
    When my amp went out, it kept draining my battery. It would get too weak to start even with a jump, and then eventually everything was completely dead.
    My first suggestion would be to remove the battery, take it to Autozone, and have them test and charge it. They will do both for free, and if the battery's crap, you can just replace it there and figure out the Vag-Com deal later.
    Good luck!
    2010 A6 3.0T Prestige, Quartz/Black
    35% Tint, VCDS, Hardwired V1, LED Interior/License Plate, Chipwerke Pro, WeatherTech
    Previous: 2011 A4 P+, APR Stage 2, 35% Tint, Eibach Pro-Kit, VCDS, Gloss Black Grille, Fogs,
    LED Interior/License Plate Lights, Short Shifter, BFI Catch Can, V1, Rieger Lip Replica, FRT's FMIC, aFe Filter
